Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculating resolved scale k and epsilon (LES)
Like Tree1Likes
  • 1 Post By pm11dt
Old   March 28, 2017, 10:59
Post Calculating resolved scale k and epsilon (LES)
Daniel W Theobald
pm11dt is on a distinguished road
I'm relatively new to openFoam and require some help with a specific issue I'm having when dealing with the post processing of LES cases.
I need to calculate k and epsilon fields for my LES case in order to compare with a RANS K-epsilon case I ran previously. In order to achieve this I have been using the following 3rd party utility:
postAverageTurbulenceFields found here: Utilities: post average turbulence fields and create turbulence fields for LES
However, I believe this utility only calls back and writes values for k from the transport equation solved during simulation. This would be fine when used with RANS but not for LES. I used the oneEqEddy viscosity sgs model which has a transport equation for ksgs and writes ksgs as k in the time directory.
When i use this tool with oneEqEddy LES model it will write ksgs as k and is probably writing epsilon from the sgs based on the same assumptions.
I need a way of calculating the total k and total epsilon for my LES case by either modifying postAverageTurbulenceFields utility or using some other utility to calculate these values from the mean velocity information I have.
k=0.5<U'_i><U'_i>
epsilon= nu(d<U'_i>/d<x_j>)^2
nu = nuSgs + nu of material ..?
Any help would be very much appreciated, but I should mention I have very little programming experience i.e. actually modifying source code. I am using and older version of openFoam, v2.3.1.
Thanks!
Daniel.
tariq likes this.
pm11dt is offline   Reply With Quote
averageturbulencefields, epsilon, les, oneeqeddy, turbulence disapation
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
Calculation of Epsilon in LES model Yuri Almeida OpenFOAM 2 January 18, 2013 08:43
epsilon and K blowing up. sivakumar OpenFOAM Running, Solving & CFD 1 October 25, 2012 05:50
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
k epsilon and LES louison Main CFD Forum 1 May 2, 2005 01:10
