Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
DTC HULL post processing right setting
Like Tree1Likes
  • 1 Post By Subodh21
Old   March 8, 2017, 18:21
Default DTC HULL post processing right setting
Raffaele Frontera
Raffaele Frontera is on a distinguished road
Hi guys, do you know how works the post processing for the DTC Hull? There is not motion and I cannot have really different colors for the U and p
Thank you in advance
p.s I am new!
Raffaele Frontera is offline   Reply With Quote
Old   April 25, 2017, 16:50
Subodh
Subodh21 is on a distinguished road
you should witch off your stl geometry of DTC hull.
Also you can try selecting the contour edit right next to contour on/off option on the top left hand side to change the color scheme of the contours.
Use play option to see the results at different time steps or to run animation.
Also there are lot of filters in Paraview you can play with to visualize the results.
Hope this helps.
Good Luck!
Raffaele Frontera likes this.
Subodh21 is offline   Reply With Quote
Old   May 20, 2017, 03:44
raju ram bhakar
bhakar.raju98 is on a distinguished road
Hello Raffaele,
I am also studying the DTC Hull geometry. I am facing the same problem using paraFoam.
Do you have any suggestion how should I proceed with it.
The only remaining part is paraView.
bhakar.raju98 is offline   Reply With Quote
Old   May 24, 2017, 13:09
Raffaele Frontera
Hello bhakar.raju98,
just follow what Subodh21 said, if you still have problem then write here in the forum again and I/we will reply.
Raffaele
Old   May 25, 2017, 01:01
raju ram bhakar
Hello Raffaele,
I had figured out what I was missing.
Thankyou.
Setting the desired Zoom level in ANSYS CFD Post for custom reports shreyasr CFX 1 July 11, 2013 02:57
post processing for CEL expressions Niru CFX 0 May 10, 2013 14:13
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 07:21
post processing in CFX11.0 u k jha CFX 1 September 17, 2010 06:53
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 21:51
