Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to plot surface elevation vs time in paraview4?
Like Tree1Likes
  • 1 Post By kasra karimi
Old   January 24, 2017, 15:18
Default How to plot surface elevation vs time in paraview4?
Ioanna
iostam is on a distinguished road
I am using interFOAM to run a dam break case. I am post-processing the results with paraview4 and trying to get a plot of water elevation versus time. Everything I have tried seems to give me wrong results.
Any ideas?
Thank you,
Ioanna
iostam is offline   Reply With Quote
Old   February 22, 2017, 15:51
kasra karimi
kasra karimi is on a distinguished road
Any ideas?
Thank you,
Ioanna
Hi Ioanna
you can pick a section which you want to see the free surface fluctuation in that, then you should use "plot over line" option from filters>data analysis (be sure that the line covers all of the vertical length on your domain), then chose the "integrated variables", and in the final step chose "plot selection over time "
iostam likes this.
kasra karimi is offline   Reply With Quote
dam break results, paraview 4.0.1, plot surface, plot vs time
Elastic or Plastic Deformations in OpenFOAM NickolasPl OpenFOAM Pre-Processing 36 September 23, 2023 09:22
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
