Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Thrust Force calculation on Wind turbine blade
Like Tree1Likes
  • 1 Post By vd93
Old   November 29, 2016, 11:26
Default Thrust Force calculation on Wind turbine blade
VarunDas
vd93 is on a distinguished road
I am rather a beginner in OpenFoam, so please do excuse me if this question sounds a bit too trivial.
I am currently working on the CFD analysis of a Horizontal axis wind turbine using OpenFOAM for my master thesis. I am running a clean blade for a free stream velocity of 8m/s and omega 36.577 rad/s. I have got the results and they do seem reasonable based on the pressure distributions over the blade as well as the flowfield around the blade.
I have successfully calculated the power coeffcient for my blade and am getting an error of 5% when compared to the experimental case.
As for the thrust coefficient, I am getting an error of about 16% compared to the experimental results.
I believe I am making a mistake in regards to the thrust force calculation from the log file. Presently, I am calculating the thrust by obtaining the average of the pressure and viscous forces along the direction of the flow (y axis in my case) for the final 1000 iterations and implementing the following formulae.
Thrust_force = (pressure_force_avg * density) + (viscous_force_avg);
and consequently the Ct as,
Ct = (Thrust_force)/(0.5 * density * V^2 * Area);
I would like to know if my above calculation is correct or not and if not a correct solution would be much appreciated.
Thank you for your time!
-Varun
hirota likes this.
vd93 is offline   Reply With Quote
Old   January 9, 2018, 09:34
M. Salman Siddiqui
muhammss is on a distinguished road
Did you manage to get the correct answer?
How did you calculated the Cp? I mean the formula?
muhammss is offline   Reply With Quote
Old   February 6, 2022, 23:35
Nazi
CFD-Shiraz is on a distinguished road
Originally Posted by vd93 View Post
-Varun
I have the similar problem. What is velocity and area? How did you calculate the area.?
CFD-Shiraz is offline   Reply With Quote
Does anyone have 3D blade profile of wind turbine? kenya0514 Main CFD Forum 5 March 9, 2015 15:06
Wind Turbine Blade rotation mmd_knr FLUENT 1 August 8, 2012 15:52
Verifying results for a wind turbine blade simulation in ANSYS CFX Joystix CFX 3 April 27, 2012 18:52
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 03:33
