Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
function to record water level of the whole domain
Like Tree1Likes
  • 1 Post By tomf
Old   September 20, 2016, 20:17
Default function to record water level of the whole domain
Zhifang Hu
ce73stargazer is on a distinguished road
Hi there.
I did some multiphase problem with OpenFOAM and I used probe sampling to extract alpha.water at certain location to find out the water level changes over the simulation time.
Meanwhile, I am wondering if there is any function available in OpenFOAM to extract the whole domain's water level at any specific time step, for example at t =10s.
I went through the user manual without much luck, anyone has any suggestion?
Cheers
Zhifang
ce73stargazer is offline   Reply With Quote
Old   September 21, 2016, 05:28
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I think generating an isosurface of alpha=0.5 might work for you. You can than make a vtk surface that you could plot in paraview. I guess the following would work for version 3.0, maybe also 4.0, but syntax may have changed.
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
surfaces
    type            surfaces;
    functionObjectLibs ("libsampling.so");
    outputControl   outputTime;
    surfaceFormat   vtk;
    fields          (p U k epsilon);
    interpolationScheme cellPoint;
    surfaces
        isoAlpha
            type            isoSurface;
            isoField        alpha.water;
            isoValue        0.5;
            interpolate     true;
For inspiration try this:
grep -r isoSurface $FOAM_TUTORIALS
Cheers,
Tom
raj kumar saini likes this.
tomf is offline   Reply With Quote
Old   September 22, 2016, 00:04
Zhifang Hu
Originally Posted by tomf View Post
surfaces
    type            surfaces;
    surfaceFormat   vtk;
    surfaces
        isoAlpha
            type            isoSurface;
            isoValue        0.5;
            interpolate     true;
Cheers,
Tom
Hi Tom
Thanks for your reply, but I dont quite get what you meaning but using a isosurface of alpha.water=0.5. From my point of view, water surface level is obtained by summing up all the product of alpha.water value and the relevant cells size, the usual VOF way. Hence, the results be bias, if i just put a single threshold for it, as the water level change will no be well presented.
Dont you mind explaining this a bit further. Thanks in advance.
Old   September 22, 2016, 04:29
Tom Fahner
I think that if your cell sizes are small enough there would not be much difference in between both methods. I guess your method would be more accurate, but it would require some coding. Maybe you can compare my method with your probing to see if there is a big difference. I am not sure how your method should be implemented, so I can not help you with that.
Regards,
Tom
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
LTSInterFoam ship flow: Water level rise at start of domain JanZ OpenFOAM Running, Solving & CFD 0 January 21, 2014 05:22
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
