Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
foamToVTK -fields syntax problem
Like Tree2Likes
  • 2 Post By alexeym
Old   September 13, 2016, 11:25
Default foamToVTK -fields syntax problem
KateEisenhower is on a distinguished road
Hello all,
I know it sounds really odd, but I have a problem with the foamToVTK syntax. I try to convert field data (in this case pressure) to the VTK format by typing
foamToVTK -fields p
I get the error message:
--> FOAM FATAL IO ERROR:
incorrect first token, expected <int> or '(', found on line 0 the word 'p'
I cannot find any reason why foamToVTK is expecting an integer here. And yes, I have tried
foamToVTK -fields (p)
too as proposed.
Thanks in advance and best regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   September 14, 2016, 04:51
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Kate,
foamToVTK -fields '(p)'
Works for me. Probably the apostrophes are needed to let OpenFOAM know it is a list of words between the brackets.
Best Regards,
Tom
tomf is offline   Reply With Quote
Old   September 14, 2016, 08:12
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Little addition from foamToVTK.C ($FOAM_APP/utilities/postProcessing/dataConversion/foamToVTK/foamToVTK.C) header:
Usage
    \b foamToVTK [OPTION]
    Options:
      - \par -fields \<fields\>
        Convert selected fields only. For example,
        \verbatim
          -fields "( p T U )"
        \endverbatim
        The quoting is required to avoid shell expansions and to pass the
        information as a single argument.
tomf and Ramsky like this.
alexeym is offline   Reply With Quote
Old   September 16, 2016, 06:29
Thank you both,
Don't you think the error message I posted above could be missunderstood easily and should be changed in the source code?
Best regards,
Kate
Old   September 16, 2016, 06:39
Tom Fahner
I am not certain whether that is easily done. It looks a lot like standard syntax error output and it is probably reused in multiple locations. Maybe the usage or help can be improved somehow. I would suggest you file a bug report with a suggested improved error message here:
http://bugs.openfoam.org/
Tom
Old   September 22, 2016, 06:56
Hello all,
see bug report 0002252.
Best regards,
Kate
problem with velocity and pressure fields will_ca OpenFOAM Running, Solving & CFD 1 March 19, 2016 15:25
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
FoamToVtk syntax for fields tehache OpenFOAM Post-Processing 1 October 10, 2007 11:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
