Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
volFlowRateSurface function - triangulated surface
Like Tree10Likes
  • 4 Post By igor.leo93
  • 5 Post By igor.leo93
  • 1 Post By igor.leo93
Old   July 27, 2016, 22:03
Default volFlowRateSurface function - triangulated surface
igor.leo93's Avatar
Igor Leonardo
igor.leo93 is on a distinguished road
Hello everyone,
I'm trying to use the function object volFlowRateSurface described here:
http://cfd.direct/openfoam/user-guid...#x31-2270006.2
Basically, i want to list the flow rate in some specific areas of my model.
From the description on the link above, i can do that with this function, by using these "specified triangulated surfaces" right?
My question is:
How to make proper use of this function, and how to create these triangulated surfaces?
So far i found out that i need to have this function called from my controlDict file like this:
functions
    #includeFunc volFlowRateSurface;
Then i need to have a file named volFlowRateSurface on my system folder.
The file in the postProcessing/flowRate folder in openFOAM, looks like this:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Web:      www.OpenFOAM.org
     \\/     M anipulation  |
Description
    Calculates volumetric flow rate through a specified triangulated surface
    by interpolating velocity onto the triangles and integrating over the
    surface area.  Triangles need to be small (<= cell size) for an accurate
    result.
triSurface <triSurfaceFile>;
#includeEtc "caseDicts/postProcessing/flowRate/volFlowRateSurface.cfg"
So apparently, it looks for a triSurfaceFile, or something...
I would be happy if someone could give some example of how to use this function, specify these triangulated surfaces, or just point out some tutorial that uses this, so i can have some reference...
Thanks everyone for the help.
I'm new to OpenFOAM, sorry if this is a silly question, and if i'm posting this on the wrong section or something. But i could not find examples of usage of this function around, nor much information on the forum.
Best regards,
Igor L.
igor.leo93 is offline   Reply With Quote
Old   July 29, 2016, 21:06
Default Progress1
igor.leo93's Avatar
Igor Leonardo
So i have made some progress and thought i would come and share in case someone looks for explanations on this function like i did...
So i found out the following:
1- On our volFlowRateSurface file in the system folder, we must declare a regionType, which can be of the following types:
faceZone
patch
sampledSurface
So if we choose patch, it will monitor the flow rate over a specified patch, same goes for faceZone and sampledSurface (Problem now is how exactly to create these facezones and sampledSurfaces on parts of the domain in which we want to monitor the flow rate...)
To choose where exactly we want to monitor we must declare a name, as in facezone name, or sampledsurfaceDict or patch name.
After declaring these, and running the simulation, a volFlowRateSurface folder will be created in the postProcessing folder, there will be a list of the flowrate on each timeStep.
Here is an example of a volFlowRateSurface file, this uses a sampledSurfaceDict plane, to monitor the flowrate:
   \\    /   O peration     |
     \\/     M anipulation  |
Description
    result.
regionType    sampleadSurface;
name        sampleSurfaceDict;
sampledSurfaceDict
            type            plane;
            basePoint       (0.9 0 0);
            normalVector    (1 0 0);
            interpolate       false;
The output for this, looks like something like this:
# Region type : sampledSurface sampleSurfaceDict
#   Faces  : 4000
#   Area   : 3.138364e-02
#        Time    areaNormalIntegrate(U)
            1    (1.686720e+00 0.000000e+00 0.000000e+00)
            2    (1.832342e+00 0.000000e+00 0.000000e+00)
            3    (1.859946e+00 0.000000e+00 0.000000e+00)
            4    (1.735812e+00 0.000000e+00 0.000000e+00)
            5    (1.672361e+00 0.000000e+00 0.000000e+00)
            6    (1.693844e+00 0.000000e+00 0.000000e+00)
            7    (1.701347e+00 0.000000e+00 0.000000e+00)
            8    (1.712168e+00 0.000000e+00 0.000000e+00)
            9    (1.720110e+00 0.000000e+00 0.000000e+00)
           10    (1.724886e+00 0.000000e+00 0.000000e+00)
           11    (1.728143e+00 0.000000e+00 0.000000e+00)
           12    (1.730597e+00 0.000000e+00 0.000000e+00)
           13    (1.731944e+00 0.000000e+00 0.000000e+00)
           14    (1.730392e+00 0.000000e+00 0.000000e+00)
           15    (1.724115e+00 0.000000e+00 0.000000e+00)
           16    (1.720754e+00 0.000000e+00 0.000000e+00)
           17    (1.719241e+00 0.000000e+00 0.000000e+00)
I will keep investigating this, and posting my progress, i hope this helps someone.
Best regards,
Igor L.
Old   August 16, 2016, 21:24
Smile Solution
igor.leo93's Avatar
Igor Leonardo
Ok so i found out how to calculate the flow rate over a specified plane.
For this task, one can use sampledSurfaces, which will be created from setting a plane with 3 points -> 1-Origin, 2-3- Vertexes (See attachment)
As simple as that, we can create many surfaces with any orientation and monitor the flow rate. The results will be listed for all the surfaces on the postProcessing dict as i mentioned before.
Just remember to "call" the functions on the control dict.
I leave here a example of a volFlowRateSurface for anyone who might need.
By the way, OpenFOAM 4, being used.
   \\    /   O peration     |
     \\/     M anipulation  |
Description
    result.
regionType    sampledSurface;
sampledSurfaceDict
                type cuttingPlane;
                planeType           embeddedPoints;
                embeddedPointsDict
                        point1    (0.9 -0.2 -0.2);
                        point2    (0.9 0.2 -0.2);
            point3    (0.9 0.2 0.2);
                source cells; // sample cells or boundaryFaces
                interpolate false;
I hope this helps others, it took me about a week to figure all this out lol.
Best regards for everyone.
Igor Carvalho.
File Type: png Screenshot from 2016-08-16 21:22:18.png (11.0 KB, 82 views)
Old   August 17, 2016, 03:16
akidess's Avatar
Anton Kidess
Are you sure the plane will be bounded using embeddedPoints? Furthermore, when using a sampling plane perhaps you should use interpolated values.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   August 17, 2016, 09:36
Default interpolattion
igor.leo93's Avatar
Igor Leonardo
Hello akidess,
I used this exactly setup for my model, which was a simple tube, and the flow rate i obtained was indeed correct.
I think this interpolation refers to where the plane crosses and the mesh (See attached image).
I believe if interpolation is true, it is going to interpolate the value for the flow rate between the cells, regarding the plane location.
If interpolation is false, i believe it is going to just take the nearest cell center's value.
I decided to use false interpolation because my mesh was perfect hexaedral and all, so assuming cell center values would be better, because openFOAM calculates for cell centers.
But i also think if i had choose to interpolate, values shouldn't change much, maybe i will try it later to confirm.
Since my mesh was hex and good, i think it is ok, but things may be diferent for tet mesh, what do you think? Maybe for tet interpolation really should be necessary.
Well at least this is what i think this is... correct me if i'm wrong please.
Thanks for looking at this thread,
Best regards,
Igor Carvalho
File Type: png Screenshot from 2016-08-17 09:33:05.png (25.8 KB, 102 views)
LeeRuns likes this.
Old   March 16, 2017, 09:00
Gary is on a distinguished road
Very helpful, many thanks. Just to confirm with you the three points in embededPointsDict are on the tube.
Last edited by Gary; March 16, 2017 at 09:29. Reason: forgot to ask one more question
Gary is offline   Reply With Quote
Old   June 9, 2017, 11:05
M. C.
student666 is on a distinguished road
Just to understand,does it interpolate U mag? I see a vector notation on your .dat file
So how have you checked your flowrat?
Have you tested more this postProcessing utility?
Thanks
Michele
student666 is offline   Reply With Quote
Old   August 9, 2017, 10:26
Default Surface report in single file
Bruno Lebon
blebon is on a distinguished road
#   Faces  : 4000
How did you get the output in a single file? In my case, the reports are in separate files, one for each time step. I can aggregate everything using a Python script, but this is annoying (especially when there are many time steps).
blebon is offline   Reply With Quote
Old   February 1, 2018, 12:30
Default checking the results
Ali Mohammadi
cfd lover is on a distinguished road
Thanks
Michele
I checked the results of this utility with the result of flow rate in paraview and they were the same.
cfd lover is offline   Reply With Quote
Old   May 26, 2018, 12:34
Ameya
ameya2310 is on a distinguished road
Hello Everyone,
I wish to calculate volumetric flow rates out of my control volume (which is rectangular shaped domain, with multiple circular outlets on one face) As the outlets are more that 100 in number I have included them into one zone called outlet.
Now i wish to calculate flow rates through each individual outlet.
I was wondering if there is a way to define sampledSurface (like the way a plane is defined in above posts), the centers of the circular outlets,Diameters are known).
If anyone can refer to similar tutorial, sample file, that would be great. I basically want to know the correct syntax for defining a circular sample surface at a particular location in my geometry.
Thanks in advance.
ameya2310 is offline   Reply With Quote
Old   May 27, 2018, 04:00
Default flow rate in multiple outlets
  #11
Ali Mohammadi
Hi ameya
I can suggest you a simple way which i have used it my self. my domain had 16 outlets which i named from outlet 1 to outlet 16. I wrote a for loop code and used the flow rate patch command to calculate the flow rate from outlet 1 to outlet 16.
best regards
Ali
Old   May 30, 2018, 13:17
Ameya
Hello, Thanks for the reply Ali,
Your suggestions sounds great, I will try writing the code.
Actually my problem is that, I have more that 100 outlets and defining 100 outlets seperately is tedious, so I was wondering if there is a way around that.
Anyways Thanks a lot.
Old   March 15, 2019, 09:43
Default Using .stl file
  #13
Matthieu ZUBIALDE
mzubiald is on a distinguished road
Hello all,
I am also trying to calculate the flow rate over a specified plane. But in my case, this specified plane is defined with a .stl file.
I used the following code in the volFlowRateSurface file.
My question is: how can I define multiples surfaces (corresponding to multiples .stl files) in this code to calculate flow rates through these surfaces ?
   \\    /   O peration     |
     \\/     M anipulation  |
Description
    result.
name               mySurface;
sampledSurfaceDict
    type            sampledTriSurfaceMesh;
    surface         mySurface.stl;
    source          cells;
    interpolate     true;
mzubiald is offline   Reply With Quote
functionobjects, triangulated surfaces, volflowratesurface
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
