Plotting Velocity Probe File with gnuplot |
July 19, 2016, 06:06 |
Charles K.
Rep Power: 10 |
Hello everyone,
i used the probe function to record the velocity components at different probe locations over a few iterations. The resulting file looks like this: Code:
# x -0.131405 -0.0651938 -0.076365 -0.038918 # y 0.217974 0.168556 0.157857 0.140393 # z 0 0 0 0 # Time 30001 (-66.1109 -119.8326 25.50102) (4.886721 -3.84177 61.53438) (-3.194476 1.791498 61.15488) (-0.9615131 -0.001325707 63.65683) 30002 (-66.10999 -119.8314 25.50123) (4.886713 -3.841753 61.53451) (-3.194472 1.791497 61.15505) (-0.961551 -0.001290854 63.65706) 30003 (-66.10908 -119.8303 25.50143) (4.886701 -3.841732 61.53466) (-3.194465 1.791497 61.15522) (-0.9615866 -0.001260145 63.65731) 30004 (-66.10817 -119.8291 25.50164) (4.886687 -3.841709 61.53481) (-3.194457 1.791498 61.15539) (-0.9616209 -0.001232042 63.65756) 30005 (-66.10726 -119.828 25.50185) (4.886672 -3.841684 61.53496) (-3.19445 1.791498 61.15557) (-0.9616544 -0.001205453 63.65782) 30006 (-66.10634 -119.8268 25.50205) (4.886656 -3.841658 61.53513) (-3.194443 1.791498 61.15576) (-0.9616873 -0.001179835 63.65808) 30007 (-66.10543 -119.8257 25.50226) (4.88664 -3.841632 61.53529) (-3.194437 1.791499 61.15594) (-0.9617197 -0.001154599 63.65833) 30008 (-66.10452 -119.8245 25.50246) (4.886624 -3.841606 61.53546) (-3.194432 1.7915 61.15613) (-0.9617518 -0.001129642 63.65859) 30009 (-66.10361 -119.8234 25.50266) (4.886609 -3.841581 61.53563) (-3.194428 1.7915 61.15632) (-0.9617837 -0.00110496 63.65884) 30010 (-66.1027 -119.8223 25.50287) (4.886595 -3.841557 61.5358) (-3.194424 1.791501 61.15652) (-0.9618155 -0.001080633 63.65909) 30011 (-66.10178 -119.8211 25.50307) (4.886581 -3.841533 61.53597) (-3.194421 1.791502 61.15671) (-0.9618472 -0.001056746 63.65934) 30012 (-66.10087 -119.82 25.50328) (4.886568 -3.841511 61.53614) (-3.194418 1.791502 61.15691) (-0.961879 -0.001033452 63.6596) 30013 (-66.09996 -119.8188 25.50348) (4.886556 -3.841489 61.53631) (-3.194414 1.791502 61.15711) (-0.9619109 -0.00101076 63.65985) 30014 (-66.09904 -119.8177 25.50369) (4.886544 -3.841468 61.53647) (-3.19441 1.791502 61.1573) (-0.9619431 -0.0009887137 63.6601) 30015 (-66.09813 -119.8165 25.5039) (4.886531 -3.841447 61.53664) (-3.194406 1.791501 61.1575) (-0.9619756 -0.0009672426 63.66035) 30016 (-66.09721 -119.8154 25.5041) (4.886519 -3.841427 61.5368) (-3.194401 1.791499 61.1577) (-0.9620084 -0.0009462494 63.66061) 30017 (-66.09629 -119.8142 25.50431) (4.886506 -3.841407 61.53696) (-3.194396 1.791498 61.15789) (-0.9620416 -0.0009255863 63.66086) 30018 (-66.09537 -119.8131 25.50452) (4.886494 -3.841387 61.53712) (-3.19439 1.791495 61.15808) (-0.962075 -0.0009050651 63.66112) 30019 (-66.09446 -119.8119 25.50472) (4.88648 -3.841367 61.53728) (-3.194384 1.791493 61.15828) (-0.9621086 -0.0008844772 63.66137) 30020 (-66.09354 -119.8108 25.50493) (4.886467 -3.841347 61.53744) (-3.194377 1.791491 61.15847) (-0.9621423 -0.0008636631 63.66162) My current Gnuplotscript (which is not working....) looks like this : Code:
# Gnuplot script file for plotting data from file "probes.dat" set title "Convergence process" set xlabel "Iterations" set ylabel "Velocity Ux Uy Uz at selected points" plot "postProcessing/probes/30000/U" using 1:2 title 'Probe U1' # "postProcessing/probes/30000/U" using 1:3 '(%lf %lf %lf)' title 'Probe U2', \ reread Cheers! Charles |
July 20, 2016, 07:43 |
hannes
Rep Power: 13 |
Hi Charles,
perhaps it helps if you first delete the brackets? Code:
plot "< cat postProcessing/probes/30000/U | tr -d '()'" using 1:2 title 'ProbeU1' regards Hannes |
July 20, 2016, 09:00 |
Rep Power: 10 |
I followed this tutorial yesterday to do the exact same job (page 249 of the pdf file). I ended up with the following sh script. Read the comments :
#! /bin/sh #deleting all parenthesis everywhere in the file, using a temporary "tmp" file that is deleted just at next line : cat U | tr -d "()" > tmp mv tmp U #deleting the 4 first lines of my probe file "U", using a temporary file caled "U.bak" that is erased just at next line : sed -i.bak "1,4d" U rm U.bak gnuplot <<EOF reset set terminal png set output "sonde_vitesse_centrale.png" set title "Sonde de vitesse au centre cellule" set xlabel 'Temps (s)' set ylabel 'V (m/s)' plot 'U' u 1:3 w l EOF |
July 21, 2016, 08:12 |
Charles K.
Rep Power: 10 |
Thanks Romain and Hannes for your replies,
actually, I found out how to solve my issue. The solution is quite straight forward and there is no need to change the format or structure of the Vector Data (Ux Uy Uz) in the probe files. I used the following syntax to use the specific vector components in each column: Code:
1:(($2**2)+($3**2)+($4**2))**(0.5) " %lf (%*lf %*lf %*lf) (%lf %lf %lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf)" with "%lf (%*lf %*lf %*lf) (%lf %lf %lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf)" it is possible to tell gnuplot which values of each vector in each column it should use or not, %*lf meaning it should ignore the value. I am using 4 probes, that's why I need several brackets. My final script looks like this: Code:
# Gnuplot script file for plotting data from file "probes.dat" set title "Convergence process" set xlabel "Iterations" set ylabel "Velocity Ux Uy Uz at selected points" plot 'run/alpha90_s24/older/800K_NoSlip/rhoSimplecFoam/postProcessing/probes/30000/U' u 1:(($2**2)+($3**2)+($4**2))**(0.5) " %lf (%*lf %*lf %*lf) (%lf %lf %lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf)" w l title 'Probe U1', \ 'run/alpha90_s24/older/800K_NoSlip/rhoSimplecFoam/postProcessing/probes/30000/U' u 1:(($2**2)+($3**2)+($4**2))**(0.5) " %lf (%*lf %*lf %*lf) (%*lf %*lf %*lf) (%lf %lf %lf) (%*lf %*lf %*lf)" w l title 'Probe U2', \ '/run/alpha90_s24/older/800K_NoSlip/rhoSimplecFoam/postProcessing/probes/30000/U' u 1:(($2**2)+($3**2)+($4**2))**(0.5) " %lf (%*lf %*lf %*lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf) (%lf %lf %lf)" w l title 'Probe U3' reread Cheers |
November 27, 2017, 06:05 |
Luca Montagliani
Rep Power: 9 |
resolved in this way to plot the components and the module
set title "U_probe1" set ylabel 'U' set yrange [ ] set xlabel 'time [s]' plot 'postProcessing/probes/0/U' using 1($2**2)+($3**2)+($4**2))**(0.5) "%lf (%lf %lf %lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf)" w l title 'magU' lt rgb "blue", \ 'postProcessing/probes/0/U' using "%lf (%lf %*lf %*lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf)" w l lt rgb "red" title 'Ux',\ 'postProcessing/probes/0/U' using "%lf (%*lf %lf %*lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf) (%*lf %*lf %*lf)" w l lt rgb "green" title "Uy" pause 1 Thanks Last edited by luca_mon; November 27, 2017 at 18:16. |
December 20, 2017, 07:21 |
Help
#6 | |
Guilherme
Rep Power: 10 |
If you have tree points...
September 18, 2018, 12:01 |
Plotting the Velocity with gnuplot
Johannes
Rep Power: 8 |
Dear Foamers,
in controlDict I defined functions to get probes for the velocity-field on different points. The restult is this: # Probe 11 (1.5 1.5 1.5) # Probe 0 1 2 3 4 5 6 7 8 9 10 11 # Time 0.0002 (1.02472 -0.00370842 -0.00702691) (0.298415 0.0239647 0.0236811) (0.0702029 0.0333547 0.033016) (0.184431 -0.026987 -0.0271025) (0.00195649 -0.0108012 -0.0108247) (1.62031 -0.02633 -0.0267462) (1.62019 0.0265368 0.0265032) (0.965851 -0.359919 0.0538214) (0.966087 0.0540248 -0.360035) (1.04432 -0.0152247 -0.0153117) (1.04432 -0.0152247 -0.0153117) (1.04432 -0.0152247 -0.0153117) 0.0002 (1.02472 -0.00370842 -0.00702691) (0.298415 0.0239647 0.0236811) (0.0702029 0.0333547 0.033016) (0.184431 -0.026987 -0.0271025) (0.00195649 -0.0108012 -0.0108247) (1.62031 -0.02633 -0.0267462) (1.62019 0.0265368 0.0265032) (0.965851 -0.359919 0.0538214) (0.966087 0.0540248 -0.360035) (1.04432 -0.0152247 -0.0153117) (1.04432 -0.0152247 -0.0153117) (1.04432 -0.0152247 -0.0153117) (It's similar to the first post from McCharles!) So I get vectors with 3 entries for every Point. How can I plot the x-velocity entry over the time with gnuplot? Thanks in advice for your help |
October 22, 2018, 17:22 |
Tony Jia
Hi Mexes,
Have you found a solution to this issue? Thanks! |
October 22, 2018, 17:51 |
#9 |
Johannes
Rep Power: 8 |
Hi code7760!
I found a solution. It worked when I load the textfiles in Microsoft Excel. Afterwards go with this file back to linux / OpenFoam For the import in Excel you have to seperat all columns (it's easy. Just try a few different settings). With this file you can plot arbitrary diagrams. Unfortunately with libre office it didn't work, cause in every field in the beginning there was a --> ' <-- and gnuplot couldn't handle this |
November 18, 2019, 08:44 |
#10 |
Harish Selvam
It's working perfectly
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
