Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
probe/sample pressure on moving boundary
Like Tree21Likes
  • 1 Post By mo_na
  • 20 Post By mo_na
Old   July 14, 2016, 06:26
Post probe/sample pressure on moving boundary
mo_na's Avatar
Mona
mo_na is on a distinguished road
Hi all,
I am simulating a pitching floater in a wave flume with ihFoam and a moving mesh. To validate my simulation I want to compare my results with pressure measurements, that were taken in experiments.
I got the positions of the pressure sensors on the body. The problem is that the body will move during the simulation, so these locations won't stay the same in reference to the global coordinate system..
Does anyone have an idea how to get the pressure (in several locations) on the moving body either using the probe or the sample function?
Cheers,
Mona
Mehdi Rami likes this.
mo_na is offline   Reply With Quote
Old   July 14, 2016, 16:58
João Ferreira
jmdf is on a distinguished road
I don't have that many experience with sampling, however I have a suggestion.
If you create a cellZone, faceSet, or something like that, using topoSet and then probe the zone you created instead of a point, could it work?
I suppose that when you create a cellZone it "follows" when the mesh moves. Not sure if this works but let me know, despite it does or not.
jmdf is offline   Reply With Quote
Old   July 15, 2016, 06:00
mo_na's Avatar
Mona
Hi João,
thanks for your answer! I will definitely try that and let you know if it works!
Old   August 9, 2016, 05:25
Default solved
mo_na's Avatar
Mona
Hey everyone,
if you are using a dynamic mesh, this is actually quite easy.
You just need to use
fixedLocations     false;
and the probe will move with the mesh, so it will stay in the same place in relation to the body.
I now have this in my controlDict and it works fine:
probes
// Where to load it from
functionObjectLibs ( "libsampling.so" );
type        probes;
// Name of the directory for probe data
name        probes;
// Fields to be probed
fields (
        p
probeLocations
(0.490739 0 -0.29552)
(0.418913 0 -0.30492)
(0.29715 0 -0.198471)
(0.272609 0 -0.136329)
(0.42495 0 -0.31246)
(0.489783 0 -0.297302)
(0.335867 0 -0.23989)
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 17:36
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
