forcecoeffs with icoFoam... No postProcessing directory |
February 5, 2016, 16:49 |
Murtaza Abbas
Rep Power: 10 |
Hi all,
I had tried to revive an old thread but I thought it may be best starting a new one. I'm trying to solve the flow around a cylinder problem and I have modified the ControlDict with the forces and forcecoeffs function objects, so I can output the drag and lift coefficients. When I run the solver, I get the following error: --> FOAM FATAL IO ERROR: wrong token type - expected word, found on line 18 the punctuation token '[' file: /home/murtaza/OpenFOAM/murtaza-3.0.1/run/courseWork/part1/constant/transportProperties.nu at line 18. From function operator>>(Istream&, word&) in file primitives/strings/word/wordIO.C at line 74. The model still runs if I undo the changes to the ControlDict, so I'm sure it has nothing to do with the transportProperties. Any help would be apprieciated Thanks in advance. |
February 9, 2016, 08:49 |
Murtaza Abbas
Rep Power: 10 |
SOLVED: In the transport properties file, the definition of nu needed to looked something like:
"nu nu[0 2 -1 0 0 0 0]" I had missed out the second nu :P |
forcecoeffs, forces, functionobject |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
OpenFoam install script Error during paraFoam installation | SePe | OpenFOAM Installation | 10 | June 19, 2010 15:15 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
