Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Error in implementing probe-post processing utility
Like Tree4Likes
  • 1 Post By baran_foam
  • 2 Post By fs82
  • 1 Post By wyldckat
Old   June 15, 2015, 06:41
Default Error in implementing probe-post processing utility
baran
baran_foam is on a distinguished road
Greeting all!!!
I want to implement "probe" to get temperature variation with change in time in chtMultiRegionFoam tutorial (multiRegionHeater) of OpenFOAM-2.4.
So as per incompressible/pisoFoam/pitzDaily/system/controlDict file i have made following changes.. in my case..
functions
heater
type probes;
functionObjectLibs ("libsampling.so");
enabled true;
outputControl timeStep;
outputInterval 1;
fields
T
probeLocations
(0 0 0)
But some how it is showing following kind of error....
Selecting radiationModel opaqueSolid
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel none
Selecting sootModel none
Adding fvOptions
No finite volume options present
Region: bottomWater Courant Number mean: 0.00017208904 max: 0.00082499996
Region: topAir Courant Number mean: 0.015 max: 0.015000002
Region: heater Diffusion Number mean: 5.9582983e-08 max: 7.1134787e-08
Region: leftSolid Diffusion Number mean: 5.9429061e-08 max: 7.1134787e-08
Region: rightSolid Diffusion Number mean: 5.9429061e-08 max: 7.1134787e-08
--> FOAM FATAL ERROR:
request for objectRegistry region0 from objectRegistry probe_check failed
available objects of type objectRegistry are
5
rightSolid
bottomWater
heater
topAir
leftSolid
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/bg8743/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/bg8743/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/bg8743/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam:bjectRegistry const& Foam:bjectRegistry::lookupObject<Foam:bjectReg istry>(Foam::word const&) const in "/home/bg8743/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libsampling.so"
#3 Foam::OutputFilterFunctionObject<Foam:robes>::al locateFilter() in "/home/bg8743/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libsampling.so"
#4 Foam::OutputFilterFunctionObject<Foam:robes>::st art() in "/home/bg8743/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libsampling.so"
#5 Foam::functionObjectList::read() in "/home/bg8743/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::functionObjectList::adjustTimeStep() in "/home/bg8743/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#7 ? in "/home/bg8743/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/chtMultiRegionFoam"
#8 __libc_start_main in "/lib64/libc.so.6"
#9 ? in "/home/bg8743/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/chtMultiRegionFoam"
Aborted
Can you kindly specify what should I specify in this control Dict file to use this probe properly??
Thanks & regards,
baran
Kummi likes this.
baran_foam is offline   Reply With Quote
Old   June 16, 2015, 02:59
Dr. Fabian Schlegel
fs82 is on a distinguished road
This should be some mesh issue or something with your probe location. OpenFoam tells your where the problem is:
5
rightSolid
bottomWater
heater
topAir
leftSolid
You should check if your probe locations is within the specified region and if you have some misspellings in your dictionary.
Best regards
Fabian
fs82 is offline   Reply With Quote
Old   June 16, 2015, 05:15
baran
Greeting all!!!
@fabian...thanks for your reply...
I have cross checks the controlDict file...
1. There is no spelling error as per tutorial case...
2. I have taken different points from polyMesh directory to check it. But same error is coming...
Regards,
Baran
Old   June 16, 2015, 06:24
Dr. Fabian Schlegel
The code for your probes seems to be outdated (I use OF 2.4.x). Have a look, e.g., at multiphase/interDyMFoam/ras/sloshingTank2D/system/controlDict how probes are used.
Old   June 16, 2015, 07:39
baran
I am also using openFoam-2.4.
I have taken the command from
tutorial/incompressible/pisoFoam/pitzDaily/system/controlDict
It is also showing the same error... according to your suggestion
Mostly some other issue is there which I am missing...
Regards,
Baran
Old   June 16, 2015, 08:27
Dr. Fabian Schlegel
I checked it and I am able to reproduce your error for the multiRegionHeater tutorial case. However, I do not have a clue at the moment, it seems to be related to the mesh and the various regions. To register the probe OF tries to access region0, which is not present. I think you have to dive into the code to fix this issue.
Best regards
Fabian
Old   June 16, 2015, 11:14
Dr. Fabian Schlegel
I found your problem. You have to add the region in your probe function, as I have done below:
    probes
        type            probes;
        enabled         true;
        outputInterval  1;
	region heater;
        fields
            p
        probeLocations
            ( 0.0254 0.0253 0 )
            ( 0.0508 0.0253 0 )
            ( 0.0762 0.0253 0 )
            ( 0.1016 0.0253 0 )
            ( 0.127 0.0253 0 )
            ( 0.1524 0.0253 0 )
            ( 0.1778 0.0253 0 )
Best regards
Fabian
Kummi and geralt1997 like this.
Old   June 17, 2015, 03:18
baran
Greeting all!!
@Fabian thanks a lot for your reply..it works in this way.....
Some observation I have seen as follows...
1. If we enter different region for probe location then it will give some garbage value....but not going to show any error...
But i have another doubt....If we want to probe in two different fields then how to do this using probe??
I am trying in this way... but it is only reading last entry region.that means for this case it only log data for topAir....
    probes
        type            probes;
        enabled         true;
        outputControl   outputTime;  //timeStep;
        outputInterval  1;
    region        heater;
    probeLocations
      (-0.013333333 0 -0.05)
      (-0.0066666667 0 -0.05)
      (0 0 -0.05)
      (0.0066666667 0 -0.05)
      (0.013333333 0 -0.05)
      (-0.013333333 0.008 -0.05)
      (-0.0066666667 0.008 -0.05)
      (0 0.008 -0.05)
    fields
    T
      probes
        type            probes;
    enabled        true;
    outputInterval  1;
    region       topAir;
        probeLocations
(-0.1 0.008 -0.05)
(-0.093333333 0.008 -0.05)
(-0.086666667 0.008 -0.05)
(-0.08 0.008 -0.05)
(-0.073333333 0.008 -0.05)
(-0.066666667 0.008 -0.05)
(-0.06 0.008 -0.05)
(-0.053333333 0.008 -0.05)
(-0.046666667 0.008 -0.05)
(-0.04 0.008 -0.05)
(-0.033333333 0.008 -0.05)
(-0.026666667 0.008 -0.05)
(-0.02 0.008 -0.05)
        fields
            T
    probes
        type            probes;
        enabled         true;
        outputInterval  1;
    region        heater;
    probeLocations
      (0 0 -0.05)
      (0 0.008 -0.05)
   &nbsp;);
    region       topAir;
      probeLocations
(-0.1 0.008 -0.05)
(-0.08 0.008 -0.05)
(-0.06 0.008 -0.05)
(-0.04 0.008 -0.05)
(-0.02 0.008 -0.05)
        fields
            T
Can anyone have any idea for this...??
Regards,
Baran
Last edited by wyldckat; June 17, 2015 at 16:27. Reason: Changed [QUOTE][/QUOTE] to [CODE][/CODE]
Old   June 17, 2015, 16:29
Retired Super Moderator
Bruno Santos
Quick answer: You are using the same name for each named block:
probes
probes
When you should use different names, for example:
heaterProbes
topAirProbes
nimasam likes this.
Old   June 18, 2015, 06:30
baran
Greeting All!!!
@bruno...thanks a lot for your reply.....
Yea I have done some mistakes here....right now it is working properly...
Regards,
Baran
post processing for CEL expressions Niru CFX 0 May 10, 2013 14:13
Calculation of R using post processing utility choudhury OpenFOAM 3 March 24, 2013 12:59
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 07:21
CFD post processing techniques & streamlining klk Main CFD Forum 0 October 19, 2010 08:37
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 21:51
