Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Post processing in CFD Post or Fluent.
Like Tree1Likes
  • 1 Post By Blobs
Old   April 7, 2015, 11:12
Default Post processing in CFD Post or Fluent.
Joris van der Ploeg
Blobs is on a distinguished road
Hi all,
For the thesis of my bachelor study Mechanical Engineering (University of Applied sciences) I am assessing the possibilities of using OpenFOAM in stead of Fluent. To effectively compare results (contour plots, velocity fields, pressure fields etc.) I would prefer post-processing in CFD post or Fluent so that the color scheme and image lay-out are identical.
I have (as far as I can tell) successfully used the foamMeshToFluent and foamDataToFluent command. More precisely I made my mesh in Ansys Mesh Modeler and saved it in ASCII format and successfully imported it to OpenFOAM (with the fluentMeshToFoam utility). This is what I have done step by step:
-Model mesh in Ansys mesh modeller, save in ASCII format.
-Import mesh in OpenFOAM (fluentMeshToFoam utility).
-Performed a seemingly successful K-Epsilon RNG simulation within the HelyxOS environment.
-Checked results in paraView (Looks allright).
Now I want to post-process my results on Win7 with Ansys CFD Post or Fluent (since that utility is available). Here is what I have tried so far:
-Export the .dat file with foamDataToFluent and exported the mesh with foamMeshToFluent to get the .msh mesh file.
Opening the .msh file in Fluent(Win7, different machine) works, I can see the mesh and it looks fine. All faces (inlet, outlet, symmetry) are defined and I set Fluent to K-Epsilon RNG so it has the correct variables available. Now when I try to import the .dat file Fluent gives the follow error:
''Warning: case and data files are inconsistent zone 10[xxxx,xxxx] data [xxxx,xxxxx]"
This error is repeated for all zones in the mesh.
Hope you guys can help! Thanks in Advance,
Joris
BTW: I'm not using cellzones, there is only one mesh region.
Blobs is offline   Reply With Quote
Old   April 13, 2015, 06:35
Default Problem found
Joris van der Ploeg
Hi Guys,
The problem seemed to be that I was running Fluent in parallel. I started a version of Fluent in serial and then it loaded in the results.
Right now I'm not actually post-processing in Fluent yet. I'll give updates and how it progresses.
CFD-engineer likes this.
Old   June 26, 2016, 08:23
masoudsh is on a distinguished road
Hi Joris
I have your problem too,do you solve it?
thanks
masoudsh is offline   Reply With Quote
cfd post, fluent, foamdatatofluent, post processing
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 01:30
Need help in post processing of Slurry flow in Ansys Fluent jatin1990 FLUENT 0 November 5, 2014 15:11
Parallel process & CFD POST jypark FLUENT 2 August 15, 2013 00:49
Different in fluent result after post processing Niles FLUENT 0 August 14, 2008 05:28
Fluent Post Processing Kulasekharan N FLUENT 0 February 18, 2008 03:54
