Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Pressure and density values to compute forces
Like Tree2Likes
  • 2 Post By tomf
Old   March 5, 2015, 12:26
Default Pressure and density values to compute forces
daniel fernex
fernexda is on a distinguished road
Dear all,
I'm currently computing forces around a body, but the forces are surprisingly high, therefore I'm trying to review every aspects to check if those values are realistic. Two things are still unclear :
1.Pressure
: I was wondering if the boundary and initial values of the pressure matter. What I did until now is apply a zeroGradient on the Inlet, and p=0 on the outlet. But since the simulation takes place at atmospheric conditions, shouldn't I impose p=p_atm on the outlet ? Would that make any difference ? Would it affect either the viscous forces or the pressure forces ? In what manner ?
2.Density
: I don't know the influence of the density on the resulting forces (viscous and pressure forces). As far as I know, the only place where I can choose the density is in the forces dictionary where I have the two following lines :
rhoName            rhoInf;
rhoInf                1;
Should I change this value to make it equal to my fluide density (which is equal to 1.225 kg/m³) to get the real forces ?
And does this value have anything to do with the input values (boundary conditions for U, p, viscosity) ?
Thanks a lot for any answer !
Daniel
fernexda is offline   Reply With Quote
Old   March 6, 2015, 04:35
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Daniel,
I guess you use one of the incompressible solvers from the description you gave. In that case you have to specify the actual density of the fluid in the forces subDict. In transportProperties you specify the kinematic viscosity that belongs to your fluid. They are not related in the code, but they are of course in reality, so you have to make sure they correspond to the same fluid independently. In an incompressible solver the actual pressure level is irrelevant for the solution, however you have to specify an arbitrary constant to make the solution the only solution. If you specify the atmospheric pressure (instead of 0) at the outlet, the only change is that all cells have a pressure that is exactly 1 atm higher. The difference over the body would still be the same.
So to answer your questions:
1. No, only a uniform higher level, no, no
2. yes, not directly: you have to set them correctly
Regards,
Tom
fernexda and elmo555 like this.
tomf is offline   Reply With Quote
Old   March 6, 2015, 04:39
daniel fernex
Hi Tom,
I forgot to specify I'm running incompressible simulations (with pimpleFoam).
You're answer is perfectly clear and it's exactly what I was looking for !
Thank you very much !
Daniel
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
Warning 097- AB Siemens 6 November 15, 2004 05:41
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
