Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Trouble with sampleDict syntax for OpenFOAM 2.3.1
Like Tree1Likes
  • 1 Post By alexeym
Old   January 31, 2015, 14:53
Unhappy Trouble with sampleDict syntax for OpenFOAM 2.3.1
Rowan Bado
rawdoggity is on a distinguished road
Hey all, new OpenFOAM user here. Using v2.3.1, I'm trying to run a lid-driven cavity flow simulation on a DEM of a mountain range converted into STL geometry as described by:
http://www4.ncsu.edu/~ejhardi2/OF_GRASS_Geom.pdf
So far, everything works beautifully and I have no trouble refining the geometry with blockMesh > snappyHexMesh -overwrite and calculating surface shear stress with icoFoam > wallShearStress -latestTime. However, I am having trouble sampling the results in 'wallShearStress'. I'm using a sample dictionary copied verbatim from the example given above that looks like this:
setFormat xmgr;
surfaceFormat raw;
interpolationScheme cellPoint;
fields
wallShearStress
sets
surfaces
wall
type patch;
patchName terrain_terrain;
However, when I run "sample" I receive the following error:
keyword patches is undefined in dictionary "/Users/ecr/browan/OpenFOAM/browan-2.3.1/run/tutorials/incompressible/icoFoam/mteveresttutorial/system/sampleDict.surfaces"
It's clear to me that the tutorial is based off an older version of OpenFOAM and that the sampleDict syntax has changed since moving to 2.3.1, but I can't find an example of the proper syntax (including 'patches' and 'type' within the 'surfaces' dictionary) anywhere. I'm sure this is a simple fix... can anybody tell me how I should be writing this? Perhaps post an example to use for reference?
rawdoggity is offline   Reply With Quote
Old   February 1, 2015, 06:24
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Usually examples of dictionaries are placed along the sources of the utilities, in case of sample, you can find the dictionary in $FOAM_APP/applications/utilities/postProcessing/sampling/sample folder.
Here's an excerpt from the file:
    walls_constant
        type            patch;
        patches         ( ".*Wall.*" );
        // Optional: whether to leave as faces (=default) or triangulate
        // triangulate     false;
    walls_interpolated
        type            patch;
        interpolate     true;
apu111 likes this.
alexeym is offline   Reply With Quote
sampledict, syntax error
UDF syntax error Ratel Fluent UDF and Scheme Programming 4 May 23, 2015 06:15
what is syntax error : missing ')' before ';' aleisia Fluent UDF and Scheme Programming 8 March 10, 2015 16:42
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
