Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
SimpleFoam with Komega turbulence model?
Like Tree1Likes
  • 1 Post By aalzoubi06
Old   December 8, 2014, 00:49
Default SimpleFoam with Komega turbulence model?
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hi All,
I have been working on the simpleFoam with the example airfoil2D. I implemented the files that are relevant to kOmega turbulence model into the zero file. I did all required steps in order to get it to work. The case file ran correctly and it gave me similar results to Spalart Allmaras. However, I feel that the drag and left values are a little bit different than the theoretical results. For instance, for angle of attack 2 degree, the CFD lift coefficient result was 0.652044. On the other hand, the theoretical result for the same angle of attack was 0.4865, which gives an error for about 25.4%. I feel unsatisfied from these results. Can someone explain why am I getting these results? I would be greatly thankful
Kind regards,
tareqkh is offline   Reply With Quote
Old   December 8, 2014, 20:13
Ahmad Al-Zoubi
aalzoubi06 is on a distinguished road
In general:
- Did you make grid independence study?
- What about the boundary conditions?
- Did you reach converged solution?...
If you are aware about the above facts, then you can blame the 2 equation turbulence model for any inaccurate results.
All the best and success.
tareqkh likes this.
aalzoubi06 is offline   Reply With Quote
Old   December 8, 2014, 20:31
tareqkh's Avatar
CFD
I will provide a picture shows the monitor convergence. However, I don't know a lot about making a grid independence. Could you please explain what do you mean about it.
Old   December 8, 2014, 20:40
tareqkh's Avatar
CFD
As you are aware, from turbulence equations we have the following:
k=(3/2)(Uinf*I)^2
Where Uinf=26 m/s, and I=0.05 for the external flow.
Therefore, k= 2.535.
Similarly, omega= (0.09*k)/(beta*kinematic viscosity)
kinematic viscosity= 10^-6 m2/s, beta =0.1-1 (I chose 0.5)
Omega= 182.52.
Am I right?
Regards,
Old   December 8, 2014, 21:20
tareqkh's Avatar
CFD
Picture shows the monitor convergence
Old   December 11, 2014, 17:38
Ahmad Al-Zoubi
Dear tareq,
Thanks for the supplied information.
- The provided image shows that there is a trend to convergence. However it doesn't mean that your solution is converged yet... Please check the results after some more hundred iterations and compare them with the previous one.
- Did you use the same boundary conditions as in the experimental case.
- You are using k-omega turbulence model. It worths also to check the results with realizable k-epsilon or v2f models.
- Grid independence study means checking the effect of grid refinement on the results. So make a more fine mesh (taking into account a reasonable y+ value) and compare the results. Do this until you see (engineering) minor difference between the results
Ahmad
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 23:43
What model of turbulence choose to study an external aerodynamics case raffale OpenFOAM 0 August 23, 2012 06:45
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
