Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to extract data from a specific layer of the grids?
Like Tree1Likes
  • 1 Post By ripperjack
Old   September 18, 2014, 00:37
Default How to extract data from a specific layer of the grids?
Jack
ripperjack is on a distinguished road
Hi Foamers,
I have a really simple question. I ran a channel flow simulation with 128*100*128 grids in streamwise (x), vertical (y), and spanwise (z) direction. After the simulation, I would like to extract the temperature fields at a specific channel height, e.g., y=50. How can I do that? I know that "sample" utility can do a simple work, but interpolation is always needed. How can I just give a y index and extract the data from specific vertical layer of the grids? (I used non-uniform grids in vertical direction, so I dont want interpolation, I just want raw data from a specific grid layer). Many thanks!
Regards,
Ripperjack
reespanau likes this.
ripperjack is offline   Reply With Quote
Old   October 29, 2014, 09:57
Joachim Herb
jherb is on a distinguished road
Did you find a solution for your problem? Perhaps these links help:
https://github.com/OpenFOAM/OpenFOAM...m/cuttingPlane
http://www.tfd.chalmers.se/~hani/kur...ionObjects.pdf
jherb is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 21:05
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 11:24
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Extract data we want from Techplot to a data file vetnav Main CFD Forum 0 July 28, 2010 21:17
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
