Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
R, yPlusRas & wallShearStress in interFoam
Like Tree1Likes
  • 1 Post By JFM
Old   June 2, 2014, 10:13
Post R, yPlusRas & wallShearStress in interFoam
JFM
JFM's Avatar
John Anonymous
JFM is on a distinguished road
Send a message via Skype™ to JFM
Good day to All
I would like to confirm with the community that the standard utilities in OpenFOAM 2.3
  • R
  • yPlusRAS
  • wallShearStress
do not work with interFoam as they are not designed to interpret multiphase model results. When I have tried to initiate these utilities I receive the following error message.
--> FOAM FATAL IO ERROR:
keyword transportModel is undefined in dictionary "/media/TERRA/MEng/MEng2014/OpenFOAM/working/5-k-e_60-90s/1448kMesh_ke_60-90s.org/constant/transportProperties"
file: /media/TERRA/MEng/MEng2014/OpenFOAM/working/5-k-e_60-90s/1448kMesh_ke_60-90s.org/constant/transportProperties from line 21 to line 73.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 437.
FOAM exiting
After reading a number of posts on the forum I have modified the transportProperties dictionary by including an additional single phase transportModel (i.e. water in this instance), as below, and the utilities will then output the respective output for the 'dummy' phase.
    transportModel  Newtonian;
    // Kinematic viscosity
    nu              nu [ 0 2 -1 0 0 0 0 ] 1e-06;
    // Density
    rho             rho [ 1 -3 0 0 0 0 0 ] 1000;
phases (water air);
water
    CrossPowerLawCoeffs
        nu0             nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
        nuInf           nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
        m               m [ 0 0 1 0 0 0 0 ] 1;
        n               n [ 0 0 0 0 0 0 0 ] 0;
    BirdCarreauCoeffs
        nu0             nu0 [ 0 2 -1 0 0 0 0 ] 0.0142515;
        k               k [ 0 0 1 0 0 0 0 ] 99.6;
        n               n [ 0 0 0 0 0 0 0 ] 0.1003;
air
    nu              nu [ 0 2 -1 0 0 0 0 ] 1.48e-05;
    rho             rho [ 1 -3 0 0 0 0 0 ] 1;
    CrossPowerLawCoeffs
    BirdCarreauCoeffs
At this point in time I cannot code (but will be learning over the next few months) however this leads me to ask several questions:
  • How accurate are the results
  • What happens at the interface
  • Is there a different utility that can be used in OF2.3
  • Has someone created their own utilities for compilation into OpenFOAM
Any feedback will be greatly appreciated.
Nostradamus likes this.
JFM is offline   Reply With Quote
interfoam, reynolds street (r), wallshearstress, yplusras
Using yPlusRAS with interFoam JohnTornblom OpenFOAM 2 March 16, 2018 08:05
Problems with YPlusRAS and wallShearStress Peter85 OpenFOAM Post-Processing 21 May 4, 2016 06:15
why does 'sample' do this? wallShearStress question CHARLES OpenFOAM Post-Processing 0 August 7, 2013 20:30
YPlusRas for InterFoam (Open Foam 1.7) MrD OpenFOAM 0 August 11, 2010 16:44
YPlusRAS and interFoam dkingsley OpenFOAM Bugs 4 April 28, 2010 10:08
