April 2, 2014, 20:17 |
Probes
Rep Power: 14 |
Not sure how to use "probes" utility in OpenFOAM..?
any help on this will be appreciated. Thanks much |
April 14, 2014, 03:20 |
Sita Drost
Rep Power: 18 |
You should include some code at the end of your controlDict, like this: functions { probes1 { type probes; functionObjectLibs ("libsampling.so"); region region0; probeLocations ( (1.3e-2 0 0) ); fields ( U ); outputControl timeStep; outputInterval 100; } } This particular example will give you the velocity (all three components) in the point (1.3e-2 0 0). It writes to a file probes1/0/U every 100 time steps. You should also be able to probe multiple points, to probe multiple variables, and to use different write controls. This is all explained elsewhere on this forum (use the search function), in the OpenFOAM wiki (use google), etc. Good luck, Sita |
How many probes can I have in a simulation ? | guilha | OpenFOAM Post-Processing | 13 | September 17, 2016 07:26 |
probes function not working in Openfoam 2.1.1 | nandiganavishal | OpenFOAM | 7 | July 26, 2012 11:06 |
Probes | dhruv | OpenFOAM | 3 | October 5, 2011 12:59 |
Error using probes | balkrishna | OpenFOAM Running, Solving & CFD | 6 | November 12, 2010 04:55 |
problems with probes() function in chtMultiRegionFoam | Victor | OpenFOAM | 0 | November 25, 2009 15:08 |
