Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Sample at a single point?
Like Tree1Likes
  • 1 Post By alexeym
Old   March 4, 2014, 06:08
Default Sample at a single point?
Olie
odellar is on a distinguished road
Apologies for what seems a trivial question, but how can I sample at a SINGLE POINT? I've managed to sample across lines, but I just want to sample at a single coordinate, (x,y,z), and have tried using 'cloud' and other things but can't get it to work!
Thanks in advance.
Olie
odellar is offline   Reply With Quote
Old   March 4, 2014, 06:20
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
try probeLocations utility. Though all the values at different time steps will be in a single file.
alexeym is offline   Reply With Quote
Old   March 4, 2014, 06:37
Olie
Thanks this looks like what I'm after - is this something that I need to set up before running the simulation (there seems to be a lot of talk about it being related to the controlDict when I googled it), or something I can use AFTERWARDS like the rest of the sampleDict utilities?
Thanks,
Olie
Old   March 4, 2014, 06:42
Alexey Matveichev
if you'd like to do run-time probing, you put description of the probes into controlDict, if you'd like to do probing after simulation, you create probesDict file (see example in $FOAM_APP/utilities/postProcessing/sampling/probeLocations), put it in the system folder and run probeLocations.
avinashjagdale likes this.
Old   March 4, 2014, 06:50
Olie
Oh brilliant, thanks.
point, sample
Single v.s. double precision Confused CFX 15 November 10, 2016 05:42
[Commercial meshers] Converting fluent mesh to foam sivakumar OpenFOAM Meshing & Mesh Conversion 11 April 30, 2013 10:29
[Other] [Gridgen] boundary condition for single point yidongxia OpenFOAM Meshing & Mesh Conversion 2 November 20, 2012 11:51
Sample issues MikePo OpenFOAM Post-Processing 1 February 7, 2010 20:20
CFX Post: Problems with moving point cloud for changing time steps spatialtime CFX 0 December 7, 2009 05:56
