February 19, 2014, 11:15 |
Force Coeffs using Helyx OS?
Andrew Kennedy
When running a job using the Helyx software, it doesn't produce the force coefficients in a convenient text file, as it does when running using OpenFoam. Is there a simple way to obtain the force coeffs after using the Helyx OS? I am able to view the results as normal using paraFoam, and I'm modelling the flow over a wing using simpleFoam and the SA flow model. Thanks |
force coefficients, helyxos, parafoam, wing, wing tip vortices |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 12:12 |
Force Coeffs with icoFoam | VSass | OpenFOAM Post-Processing | 10 | February 5, 2016 17:26 |
Force coeffs in compressible flows | nachettito | OpenFOAM Post-Processing | 0 | August 13, 2012 07:18 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 11:25 |
