Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
calculate and sample wallGradU & wallShearStress every output time
Like Tree1Likes
  • 1 Post By canopus
Old   November 8, 2013, 13:00
Default Sample wallShearStress every output time for all wall points
ArathoN
ArathoN is on a distinguished road
I'm a beginner user of OpenFoam, and after days of research i decided to ask your help dear community.
I need to calculate the velocity gradient and the wall shear stress at every output time, and i don't know how I can do it. I tried to modify the solver but my knowledge of C code isn't enough to make me understand what i have to do.
Another question is how can i output afterwards these data? I thought about using the sampledict but what should i choose between surface, sets and all other options?
Finally i saw some output file from the sample function and i didn't understand the meaning of the column, what they represent if i choose for example the variable velocity U and i want to sample in the "x" direction starting from point P1 and ending on point P2?
I thought on making something similar to the post-processing (it is written in the controldict and not in a separate file sampledict) present in the case "pitzDaily" where it outputs the fiels "P U K" every output time, but I don't know how I can do it.
I hope some kind soul could help me and sorry for my bad English (not my native language).
ArathoN is offline   Reply With Quote
Old   November 12, 2013, 10:26
ArathoN
I'm using this function in the control dict to calculate wallshearstress at every output time, but it gives me only the min and max value of the variable:
wallShearStress1
        type        wallShearStress;
        functionObjectLibs ("libutilityFunctionObjects.so");
        outputControl   outputTime;
        setFormat       gnuplot;
        patches     ("lowerWall");
what should i add to give me the valu of the stress in the lowerwall and the distance too?
Old   November 12, 2013, 12:32
ArathoN
I tried to use also the sample function like this:
interpolationScheme cellPoint;
fields
    "wallShearStress"
sets
lineX1
        type        uniform;
        axis        distance;
        start       (0 0 0);
        end         (2.5 0 0);
        nPoints     10;
where the lowerwall in which i'm interested to evaluate the wallshearstress begins from (0 0 0) and ends at (2.5 0 0).
But it will give me a null wallstressshear for every position. can you please tell me what am i doing wrong?
Old   November 17, 2013, 13:59
ArathoN
finally now i coult sample the wallshearstress. I want now to use the "libutilityfunctionobjects.so" with wallShearStress1 function in controldict. The only problem is that it will give me only the min and max value for every timeset, how can i specify that it should give me all the values on the lowerwall, i need to evaluate the separation point of the flow in a backward facing step.
wallShearStress1
        setFormat       gnuplot;
Please Can someone help me??I reached a dead end here and searched all the forum and the source documentation e found nothing.
Old   November 17, 2013, 14:18
ArathoN
I created the sample file so i can have the values of the wall shear stress with this code:
setFormat gnuplot;
surfaceFormat raw;
fields
    "wallShearStress"
sets
lineX1
        type        face;
        axis        x;
        start       (0 -0.1 0);
        end         (2.5 -0.1 0);
        nPoints     400;
surfaces
 walls_interpolated
        type            patch;
        patches         ( "lowerWall" );
        interpolate     true;
i sampled the same patch in two different modes, wanted to try the capability of the sample function.
I saw that i can add the libsampling.so to the controldict file and by this i can sample too while running the solver i tried modifying the file but with no success, any of you have a hint?
Old   August 8, 2016, 08:50
Default calculate and sample wallGradU & wallShearStress every output time
SM
canopus is on a distinguished road
Is it possible now to calculate wallGradU & wallShearStress every output time by using the controldict?
canopus is offline   Reply With Quote
Old   August 8, 2016, 09:21
SM
I found its possible to write in runtime with
wallShearStress1
        patches     ("wallbot");
//        outputControl   timeStep;
        outputControl   runTime;
        writeInterval   0.005;
But problem is
This function object evaluates and outputs the shear stress at wall patches. The result is written as a volVectorField to time folders as field 'wallShearStress'.
How can I make it write in postProcessing directory as the results of probe appear?
randolph likes this.
Old   February 18, 2017, 03:05
Saurav Kumar
srv537 is on a distinguished road
Hi
i used
pimpleFoam -postProcess -func wallShearStress
to calculate wallShearStress but it gives me only for saved data file but my case is unsteady so after some time i have to take average of all and to do this i want to calculate wallShearStress at each time step and its temporal average.
how to do it, please tell me. is there any method or code available in controlDict file to do this?
Thank you
srv537 is offline   Reply With Quote
Old   July 11, 2018, 13:14
Reviewer #2
randolph is on a distinguished road
wallShearStress1
But problem is
I do not see how this will work. How will the solver pass the turbulence model information to the function object?
randolph is offline   Reply With Quote
wallShearStress, wallGradU are inconsistent dancfd OpenFOAM Post-Processing 5 July 18, 2018 09:33
why does 'sample' do this? wallShearStress question CHARLES OpenFOAM Post-Processing 0 August 7, 2013 20:30
