Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Monitor Total Pressure in a running simulation using functionobjects
Like Tree11Likes
  • 1 Post By wyldckat
  • 1 Post By CFD-Cat
  • 4 Post By wyldckat
  • 2 Post By CFD-Cat
  • 3 Post By AqeelAhmed168
Old   October 22, 2013, 05:00
Default Monitor Total Pressure in a running simulation using functionobjects
CFD-Cat is on a distinguished road
I'm new to Open Foam, so probably the solution of my problem will be really simple for other user but I couldn't find anything about this in the forum.
I'm running a simulation of something similar to a pipe in simpleFoam ( OpenFoam 2.2.0). I'd like to monitor the areaAverage of the total pressure on the outlet boundary as a parameter to judge when the simulation reaches a good convergence. I'm doing the same for the massflowrate with a functionobject and it works fine but when I try to do it using the new pressureTools I got this warning:
--> FOAM Warning :
     From function probes::read()
     in file patch/patchFieldFunctionObject/patchFieldFunctionObject.C at line 100
     Unknown field total(p) when reading dictionary ".TotalPressureAveOutlet"
     Can only probe registered volScalar, volVector, volSphericalTensor, volSymmTensor and volTensor fields
The simulation runs fine and it saves a folder total(p) every iterations but it doesn't calculate the areaAverage at Outlet.
this is my control dictionary function:
functions
  myFunctionObject    // user-defined name of function object entry
        type            pressureTools;
        functionObjectLibs ("libutilityFunctionObjects.so");
    rhoRef 997;
    pRef  101300;
    //region          defaultRegion;
        enabled         yes;
        //timeStart       0;
        //timeEnd         10;
        outputControl timeStep;//outputTime;//
        outputInterval 1; // 5000;
        calcTotal   yes;
        calcCoeff   no;
reloadTotalP
          type        readFields;
          functionObjectLibs ("libfieldFunctionObjects.so");
          enabled         yes;
          //timeStart       0;
          //timeEnd         10;
          fields
              "total(p)"
type patchAverage;
functionObjectLibs ("libsimpleFunctionObjects.so");
verbose true;
patches (outlet);
factor 1;
fields (
total(p)
outputInterval  1;
outputControlMode timestep;
Thank you in advance for your help!
Ale
CFD-Cat is offline   Reply With Quote
Old   October 24, 2013, 13:15
anybody can help me?
Did I do something wrong?
Old   October 26, 2013, 08:39
Retired Super Moderator
Bruno Santos
Greetings CFD-Cat,
Mmm... this looks sort-of familiar... OK, 2 details:
  1. In this part of the code:
    type patchAverage;
    verbose true;
    patches (outlet);
    factor 1;
    fields (
    total(p)
    outputInterval  1;
    You should use quotes:
    fields (
    "total(p)"
    This is to avoid any other kind of interpretation.
  2. Secondly, the file name depends on several factors, as described on the Doxygen documentation: http://foam.sourceforge.net/docs/cpp...4.html#details
More specifically, I wrote about this here: http://www.cfd-online.com/Forums/ope...tml#post430031 post #4
Beyond this, I need an example case to test this for myself.
Best regards,
Bruno
Old   October 28, 2013, 06:21
I added the quote but it gives the same error. :-(
Old   November 2, 2013, 13:20
Bruno Santos
Hi CFD-Cat,
I finally managed to have a look into the case you sent me and it was fortunately rather simple!
A bit of a introduction - the idea behind "()" and "{}" is this:
  • The brackets "{}" are for gathering blocks of options, such as this:
    a 123;
    b 4564;
    c "word";
  • The parenthesis "()" are for lists of values, such as:
    • Code:
      (1 2 3)
    • Code:
      ((0 1 2) (3 4 5))
      Which is the same as:
      ((0 1 2) (3 4 5))
    • And the ultimate kind of list:
      a 123;
      b 4564;
      c "word";
      a 534;
      b 57467;
      c "another word";
The reason why this didn't work:
functions
Is because lists with parenthesis cannot have a name or title. This is why "functions" should be a block list of blocks:
functions
Best regards,
Bruno
Old   November 9, 2013, 15:43
Bruno Santos
Hi CFD-Cat,
To answer the question you've asked via private message, the full "functions" entry should look something like this:
functions
        type            pressureTools;
        rhoRef 997;
        pRef  101300;
        enabled         yes;
        //timeStart       0;
        //timeEnd         10;
        calcTotal   yes;
        calcCoeff   no;
    reloadTotalP
        type        readFields;
        enabled         yes;
        //timeStart       0;
        //timeEnd         10;
        fields
          "total(p)"
        type patchAverage;
        verbose true;
        patches (outlet);
        factor 1;
        fields (
          "total(p)"
        outputInterval  1;
    massflow
        type patchMassFlow;
        verbose true;
        patches (outlet);
        factor 997;
        outputInterval  1;
Notice that brackets "{}" are used for the "functions" block, and not parenthesis "()".
Best regards,
Bruno
chc likes this.
Old   March 14, 2014, 14:23
I'm sorry to restart this old discussion but since when I installed OF2.2.2 instead of OF2.2.0 I'm facing a new problem with pressureTools function object.
I can't understand the reason why when i try to calculate the total(p) the output reports only the BC like if no internal field has been calculated. It I try to calculate the static(p) I got the same problem, while for the total(p)_coeff I got a field distribution(maybe wrong) even setting the pInf =0.
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "160";
    object      total(p);
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    wall_sx
        type            calculated;
        value           uniform 0;
    floor
        type            calculated;
        value           uniform 0;
    wall_rear
        type            calculated;
        value           uniform 0;
    wall2
        type            symmetryPlane;
    inlet
        type            calculated;
        value           uniform 0;
    wall1
        type            calculated;
        value           uniform 0;
    wall_dx
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
I check if someone else found a similar problem but I wasn't able to find anything useful.
Except for this sentence that sincerely I don't understand completely:
"Where the function generates a field, e.g. wallShearStress, pressureTools, yPlusRAS, etc., the field is now stored on the mesh database so that it is available for further post-processing. " from http://www.openfoam.org/version2.2.2/
Old   March 15, 2014, 03:51
Bruno Santos
Hi CFD-Cat,
I need more information in order to be able to help you, namely:
  1. How exactly did you configure the function objects section at "controlDict"?
  2. What type of simulation are you performing?
  3. Are you able to reproduce the error with a tutorial from OpenFOAM?
Best regards,
Bruno
Old   March 15, 2014, 07:48
I'm out of office. On monday I'll try the tutorial and I'll send you the file.thank you for your help
Old   March 17, 2014, 05:46
Hi wyldckat,
I reproduced it with the tutorial Tjunction. This is my controlDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
libs
    "libOpenFOAM.so"
    "libincompressibleTurbulenceModel.so"
    "libincompressibleRASModels.so"
application     pimpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         1.5;
deltaT          0.001;
writeControl    adjustableRunTime;
writeInterval   0.1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           5;
functions
    probes
        // Where to load it from
        functionObjectLibs ( "libsampling.so" );
        type            probes;
        // Name of the directory for probe data
        name            probes;
        // Write at same frequency as fields
        outputControl   outputTime;
        outputInterval  1;
        // Fields to be probed
        fields
            p U
        probeLocations
            ( 1e-06 0 0.01 )        // at inlet
            ( 0.21 -0.20999 0.01 )  // at outlet1
            ( 0.21 0.20999 0.01 )   // at outlet2
            ( 0.21 0 0.01 )         // at central block
functions
pressure    // user-defined name of function object entry
        type            pressureTools;
	rhoRef 997;
	pRef  0;
        enabled         yes;
        timeStart       0;
        //timeEnd         10;
	//outputControl timeStep;//outputTime;
        //outputInterval 1; // 5000;
        calcTotal   yes;
        calcCoeff   no;
pressurecoeff    // user-defined name of function object entry
        type            pressureTools;
	rhoRef 997;
	pRef  0;
        enabled         yes;
        timeStart       0;
        //timeEnd         10;
        calcTotal   yes;
        calcCoeff   yes;
	pInf 0;
	UInf (1 1 1);
	rhoInf 997;
reloadtotalP
          type        readFields;
          enabled         yes;
          //timeStart       0;
          //timeEnd         10;
	  //outputControl timeStep;//outputTime;//
	  outputControlMode timeStep;
          fields
              "total(p)"
outlet-total-pressure
        type            faceSource;
        enabled         true;
	//outputInterval  1;
        log             true;
        valueOutput     false;
        source          patch;
        sourceName      outlet2;
        operation       areaAverage;
        //weightField        phi;
        fields
            "total(p)"
and this is the output :
FoamFile
    version     2.0;
    format      ascii;
    location    "0.2";
    object      total(p);
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet1
        type            calculated;
        value           uniform 0;
    outlet2
        type            calculated;
        value           uniform 0;
    defaultFaces
        type            calculated;
        value           uniform 0;
while the total(p)_coeff is like this:
FoamFile
    version     2.0;
    format      ascii;
    location    "0.2";
    object      total(p)_coeff;
dimensions      [0 0 0 0 0 0 0];
internalField   nonuniform List<scalar>
3875
10.639
10.4919
10.4483
10.3811
10.313
10.2384
10.1689
10.0984
boundaryField
    inlet
        type            calculated;
        value           nonuniform List<scalar>
25
10.6671
10.667
10.667
10.667
10.667
10.667
I run my case with simpleFoam too and I got the same result.
Best regards,
Ale
vsammartano likes this.
Old   March 23, 2014, 16:21
Bruno Santos
Hi Ale,
I finally managed to look into this. This should work:
        type            pressureTools;
        rhoName    rhoInf;
        rhoInf 997;
        pRef  0;
        enabled         yes;
        timeStart       0;
        //timeEnd         10;
        calcTotal   yes;
        calcCoeff   no;
The missing details were these:
        rhoName    rhoInf;
        rhoInf 997;
"rhoRef" doesn't exist, it's "rhoInf" that should be used. And we have to indicated that the name of the field to be used for "rho" is "rhoInf", so that it knows that it should use the constant value, as there is no "rho" field.
Although a bit cryptic, this can be spotted if we look at the source code: https://github.com/OpenFOAM/OpenFOAM...reTools.C#L263
Originally Posted by src/postProcessing/functionObjects/utilities/pressureTools/pressureTools.C
void Foam::pressureTools::read(const dictionary& dict)
    if (active_)
        dict.readIfPresent("pName", pName_);
        dict.readIfPresent("UName", UName_);
        dict.readIfPresent("rhoName", rhoName_);
        if (rhoName_ == "rhoInf")
            dict.lookup("rhoInf") >> rhoInf_;
        dict.lookup("calcTotal") >> calcTotal_;
        if (calcTotal_)
            dict.lookup("pRef") >> pRef_;
        dict.lookup("calcCoeff") >> calcCoeff_;
        if (calcCoeff_)
            dict.lookup("pInf") >> pInf_;
            dict.lookup("UInf") >> UInf_;
Best regards,
Bruno
Old   March 24, 2014, 09:10
Thank you very much Bruno. Now it works! I really appreciate your help.
I didn't check it because in OF2.2.0 it works fine without
 rhoName    rhoInf;
wyldckat and vsammartano like this.
Old   February 23, 2019, 18:12
  #13
Aqeel Ahmed
AqeelAhmed168 is on a distinguished road
For people looking for the same functionality in OpenFOAM version 6
functions
    totalPressureCalc
        type              pressure;
        functionObjectlib ("libfieldFunctionObjects.so");
        rhoName           rhoInf;
        rhoInf            1000;
        pRef              0;
        enabled           yes;
        executeControl    timeStep;
        executeInterval   1;
        writeControl      writeTime;
        writeInterval     1;
        calcTotal         yes;
        calcCoeff         no;
    reloadTotalP
        type              readFields;
        enabled           yes;
        executeInterval   1;
        writeInterval     1;
        fields
            "total(p)"
    totalPressureAvgInlet
        enabled         yes;
        type            surfaceFieldValue;
        surfaceFormat   false;
        libs            ("libfieldFunctionObjects.so");
        writeControl    timeStep;
        writeInterval   1;
        log             true;
        writeFields     false;
        regionType      patch;
        name            inlet;
        operation       areaAverage; //- options: sum, areaIntegrate
        mode            magnitude;
        fields
            "total(p)"
AqeelAhmed168 is offline   Reply With Quote
Old   March 10, 2020, 05:06
BastiL
bastil is on a distinguished road
Does anybody know how to do that in OpenFOAM-1906 and 1912? Does not seem to accept "pressure" as a function type. "unknown function type pressure"
Solved: needed to add "libfieldFunctionObjects.so" in the libs-section on top of "controlDict" to make it work.
bastil is offline   Reply With Quote
functionobjects, openfoam 2.2.0, pressuretools, totalpressure
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
the role of operating pressure in flow simulation sunflower FLUENT 1 December 20, 2010 22:24
high pressure simulation mahi FLUENT 0 November 7, 2008 02:30
stagnation pressure in transient flow simulation K.S.Ravichandran Main CFD Forum 2 September 5, 2000 01:34
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
