Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
probe a line
Like Tree5Likes
  • 3 Post By GerhardHolzinger
  • 2 Post By GerhardHolzinger
Old   May 16, 2013, 05:17
Default probe a line
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
Hi all,
I wrote a little python script that allows me to probe a line.
Actually, I state the start and the end of the line as well as the number of points and my script generates a probesDict containing the defined points.
Have a look at it and if you find my nasty bit of code useful, feel free to use it, or even improve it.
The script assumes a file named "probeLineDict" to reside in the system directory. The script itself needs to be executed from the case directory. However, you can change the paths inside the script to get a different behaviour.
GerhardHolzinger is offline   Reply With Quote
Old   May 21, 2013, 00:13
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
I believe that the 'sample' utility can do this as well. Give a start point, and end point, fields to sample, and number of sample points, it will extract the data requested.
http://www.openfoam.org/docs/user/sample.php
kmooney is offline   Reply With Quote
Old   May 21, 2013, 03:43
Gerhard Holzinger
You are right. However, if I use the probe function to do the job, I get a good time resolution.
I use sample as well, but in some cases I fell the need for higher time resolution. And writing everything to disk at a short interval and running sample afterwards is simply a waste of space.
Old   May 21, 2013, 05:37
Gerrit Laube
laubeg is on a distinguished road
Hi Gerhard,
I think in Line 25 it should be 'filename' instead of 'filenameW'.
And just to make things clear for future visitors of this thread: This file does not probe anything itselve, as one might expect from the title, but writes line coordinates to a probesDict, that is used by the 'native' OpenFOAM probeLocation application. As far as I know, you have to run this in advance of the processing itselve.
I never used the probe application, so Gerhard, maybe you could tell us a little more about the overall process: run Script -> run Solver -> find values in ./probes/-folder? Or is there anything else to consider? Do you have to modify the controlDict as well?
Thanks for the script! I hope that future generations of OpenFOAM will have a probe-application as good as the sample-app, but so far, this is a good workaround.
laubeg is offline   Reply With Quote
Old   May 21, 2013, 05:54
Gerhard Holzinger
You are completely right. My first post was indeed short of the information of how to use the script.
The script reads probeLineDict and generates entries for the regular probe function object. However, defining (start, end, nPoints) is much easier than writing 50 points along a line manually into probesDict.
The script overwrites probesDict. However, you can change the name of the file into which the script writes. If you are already using probes, make sure they do not collide.
The variable filename is the name of the file which contains the definition of the line to be probed. The variable filenameW is the name of the file into which the generated dictionary for probes is written.
The definition of the probe function object in controlDict must make use of an external file for the definition of the probes, otherwise, the generated file would be useless. I let the script write a seperate file in order to prevent it from messing up the controlDict.
The usage follow this procedure.
Put the probeLineDict into the system directory.
Run probeLine.py from the case directory
Run the solver
The controlDict contains this code:
functions
    probes1
        type probes;
        functionObjectLibs ("libsampling.so");
        dictionary probesDict;
    probes2
        type probes;
        dictionary probesDict2;
Old   May 21, 2013, 06:12
Gerrit Laube
Thanks for the explanation!
From line 23 to 25 you define 'filename' and use 'filenameW' afterwards.
Copied from your zip-file, line 23 to 25:
filename = './system/' + probesDict
#filenameW = probesDict
mywfile = open(filenameW,'w')
As far as I know, '#' is interpreted as a comment. Anyway I get an error, running the script:
Traceback (most recent call last):
  File "Y:\Home\laubeg\SharedFolder\Fehlman1\Fehlman2D_4\probeLine.py", line 25, in <module>
NameError: name 'filenameW' is not defined
Old   May 21, 2013, 07:04
Gerhard Holzinger
Hi, sorry for posting a buggy script. Mea culpa.
The code
should read
filenameW = './system/' + probesDict
I used the commented filename-statements to test the script without the need of having an system directory present. However, filename and filenameW are not very good variable names.
Jonas Ansoni and chengyu like this.
Old   June 5, 2013, 10:56
jiujiumin
jiujiumin is on a distinguished road
Run the solver
functions
    probes1
        type probes;
    probes2
        type probes;
this : Run probeLine.py from the case directory how to work?
jiujiumin is offline   Reply With Quote
Old   June 10, 2013, 00:45
Default The probesDict file where can i find?????
jiujiumin
The code
should read
Old   June 10, 2013, 04:27
Gerrit Laube
sorry for being rude, but did you even try to find a solution for one of your problems?
Here is one for running the python script: http://www.google.com
And one for the probesDict: Read the thread from the beginning or try the former solution!
This is a forum, not a google search. Regards!
Old   June 11, 2013, 10:13
Default sorry at the time i am very anxious
  #11
jiujiumin
sorry never next and at the time i am very anxious.
At the same time
I have another question how do I set the probeLine.py file to probe many lines at the same time? such as two lines at a time. thanks
Old   June 11, 2020, 16:36
Arijit Saha
ari003 is on a distinguished road
The code
should read
Sir I m trying the way which you just mentioned here but however I m confused whether to keep the python file and probeLineDict in the same system folder or not . Also do I have to include anything in controlDict folder?
I ll remain hopeful to get your reply.
ari003 is offline   Reply With Quote
Old   June 13, 2020, 22:09
Arijit Saha
Anyone from the forum can I get a response. I m in serious need. Please I ll remain hopeful.
Old   July 11, 2020, 15:08
Marc
mcgoldba is on a distinguished road
Hi Ari,
I have just started to look at using this script myself, and have not yet tested it. However, to answer your question, I believe the "probeLine.py" file should go into the main case directory, and the "probeLineDict" file should go into the "system/" sub-directory.
This is shown on line 17 of the python script:
filename = './system/' + probeLineDictName
Regards
mcgoldba is offline   Reply With Quote
Old   July 11, 2020, 15:13
Marc
In regards to your question about the controlDict, this was answered earlier in Gerhard's post:
functions
    probes1
        type probes;
    probes2
        type probes;
probe, probes, runtime postprocessing
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
