Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallGradU components
Like Tree6Likes
  • 1 Post By fumiya
  • 2 Post By fumiya
  • 2 Post By fumiya
  • 1 Post By anishtain4
Old   February 19, 2013, 09:26
Default wallGradU components
Amin
amin66 is on a distinguished road
Hi all
when I use "wallGradU" command for a curved wall (like a cylinder or sphere), i have 3 components for wallGradU in paraview. what are them?
are ( dUx/dx , dUy/dy , dUz/dz )? if x, y, z been cartesian system....
or if, for the curved wall, we assume normal spatial component to "n" and tangential components to "t1" and "t2" , then 3 components of wallGradU are (dUn/dn , dUt1/dt1 , dUt2/dt2 ) ???
Thanks all
Amin
amin66 is offline   Reply With Quote
Old   February 20, 2013, 10:14
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
Hi Amin,
I think the three components of wallGradU are (Ux/Δ , Uy/Δ , Uz/Δ).
where
Δ: distance between cell center and the wall
U = (Ux, Uy, Uz)
The vector wallGradU is the approximation of dU/dn (n: wall normal direction).
Hope that helps,
Fumiya
lucasbraganca likes this.
fumiya is offline   Reply With Quote
Old   February 20, 2013, 17:55
Antonio
Antonio.vucci is on a distinguished road
Hello Friends
fumiya, how can you find the location af separation point at a curvactured wall with this component?
Antonio.vucci is offline   Reply With Quote
Old   February 21, 2013, 04:07
Mahdi Hosseinali
anishtain4 is on a distinguished road
Separation point is where the second derivative becomes zero, there is no way you can find it with first derivative
anishtain4 is offline   Reply With Quote
Old   February 21, 2013, 06:14
fumiya's Avatar
Fumiya Nozaki
I have misunderstood the utility "wallGradU" and the "snGrad()" function used in it.
In the utility "wallGradU", the wall normal gradient is calculated using the "snGrad()"
function and this function discretizes the normal gradient using the following first
order approximation:
In fvPatchField.C
00176    // Return gradient at boundary
00177    template<class Type>
00178    Foam::tmp<Foam::Field<Type> > Foam::fvPatchField<Type>::snGrad() const
00179    {
00180        return (*this - patchInternalField())*patch_.deltaCoeffs();
00181    }
snGrad() = (U[faceI]-U[cellI])/mag(Cf[faceI]-Cn[cellI])
where
faceI: label of the face on which we calculate the normal gradient
cellI: label of the cell adjacent to the faceI
Cf: position vector of face center
Cn: position vector of cell center
As you can see, the surface normal gradient calculated by wallGradU does not apply any
non-orthogonality or skewness corrections.
Hope that helps,
Fumiya
cfdsolver1 and Ethon like this.
Old   March 1, 2013, 10:36
Amin
thanks all
Mahdi, as i know separation occurs when the first derivation of velocity near the wall becomes zero.
Fumiya, is there any way to determine separation point with wallGradU on cylinder? or even with other methods?
Old   March 1, 2013, 11:41
fumiya's Avatar
Fumiya Nozaki
Hi Amin,
I think it depends on your simulations:
  1. Solving laminar flows
  2. Solving turbulent flows with low Re trubulence model
  3. Solving turbulent flows with high Re turbulence model
In the case of 1 and 2:
You can use the wallGradU to find the positions where wall normal gradient of velocity is zero.
In the case of 3:
You can use the wallShearStress utility to find the positions where the wall shear stress vanishes.
Correct the mistakes, if any, in my post.
Fumiya
amin66 and Ethon like this.
Old   March 2, 2013, 08:49
Mahdi Hosseinali
Fumiya
As you know when you capture viscose sub-layer it is a linear profile, so the derivative of it is zero, while the flow is not separated. Flow separates when you have zero shear stress ( You can derive it easily from NS equations, just put non-slip conditions and look for zero pressure gradient )
So I believe third method Fumiya mentioned would be the best and most reliable
amin66 likes this.
Old   March 3, 2013, 11:12
Amin
Hi Fumiya & Mahdi
Thank you. your comments was so usefull.
Regards
Amin
Old   March 25, 2016, 21:09
RacMat
rvl565 is on a distinguished road
In fvPatchField.C
00179    {
00181    }
where
Hope that helps,
Fumiya
Hi!
So this means that the first component of GradU is dU/dn ?
Thanks
rvl565 is offline   Reply With Quote
getting (0 0 0) wallGradU value when i m probing wallGradU at some points suryawanshi_nitin OpenFOAM 1 December 9, 2013 12:36
how to extract the components of radial and tangential velocities renyun0511 OpenFOAM Running, Solving & CFD 0 April 8, 2011 08:15
Transient Statistics for turbo components Suzzn CFX 5 May 4, 2010 10:56
velocity components in cylindrical coordinates iperten CFX 2 March 31, 2009 09:22
reynolds stress components in CEL Roberto CFX 0 December 3, 2008 04:29
