Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Sample velocities for a multiphase problem
Like Tree3Likes
  • 2 Post By emirust
  • 1 Post By Elham
Old   January 24, 2013, 05:11
Default Sample velocities for a multiphase problem
emirust is on a distinguished road
Beloved Foamers,
I am simulating the fall of a droplet of water in oil, with interFoam. See the attached picture.
My question is how to procede to extract the terminal velocity of the drop, i.e. where the phase fraction alpha is 1.
The "sample" utility would serve, but I was wondering about the possibility of having an IF statement to only keep certain cells.
Another solution would perhaps be to extract values from a box, and run this if statement in Matlab f.eg, but I was wondering what is the best practice? I would also like to point out that I was thinking about averaging all velocities on all cells to keep out the effect of recirculation inside the drop.
So, if you skipped til the end, my question is: how to extract the terminal velocity of the droplet for this case.
Thank you!
emirust is offline   Reply With Quote
Old   January 24, 2013, 06:35
Assistant Moderator
Bernhard Gschaider
Originally Posted by emirust View Post
Beloved Foamers,
Thank you!
Well the easiest way to circumvent the need for an IF is to let alpha1 act as an IF and base further recipes on something like "alpha1*U" (which should give you 'only' the velocity of the liquid phase. Might of course fail for very high gas velocities in regions that only have a few percent liquid).
I personally use swak4Foam for that kind of calculations and write a function object like this (I'm doing this from the top of my head. There may be syntax errors in that):
    liquidVelocity
        type swakExpression;
        valueType internalField;
        expression "alpha1*U";
        accumulations (
            min
            max
        verbose true;
that only gives you the extremes of the liquid velocity. A more elaborate calculation (with volume weighted average and only using the component of the velocity in the down direction) would be
    downAverage
        variables (
             "downDirection=vector(0,-1,0);"
             "thres=0.5;"
             "liquidVol=sum(alpha1>thres ? vol() : 0);"
             "downVel=alpha1>thres ? (U & downDirection) : 0;"
        expression "downVel*vol()/liquidVol";
        accumulations (
           sum
        verbose true;
An alternative that swak offers is to track the surface of the liquid and calculate the velocity of that (for an example see in the swak-distribution Examples/other/capillaryRise).
If you decide to do it this way and it works for you could I ask you to add a recipe to http://openfoamwiki.net/index.php/Co...Usage_examples as this is something that other people might be interested in. Thanks
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 12, 2013, 10:39
Hello!
I haven't tracked the isosurfaces as suggested previously, but I used the following to track the drop deformation as it falls down. It might not be good enough for the wiki, so I just post it here.
This was just added at the end of the controlDict and creates a set of values that can give the horizontal and vertical diameter. This can lead to the position of the center of the drop which can be used to find the fall velocity
libs (
      "libOpenFOAM.so"  // OpenFOAM will (probably) crash if this library is not specified
      "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
functions
    downAverage
        variables (
             "thres=0.5;"//which cells to keep
             "liquidVol=sum(alpha1>thres ? vol() : 0);" //calculates the volume of the drop
             "downVel=alpha1>thres ? (U & downDirection) : 0;" //a & b:inner vector product. Keep the y component of U.
        expression "downVel*vol()/liquidVol";//vol():vol of the cell
        accumulations (
           sum
        verbose true;
    createInterface
        type createSampledSurface;
        outputControl timeStep;
        outputInterval 1;
        surfaceName interface;
        surface {
            type isoSurface;
            isoField alpha1;
            isoValue 0.5;
            interpolate true;
    xDiameter
        valueType surface;
        verbose true;
        expression "pos().x";
        accumulations (
            min
            max
    yDiameter
        valueType surface;
        verbose true;
        expression "pos().y";
        accumulations (
            min
            max
Good luck!
Elham and BlnPhoenix like this.
Old   February 12, 2013, 17:00
Assistant Moderator
Bernhard Gschaider
Hello!
Why not? If everything there had to be perfect nothing would get posted. And if somebody doesn't like your solution he can improve it ... it's a Wiki
Old   July 1, 2015, 23:35
Elham
Elham is on a distinguished road
I try to use your subroutine at the end of controlDict to calculate droplet velocity but I don't know where I can find the calculated velocity? I mean in Paraview?
Elham is offline   Reply With Quote
Old   July 20, 2015, 22:15
Elham
Hello!
libs (
functions
    downAverage
        variables (
        accumulations (
           sum
        verbose true;
    createInterface
        outputInterval 1;
        surface {
            type isoSurface;
            isoField alpha1;
            isoValue 0.5;
            interpolate true;
    xDiameter
        valueType surface;
        verbose true;
        accumulations (
            min
            max
    yDiameter
        valueType surface;
        verbose true;
        accumulations (
            min
            max
Good luck!
Hi everyone
I use the above code to calculate drop velocity but I don't know how I can sea the results? in paraFoam?
Thanks
Old   December 15, 2016, 07:13
Ramin
rmn_990 is on a distinguished road
Originally Posted by Elham View Post
Hi everyone
Thanks
Hi
Please open Postprocessing Folder and there you can see the result.
you can plot the data with excel etc.
your output is a 2D chart and is not a contour.
Goodluck !
Ramin
rmn_990 is offline   Reply With Quote
Old   December 18, 2016, 23:00
Elham
This is an old post. Anyway, thanks.
arashma likes this.
Old   November 9, 2020, 11:06
Question can this be used with -postProcess?
JM27 is on a distinguished road
I have added this functionObject to the controlDict in an existing case file. The simulation has already been computed and I would like to extract some of the data, I therefore try to use the -postProcess functionality in OF for this swak functionObject, but I can't seem to get it to work.
I have tried:
mpirun -np 2 compressibleInterFoam -parallel -postProcess -func liquidVelocity
but I get
--> FOAM Warning :
    From function static bool Foam::functionObjectList::readFunctionObject(const Foam::string &, Foam::dictionary &, Foam::HashSet<Foam::word, Foam::string::hash> &, const Foam::word &)
    in file db/functionObjects/functionObjectList/functionObjectList.C at line 246
    Cannot find functionObject file liquidVelocity
I don't quite understand why the file cannot be found since -postProcess defaults to system/controlDict unless otherwise specified. I have also tried coding similar using a coded functionObject but with no success using the -postProcess functionality.
I feel this should be straightforward, but I wanted to ask if anyone had similar issues and how I can solve this? I can't seem to find any other posts describing similar issues.
JM27 is offline   Reply With Quote
Old   November 12, 2020, 09:14
Update -- I've managed to find a workaround for this by using postProcess without specifying the name of the desired functionObject. It works fine in this case but it will compute ALL functionObjects in the controlDict rather than ONLY the newly introduced one.
multiphase steady problem lionlove0903 OpenFOAM Running, Solving & CFD 0 January 19, 2011 04:49
mass balance problem in multiphase model mdsanij1 FLUENT 0 July 28, 2009 17:01
multiphase UDF, variables for phase velocities Kerem FLUENT 4 March 27, 2006 09:20
Problem of B.C. in Eulerian multiphase model Derek Jing FLUENT 0 May 12, 2002 12:52
CF4 - need advice on setting up multiphase problem Brett Towler CFX 2 August 18, 2000 17:38
