Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Glyph: how to avoid the plot of vectors perpendicular to boundaries?
Like Tree8Likes
  • 7 Post By alsdia
  • 1 Post By banji
Old   November 16, 2012, 21:23
Default Glyph: how to avoid the plot of vectors perpendicular to boundaries?
Serena
serena is on a distinguished road
Dear all,
In paraview if I select glyph scaling off and the velocity magnitude is 0, the glyphs are orientated in the x-direction (as in the picture enclosed) [look like they are getting through the boundary wall]
is there a way to make those horizontal glyphs disappear?
serena is offline   Reply With Quote
Old   November 17, 2012, 14:13
Chris L
vbchris is on a distinguished road
Did you add boundary patches along with your internal mesh, maybe try only internal mesh.
vbchris is offline   Reply With Quote
Old   November 18, 2012, 23:24
edy
alsdia is on a distinguished road
Ah Ok, we can do this way:
(from pag166 user-guide) first apply the Cell Centers filter to the case module (Filters -> Alphabetical -> Cell Centers), and
then apply the Glyph filter to the resulting cell centre data.
In this way we plot the vector in the center of the cell, whose magnitude is not zero, so the orientation is not horizontal anymore.
alsdia is offline   Reply With Quote
Old   October 22, 2015, 03:54
Andrew
Antech is on a distinguished road
I have the same issue post-processing CFX results converted to EnSight Gold (ASCII) with Ansys Solver Manager. Now I use the following solution:
1. Apply the Extract Block filter to extract only cells, not boundaries (as recommended in this topic).
2. Apply Point Data To Cell Data and then Cell Data To Point Data on slices where I need glyphs (velocity vectors), and then use glyphs on the result. This helps to "resample" data with interpolation and avoid zero-velocity (or almost zero-velocity) near-wall cells.
Antech is offline   Reply With Quote
Old   October 1, 2016, 11:59
Olabanji
banji is on a distinguished road
You can also set a threshold for the glyph filter. This would 'silent' the glyphs that have a magnitude of zero.
Antech likes this.
banji is offline   Reply With Quote
Old   September 26, 2019, 17:51
Default Using Latest openfoam
anonymous
cloudexile is on a distinguished road
I have the same problem, but I have no idea how to fix it. It looks like the menu for glyphs is different than the tutorial guide using cell centers and glyphs. I am not sure what to do to fix it.
cloudexile is offline   Reply With Quote
Old   October 22, 2019, 05:37
BlnPhoenix is on a distinguished road
Have you managed it? You need to add the Cell Centers Filter and then apply the Glyph Filter over that. You find the Cell Centers Filter in Filter-> Alphabetical -> Cell Centers
BlnPhoenix is offline   Reply With Quote
[ICEM] How to avoid single edges at boundaries in 2D models? Gandin ANSYS Meshing & Geometry 12 October 16, 2014 07:00
plot field velocity vectors in fieldview gaurav FieldView 0 October 7, 2009 11:51
particle plot with boundaries ema Siemens 0 September 12, 2005 06:31
plot vectors perpendicular to curved surface azmir Siemens 3 October 19, 2004 02:48
Plot wall boundaries & drops Ossi Siemens 7 November 18, 2002 10:35
