Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
I want to plot residual U:
Like Tree4Likes
  • 1 Post By SirWombat
  • 1 Post By Bernhard
Old   October 4, 2012, 10:15
Default I want to plot residual U:
vahid
vahid.najafi is an unknown quantity at this point
Hi dear Foamers.I have a problem,please help me to solve this.
Im working with interPhaseChaneFoam solver!!!in the end of run I want to have residual plot!!!
I have log file but in this I havent residual for Ux,Uy and Uz!!!!
I want to have
residual U,but I seen:
"plotres.txt", line 7: warning: Skipping data file with no valid points
plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,"< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,"< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines
"plotres.txt", line 7: x range is invalid???
please help me to plot this residual!!!
{for more Description.
Im using gnuplot.for this work im do this work step by step:
1-my solver >log
2-tail -f log
3-Crtl+C
4-gnuplot plotres.txt
(file plotres.txt include:
set logscale y
set title "Residuals"
set ylabel 'Residual'
set xlabel 'Iteration'
plot "< cat log | grep 'Solving for U' | cut -d' ' -f9 | tr -d ','" title 'U' with lines,\
"< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,\
"< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,\
pause 1
reread
The point that needs to be said:
I plot residual P with this Commands in gnuplot!!!
please help me for this problem??
Thanks for your Attention.
vahid.najafi is offline   Reply With Quote
Old   October 5, 2012, 04:29
Jan
SirWombat is on a distinguished road
Send a message via Skype™ to SirWombat
could you post a small part of the logfile where the velocity residual is listet. we can then think about the correct syntax for your plot.
vahid.najafi likes this.
~~~_/)~~~
SirWombat is offline   Reply With Quote
Old   October 5, 2012, 07:39
Bernhard
Bernhard is on a distinguished road
You may want to use the foamLog utility.
Bernhard is offline   Reply With Quote
Old   October 5, 2012, 11:39
Default Hi dear SirWombat.
vahid
Hi dear SirWombat.
Thanks for your answer,I attachment Part of the log file in my log file.txt and plotres.txt,I hope that you with them,solve my problem???
Thank you very much.
File Type: txt plotres.txt (195 Bytes, 51 views)
Old   October 5, 2012, 12:16
Default Thanks dear Bernarad for your answer.
vahid
Hi Dear Bernhard,Thanks for your answer.
please give me more information about to use the foamLog utility???
I've never use it!!!
Old   October 5, 2012, 16:36
Jan
Have a look at the official documentation: http://www.openfoam.org/docs/user/monitoring-jobs.php
foamLog "my log file.txt"
will create a folder "logs" containing a few plots. You can use gnuplot to plot those files, i.e.
gnuplot --persist -e "plot 'logs/p_rgh_0' w lines;"
about the velocity residual: i cannot find it in your log file, so unfortunately i cannot help you with that. There is this "max(U)" and you can surely extract this by using:
grep "max(U)"  "my log file.txt"  | awk '{print $2}'
but i am not sure what that actually is ... looks more like the actual maximum velocity than a residual ...
~~~_/)~~~
Old   October 6, 2012, 01:22
Default Tnx
vahid
Hi agian dear SirWombat.
Thanks for your reply.
Im trying your commands ,but i dont succes to plot residual U yet!!!???
I ask you,if do you find a solution,advice to me.
However,thanks for your Guidance.
Old   October 8, 2012, 04:13
Bernhard
You can use it ase "foamLog log" and you'll get a directory ./logs, where, I think, the are easily related to the original logfile.
Old   July 7, 2013, 09:32
s.m
saeideh mohamadi
s.m is on a distinguished road
I want to have
1-my solver >log
2-tail -f log
3-Crtl+C
set logscale y
pause 1
reread
you can use "pyFoamPlotRunner.py simpleFoam" if you use simpleFoam For your analysis.
it will show you the residuals during the run.
s.m is offline   Reply With Quote
Old   June 2, 2014, 10:29
Amir
amir_kb is on a distinguished road
Hi Vahid
I think you must remove the ,\ at the end of line 7 (just one line before pause 1).
amir_kb is offline   Reply With Quote
Old   June 2, 2014, 10:31
Amir
set logscale y
plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,\
"< cat log | grep 'Solving for omega' | cut -d' ' -f9 | tr -d ','" title 'omega' with lines,\
"< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,\
"< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" title 'p' with lines
pause 1
reread
Old   July 1, 2016, 03:54
Default Need help in OpenFoam COmbustion Model
  #12
ashishvshelke's Avatar
A V Shelke
ashishvshelke is on a distinguished road
Dear Foamer,
I am working on fuel cloud combustion, in which a fuel vapor cloud is getting form in case of leakage of fuel and get ignited by any heat source available.
I have tried this in fireFoam as fuel C3H8 is inlet from ground for certain time span to make a cloud.
with singleStepReactingMixture, infinitelyFastChemistry<psiThermoCombustion,constG asHThermoPhysics> started the chemical reaction as O2 comes contact in C3H8..
in many available "ignition" contained model do not contain the species fraction that I required as CO2, H2O
so I need a model that contain:
1 Radiation Model
2 LES
3 Species Transport
4 Spark ignition
ashishvshelke is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
