Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Reconstruction of the parallel case with dynamic mesh
Like Tree12Likes
  • 12 Post By makaveli_lcf
Old   July 12, 2012, 11:10
Default Reconstruction of the parallel case with dynamic mesh
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi all!
Today I faced a problem with the reconstruction of the parallel case with dynamic mesh refinement used in the solver.
First guess was that it is my solver's problem which could write not all the mesh data required for the reconstruction.
But first trial with the interDyMFoam in parallel (4 CPUs) indicated the same problem. Let's go into details.
So, simple run of the reconstructPar utility reports following symptoms:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : reconstructPar
Date   : Jul 12 2012
Time   : 15:08:53
Host   : "pc169"
PID    : 28123
Case   : /media/Sim/alexanderv/New_CD_Labor/Term_03/VOF/DyM_Reconstruct/OFv211/damBreakWithObstacle
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Time = 0.02
--> FOAM FATAL IO ERROR:
cannot find file
file:   /media/Sim/alexanderv/New_CD_Labor/Term_03/VOF/DyM_Reconstruct/OFv211/damBreakWithObstacle/processor0/0.02/polyMesh/pointProcAddressing  at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Searching on the CFD-online gave tips and a way to solution:
1. Use reconstructParMesh for mesh reconstruction
2. Use reconstructPar for the data reconstruction
Step 1.
a) First problem is that reconstructParMesh uses reconstruction tolerance 1e-07 and suppose we used default values writing simulation data as well as mesh modifications in ASCII format with 1e-06 precision.
To override the defaults we use reconstructParMesh with -mergeTol 1e-06
b) Secondly reconstructParMesh during the run processes only one time step (correct?) either first or the lasr (wirh -latestTime flag). In any case I didn’t find automatic procession of all time dirs and -time <time> option works with the singe parameter only on the contrary to the reconstructPar -time <ranges>. So we will put it in a loop to reconstruct all time dirs.
Step 2.
Fails without clear reasons:
Date   : Jul 13 2012
Time   : 16:04:04
Host   : "pc169"
PID    : 19765
Case   : /media/Sim/alexanderv/New_CD_Labor/Term_03/VOF/DyM_Reconstruct/OFv211/damBreakWithObstacle_clean.run1
nProcs : 1
Create time
Time = 0.02
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  Foam::objectRegistry::checkOut(Foam::regIOobject&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::regIOobject::~regIOobject() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::IOList<int>::~IOList() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6  Foam::processorMeshes::read() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libreconstruct.so"
#7  Foam::processorMeshes::readUpdate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libreconstruct.so"
 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/reconstructPar"
#9  __libc_start_main in "/lib/libc.so.6"
Segmentation fault
Solution is to set “startFrom startTime;” in the controlDict and removing processor*/0 folders.
In the attached script I backup them and then move back after data reconstruction.
So hereby I’ve attached a bash script for automatic reconstruction of e.g. interDyMFoam parallel case to avoid modified mesh isues.
#!/bin/bash
##  Merge tollerance (to override default value 1e-07 for ASCII output)
TOL=1e-06
##  Log file name
LOG='log.reconstructParMesh'
##  Start time folder name
START='0'
##  Check for empty time folders
TIME_DIRS=''
for proc_ in processor0/*; do
    dir_=`echo $proc_ | sed 's/processor0\///'`
    if [ ! -d $dir_ ]; then
        echo "Time $dir_ ist not reconstructed"
        ##  For empty list
        if [ ! -n "$TIME_DIRS" ]; then
            TIME_DIRS=$dir_
        else
            TIME_DIRS="$TIME_DIRS $dir_"
        fi
    fi
done
##  Exit if everything is reconstructed
    echo -e "\nNothing to reconstruct! Exiting..."
    exit 0
else
    ##  Clean old log files
    rm -fv $LOG.*
    ##  Reconstruct mesh and data
    echo -e "Reconstructing mesh for:\n"
    ##  Mesh
    for dir_ in $TIME_DIRS; do
        echo -e "\tTime = $dir_ sec\n"
        reconstructParMesh -time $dir_ -mergeTol $TOL 2>&1 | tee $LOG.mesh
    done
    ##  Set startFrom to startTime
    sed -i "s/startFrom.*\;/startFrom    startTime\;/g" system/controlDict
    ##  Rename zero time folders in the processor directories
    for proc_ in processor*; do
        mv -fv $proc_/$START $proc_/$START.backup
    done
    ##  Data
    echo -e "Reconstructing data for times: $TIME_DIRS"
    reconstructPar -time `echo $TIME_DIRS | sed s/\ /,/g` 2>&1 | tee $LOG.data
    ##  Rename zero time folders backups in the processor directories
        mv -fv $proc_/$START.backup $proc_/$START
    done
fi
It is possible to adjust the settings in the script for tolerance, start time and logfile name.
Here are some simulation and post-processing results:
https://docs.google.com/open?id=0BzC...1k5YmVTZDdOT1k
wyldckat, linch, aliqasemi and 9 others like this.
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
Last edited by makaveli_lcf; July 13, 2012 at 11:06. Reason: Fixed fail at the reconstructPar stage
makaveli_lcf is offline   Reply With Quote
Old   August 7, 2013, 11:18
Illya Shevchuk
linch is on a distinguished road
Hi Alexander,
thanks for the script. Unfortunately, the data reconstruction doesn't work in my case (OF-2.1.x). I can't decrypt the error message:
Create time
Time = 0.0230874
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam:bjectRegistry::checkOut(Foam::regIOobject&) const in "/home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::regIOobject::~regIOobject() in "/home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::IOList<int>::~IOList() in "/home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6 Foam:rocessorMeshes::read() in "/home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libreconstruct.so"
#7 Foam:rocessorMeshes::readUpdate() in "/home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libreconstruct.so"
in "/home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/reconstructPar"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Do you have any ideas?
Best regards,
Ilya
linch is offline   Reply With Quote
Old   August 8, 2013, 05:27
Illya Shevchuk
Solved. the error was because of insufficient RAM.
Old   August 8, 2013, 05:56
Effective)
Best regards,
Old   July 3, 2014, 06:51
ttttoor
meng9019 is on a distinguished road
Hi Ilya,
How did you solve this problem?
I am running into the same problem now.
Thank you in advance.
meng9019 is offline   Reply With Quote
Old   July 14, 2021, 12:20
TWB
quarkz is on a distinguished road
Hi makaveli_lcf, thanks for the script. It really worked! Btw, I'm using OF v2012.
quarkz is offline   Reply With Quote
Old   July 15, 2021, 07:04
Hi! great that after 9 years it still works)
Best regards,
Old   October 18, 2023, 12:28
Luke Hirl
Luke99 is on a distinguished road
also works for v2212
Luke99 is offline   Reply With Quote
Old   December 3, 2024, 12:16
Smile also works for of-v9
Zhao Zi Long
Hypersonicc is on a distinguished road
I used a simplified script command:
for dir in processor*; do [ -d "$dir" ] && find "$dir" -mindepth 1 -maxdepth 1 -type d -name '0.0012' -exec rm -rv {} \;; done
0.0012 is just an example time and can be replaced with other times. Actually, you don't need to make a backup because your initial file existed before partitioning, so I chose to delete it directly.
Anyway, thank you for your script. It still helps me 12 years later today!
Hypersonicc is offline   Reply With Quote
dynamic mesh, interdymfoam, pointprocaddressing, reconstructpar, reconstructparmesh
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
how to parallel run in moving mesh case ELYOR Siemens 5 June 16, 2008 04:23
Dynamic Mesh in an In-cylinder case venkitaraman FLUENT 0 March 26, 2007 18:15
Automatic Mesh Motion solver michele OpenFOAM Running, Solving & CFD 10 September 26, 2005 09:21
