Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
OpenFoam log file monitor
Like Tree5Likes
  • 2 Post By gregor
  • 2 Post By gregor
  • 1 Post By gregor
Old   July 25, 2018, 06:34
Default OpenFoam log file monitor
Gregor Olenik
gregor is on a distinguished road
Hi guys,
I uploaded an early version of my log file monitoring tool to my github page https://github.com/greole/foamMon . The tool aims to give an overview of
the progress of long running simulations. Feel free to try it out.
Cheers,
Gregor
aerospaceman and Ramzy1990 like this.
gregor is offline   Reply With Quote
Old   September 5, 2018, 03:22
Default Version 0.2.2
Gregor Olenik
If you're interested I just released version 0.2.2, available on github and Pypi. The usage has changed slightly. To start it just run foamMon in any Simulation (or parent) folder. Tester and feedback are welcome.
guin and zhangyan like this.
foamMon A case monitor for OpenFoam log files
Owls Importing OpenFoam data into jupyter/ipython notebooks
Old   September 5, 2018, 11:44
Rodrigo
guin is on a distinguished road
Originally Posted by gregor View Post
Hi guys,
Cheers,
Gregor
Not sure how to try it (...maybe due to my ignorance regarding pip)
me@work:~$ python3 -m pip install foamMon
Collecting foamMon
  Using cached https://files.pythonhosted.org/packages/0b/09/8bf8da90eee7dd58cdb6b770df3c8677ef16c8887dd71c03d016d8c5563a/foamMon-0.2.2-py3-none-any.whl
Collecting docopt (from foamMon)
Collecting colorama (from foamMon)
  Using cached https://files.pythonhosted.org/packages/db/c8/7dcf9dbcb22429512708fe3a547f8b6101c0d02137acbd892505aee57adf/colorama-0.3.9-py2.py3-none-any.whl
Installing collected packages: docopt, colorama, foamMon
Successfully installed colorama-0.3.9 docopt-0.6.2 foamMon-0.0.0
You are using pip version 8.1.1, however version 18.0 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
me@work:~$ foamMon
foamMon: command not found
me@work:~$ python3 -m foamMon
/usr/bin/python3: No module named foamMon
me@work:~$ ls .local/lib/python3.5/site-packages/
colorama                  docopt.py         foamMon-0.0.0-py3.5.egg
colorama-0.3.9.dist-info  easy-install.pth  foamMon-0.2.2.dist-info
docopt-0.6.2.dist-info    FoamMon           __pycache__
guin is offline   Reply With Quote
Old   September 6, 2018, 10:36
Gregor Olenik
Hey Rodrigo,
thanks for giving it a try. Can you run
~/.local/bin/foamMon
Old   September 6, 2018, 11:01
Rodrigo
Hey Rodrigo,
...well, here is my output:
me@work:~$ .local/bin/foamMon
Traceback (most recent call last):
  File ".local/bin/foamMon", line 26, in <module>
    from FoamMon import cui
  File "/home/me/.local/lib/python3.5/site-packages/foamMon-0.0.0-py3.5.egg/FoamMon/__init__.py", line 3, in <module>
  File "/home/me/.local/lib/python3.5/site-packages/foamMon-0.0.0-py3.5.egg/FoamMon/FoamDataStructures.py", line 11, in <module>
  File "/home/me/.local/lib/python3.5/site-packages/foamMon-0.0.0-py3.5.egg/FoamMon/cui.py", line 1, in <module>
ImportError: No module named 'urwid'
Unfortunately, I do not (yet) speak Pythonian...
Old   September 7, 2018, 03:45
Gregor Olenik
Ok, it seems that ~/.local/bin is not in your $PATH variable. What distro are you using or do you use any virtualenv like conda? Sometimes simply opening a new shell helps otherwise add a
 export PATH=$PATH:$HOME/.local/bin
to your bashrc.
Regarding the urwid error, I forgot to add urwid to the depencies. After running
 python3 -m pip install foamMon --upgrade
it should hopefully work.
Old   September 7, 2018, 04:34
Rodrigo
Great, this worked. "foamMon" is now installed and it can be called.
BTW: conventional Ubuntu 16.04 installation.
Old   September 7, 2018, 04:39
Rodrigo
So, let's keep going step by step... (that's why I put it in a separate post) ...first running issues:
me@work:~/OpenFOAM/me-6/run/snappy_with_AMR$ foamMon
  File "/home/me/.local/bin/foamMon", line 26, in <module>
  File "/home/me/.local/lib/python3.5/site-packages/foamMon-0.0.0-py3.5.egg/FoamMon/cui.py", line 19, in <module>
ImportError: cannot import name 'Cases'
me@work:~/OpenFOAM/me-6/run/snappy_with_AMR$ tree -L 2 ./
└── windAroundBuildings
    ├── 0
    ├── 1
    ├── 10
    ├── 11
    ├── 12
    ├── 13
    ├── 14
    ├── 2
    ├── 3
    ├── 4
    ├── 5
    ├── 6
    ├── 7
    ├── 8
    ├── 9
    ├── Allclean
    ├── Allrun
    ├── constant
    ├── log
    ├── log.blockMesh
    ├── log.snappyHexMesh
    ├── log.surfaceFeatures
    ├── README.txt
    ├── system
    └── visualizationExample.pvsm
18 directories, 8 files
Old   September 7, 2018, 04:42
Rodrigo
For some reason, it seems not to find this class https://github.com/greole/foamMon/bl...uctures.py#L64
Old   September 7, 2018, 05:25
Rodrigo
WARNING to potential readers: this starts to become less and less related to CFD/OpenFOAM. Keep reading under your responsibility.
See following:
me@work:~$ foamMon
me@work:~$ find $HOME/.local/lib/python3.5 -name "FoamDataStructures.py"
/home/me/.local/lib/python3.5/site-packages/FoamMon/FoamDataStructures.py
me@work:~$ cd $HOME/.local/lib/python3.5/site-packages/
me@work:~/.local/lib/python3.5/site-packages$ tree -L 1 ./
├── colorama
├── colorama-0.3.9.dist-info
├── docopt-0.6.2.dist-info
├── docopt.py
├── easy-install.pth
├── FoamMon
├── foamMon-0.0.0-py3.5.egg
├── foamMon-0.2.2.dist-info
├── foamMon-0.2.3.dist-info
├── __pycache__
├── urwid
└── urwid-2.0.1.dist-info
9 directories, 3 files
me@work:~/.local/lib/python3.5/site-packages$ ls foamMon* FoamMon
FoamMon:
cui.py  FoamDataStructures.py  header.py  __init__.py  Log.py  __pycache__  version.py
foamMon-0.2.2.dist-info:
INSTALLER  METADATA  RECORD  top_level.txt  WHEEL
foamMon-0.2.3.dist-info:
As I said, I am not an expert in Pyhon, but I noticed that the errors correspond to code lines of the type:
from .<filename-starting-with-a-dot> import <some-class>
Furthermore, it searches files at
(foamMon-0.0.0-py3.5.egg is not a directory) that are actually in
Old   September 7, 2018, 11:10
Gregor Olenik
If you have a github account we could move the discussion to https://github.com/greole/foamMon/issues
Regarding the import issue: Could you remove the /home/me/.local/lib/python3.5/site-packages/foamMon-0.0.0-py3.5.egg folder, and try again?
Old   September 7, 2018, 18:22
Rodrigo
Hi Gregor,
I've just tried it again at home from another machine (Ubuntu 18.04) and everything works fine finally. I will debug myself the installation in my other machine after the weekend, so don't worry anymore for it.
Installation steps for the interested reader:
Warning: If you are using Ubuntu, it is currently not a good idea to update pip from pip (despite pip's suggestion)
add following line to the .bashrc file (Gregor, you may want to add this step to the instructions in the repository README file):
export PATH="$PATH:$HOME/.local/bin"
Note: Don't forget to reload the bash profile (or simply open a new terminal) after doing it.
... and that's it. It is a small great tool! Quite intuitive and useful. Just 2 questions:
- What does "Writeout" indicate? it looks like how long it would take to fill up the storage capacity at this writing rate... is it right?
- What does "Press (T) to toggle active" does? I keep pressing it (both "T" and "t") but it seems to have no effect.
Thanks again Gregor for the help!
PS: Is there any administrator among the readers willing to move this thread to the Community Contributions section?
Old   September 10, 2018, 05:07
Gregor Olenik
Hi Rodrigo,
thanks for your feedback und for testing.
- "Writeout" is the estimated time till a new timestep is written to disk.
- "T" should hide all cases that are currently not running. I think it is not active at the moment.
Currently there still some bugs and rough edges, which I'll try to fix over time.
Cheers,
Gregor
guin likes this.
Old   September 24, 2018, 10:23
Gregor Olenik
Ok, since I cannot move this thread, I created a new one New foamMon version 0.2.5
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
