Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
isoAdvector in OpenFOAM-v1706+
Like Tree11Likes
  • 10 Post By roenby
  • 1 Post By roenby
Old   July 4, 2017, 08:45
Default isoAdvector in OpenFOAM-v1706+
Johan Roenby
roenby will become famous soon enough
Dear FOAM'ers
It is a pleasure to announce that the isoAdvector algorithm has now been integrated into the newest release of OpenFOAM from ESI-OpenCFD.
The algorithm has been integrated into a new solver called interIsoFoam, and a number of test cases - including both pure advection and coupling with the p-U solver - are included. Further, the code has been improved in several ways:
  • Consistent behaviour with more than one outer corrector. Running with nOuterCorrectors > 1 can increase accuracy of nonlinear terms but will also increase computational cost.
  • Support for subcycling (nAlphaSubCycles). Whether subcycling is an advantage will depend on the specific case and will require some experimentation.
  • Should now be more stable, especially when running in parallel due to clean up of the functions isoCutFace::cutPoints and isoCutFace::quadAreaCoeffs.
  • Option for smoothed gradient based interface orientation in reconstruction step (gradAlphaNormal = true). Guarantees piecewise planar interface and seems to improve results on triangular prism meshes. The isoAdvector advection step is not changed by this option.
  • Optional writing out of isoFaces.obj, of surface cellSet and heuristically bounded cellSet.
  • General code clean up and refactoring.
For further info please see:
http://openfoam.com/releases/openfoa...cs-isoadvector
Best regards,
Johan
wyldckat, Ohbuchi, Cyp and 7 others like this.
roenby is offline   Reply With Quote
Old   August 17, 2017, 14:59
Default New isoAdvector release on github
Johan Roenby
This information is relevant for people who downloaded the isoAdvector code from github.com before 8 August 2017. Up to the release of isoAdvector in OpenFOAM-v1706, I made a number of improvements to the code, some of which should make it more stable.
See release note here for details:
I ported these changes to the github.com/isoAdvector version 30 June 2017 and went on holiday. Unfortunately, the new updates broke the compatibility with older OpenFOAM versions, which resulted in compile errors. These should now be fixed with the latest release on github from 8 August 2017. If you encounter further compilation problems with OpenFOAM-2.2.0 or newer, please don't hesitate to let me know.
Daniel_Khazaei likes this.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 04:43
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
