Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
Caelus v6.04 released
Like Tree2Likes
  • 2 Post By cnsidero
Old   April 22, 2016, 11:35
Default Caelus v6.04 released
Chris Sideroff
cnsidero is on a distinguished road
The next major version of Caelus, 6.04, was released today. We’ll continue to stick to bi-annual releases with 6.10 coming in October. Much of the effort this release was spent overhauling interpolation schemes. Here’s a brief list:
  • Restructuring of interpolation schemes (central and upwind) to use consistent limiting
  • Overhaul of limiters to ensure TVD compliance
  • Updates to pressure and density-based compressible solvers
  • New combustion solvers
  • New gammaReTheta transition, kOmegaSSTDES and DDES and SA-VLES turbulence models
The other news is there is now a publicly available source repository to enable better community collaboration:
https://bitbucket.org/appliedccm/caelus-contributors
There is a release notes PDF available on the download page with more descriptions. http://www.caelus-cml.com/download/
If you’re not already familiar with Caelus, you can read more about it on the website. Its free and open-source. The file formats are compatible with OpenFOAM but there have been many improvements to it such that it is now moving independently in its own direction.
We are happy to answer questions, technical or otherwise, by email: caelus@appliedccm.com or also follow Caelus on twitter @caelus_cml
Applied CCM is currently the maintainer and main developer of Caelus. If you’re interested in porting or developing your own application to Caelus, we’ll be happy to provide guidance. If you’ve developed a solver or model that you would like to include in Caelus check out the contributors repository. Any and all external contributors copyright will be kept in their contributed source files.
wyldckat and dybuk like this.
cnsidero is offline   Reply With Quote
Old   April 26, 2016, 20:36
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Will the linux binary version work on openSuSe 13.2?
Pei-ying
phsieh2005 is offline   Reply With Quote
Old   April 27, 2016, 10:56
Pei-Ying Hsieh
I installed Caelus-6.04 on OpenSUSE 13.2. The serial solver ran, but, got errors when tried to run in parallel.
I am wondering how I can get caelus to use system openmpi. It looks like caelus tried to look for openmpi-1.6.5 under /opt/caelus/caelus-4.10.
Recommendations will be appreciated.
Pei-Ying
Old   April 27, 2016, 16:19
Chris Sideroff
Pei-Ying,
We don't build/test on SUSE but I have helped someone previously with issues running Caelus on SUSE.
To your issue, it looks like you left the default OpenMPI (the one Caelus provides) when you installed Caelus rather than configure it to use the system MPI. Caelus is complaining because it's looking to the provided MPI libraries and you're using the system MPI executables. To fix it, follow these steps.
In "lib/python2.6/Caelus/conf.py" change to the following:
MPI_BIN = '/usr/lib64/mpi/gcc/openmpi/bin'
MPI_LIB = '/usr/lib64/mpi/gcc/openmpi/lib64'
MPI_INC = '/usr/lib64/mpi/gcc/openmpi/include'
in the "etc/caelus.bashrc":
export MPI_INC=/usr/lib64/mpi/gcc/openmpi/include
export MPI_LIB=/usr/lib64/mpi/gcc/openmpi/lib64
export MPI_LIB_NAME=mpi
and create a dynamic link like so:
sudo ln -s /usr/lib64/mpi/gcc/openmpi/lib64/libmpi.so /usr/lib64/mpi/gcc/openmpi/lib64/libmpi.so.1
Finally to get the Python wrapping to work in parallel modify the "etc/controlDict" as follows (note the bold terms):
parRunTemplate "mpiexec -n %(NPROCS)d %(PAROPTS)s  --mca btl sm,self  %(APPLICATION)s  %(ARGS)s -parallel";
Let me know if the fixes things.
Perhaps we'll look into including a SUSE distribution as a future supported platform.
-Chris
Old   April 28, 2016, 08:47
Pei-Ying Hsieh
Thanks a lot Chris!
Everything works perfectly on OpenSUSE 13.2 now.
Now, I just need to figure out how to compile a new solver using scon.
Pei-Ying
Old   April 28, 2016, 09:23
Chris Sideroff
Pei-Ying,
Glad to hear its working. I replied to your email about using scons.
-Chris
Old   May 11, 2016, 06:18
Default DNS Turbulence modelling in vofLPTSolver
ANIRBAN MONDAL
anirbanmondal93 is on a distinguished road
Send a message via Skype™ to anirbanmondal93
hi guys,
I am running the case vofLPTSolver in CAELUS-6.04. It is basically a case relating to simulation of a number of lagrangian bubble particles (lagrangian particle tracking) in continuous water phase (VOF) using LES turbulence model. But i want to simulate the same test case using DNS turbulence modelling inspite of LES approach.
What modifications i have to do in the existing '...tutorials/vofLPTSolver' directory or in any other directories in CAELUS?
Thanks in advance.
regards,
Anirban
anirbanmondal93 is offline   Reply With Quote
Old   May 11, 2016, 18:25
Chris Sideroff
Anirban,
No modifications to the solver are necessary. To run DNS means no explicit turbulence modelling (LES, RAS, etc). Therefore to disable an explicit LES model, in the constant/LESProperties dictionary change LESModel from Smagorinsky to laminar.
-Chris
Old   May 17, 2016, 11:01
ANIRBAN MONDAL
Hi Chris,
Greetings
I am running tutorials/vofLPTSolver in Caelus-6.04 changing different values and variables in some files within this directory to simulate lagrangian bubble particles rising in water with VOF free surface capturing using DNS only. But, i am confused whether the injection particles are air bubbles or water after seeing the value of alpha1 in animation.
I am mentioning two cases with the details of the changing stuff i have done.
Case-1:
$Caelus/../ACCM_bubbleCol3D/Allrun.py- line 69: omitting '-parallel': run = subprocess.Popen(['caelus.py', '-l', 'vofLPTSolver'], shell=pltfrm)
$Caelus/../
ACCM_bubbleCol3D/system/controlDict- line 22: endTime 10;
Case-2:
same changes as in case-1.
additional changes-
$Caelus/../ACCM_bubbleCol3D/system/controlDict-
line 28: writeInterval 1;
$Caelus/../ACCM_bubbleCol3D/bubbleCloudproperties-
line 153: changing threshold value from 0.5 to 0: threshold 0;
Caelus/../ACCM_bubbleCol3D/LESProperties-
line 15: replacing Smagorinsky with laminar to switch on DNS as per your suggestion: LESModel laminar;
Attaching two case animation separately what i have made.
Case-1: https://www.youtube.com/watch?v=o1Uh...ature=youtu.be
Case-2: https://www.youtube.com/watch?v=WJ1r...ature=youtu.be
Old   September 8, 2016, 03:01
Default vofLPT solver- solid particle tracking? works in Parallel?
vidyadhar
vidyadhar is on a distinguished road
Hello Chris,
I want to work with vofLPTSolver to track solid particles in liquid flow.
I have certain basic questions:
1.whether this solver can be run in parallel.
2. Does this solver treats fluid phase as continuum and particles as individual lagrangian identities?
3. Also, does this solver handles solid particles?
Request you to kindly let me know.
Thanks & Regards,
Vidyadhar
Originally Posted by cnsidero View Post
Anirban,
-Chris
vidyadhar is offline   Reply With Quote
Old   September 8, 2016, 15:46
Chris Sideroff
Vidyadhar,
1. Yes, the solver is fully parallel just like all the other solvers.
2. Yes, the fluid is a continuum and the particles are treated as discrete Lagragian objects.
3. The particles behavior is defined by their density and size. With the current implementation the particles do not change size. Therefore, yes, you could specific particle properties for a solid material.
Regards, Chris
Old   September 19, 2016, 02:39
Default DPMFoam, MPPICFoam vs vofLPTsolver????
  #12
vidyadhar
Hello Chris,
Thanks for the reply.
Actually, I want to simulate lagrangian particle (bubbles as well as solids) flows in a liquid.
Can you clarify if DPMFoam solver or MPPICFoam solver of openfoam 4.0 can't do this job. Do they solve only solid particle tracking? Because I want to simulate bubble tracking also!
If I have to use caelus, can you help me how to install it on ubuntu 16.04.
Or Is caelus can be installed on ubuntu 14.04 only?
Thanks
Old   September 19, 2016, 07:51
Default Paralllel command in caelus 6.04??
  #13
vidyadhar
I just installed caelus6.04.
How to execute commands in terminal to use this software.
Also, how to execute a solver in parallel. Which command is to be used.
Thanks.
Old   September 19, 2016, 07:59
Default Error while executing vofLPTSolver in parallel
  #14
vidyadhar
Hi Chris,
I have installed caelus 6.04. I tried using vofLPTSolver with the following command, but I got the errors messages as shown below; Can you please help me in using this solver in parallel!!! Thank you.
caelus.py vofLPTSolver -parallel
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
*** An error occurred in MPI_Init
*** on a NULL communicator
*** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
[iitmech5:17307] Local abort before MPI_INIT completed successfully; not able to aggregate error messages, and not able to guarantee that all other processes were killed!
Sorry! You were supposed to get help about:
opal_init:startup:internal-failure
But I couldn't open the help file:
/opt/caelus/caelus-4.10/external/linux/openmpi-1.6.5/share/openmpi/help-opal-runtime.txt: No such file or directory. Sorry!
[iitmech5:17307] [[INVALID],INVALID] ORTE_ERROR_LOG: Error in file runtime/orte_init.c at line 79
mpi_init:startup:internal-failure
/opt/caelus/caelus-4.10/external/linux/openmpi-1.6.5/share/openmpi/help-mpi-runtime: No such file or directory. Sorry!
Old   September 19, 2016, 12:08
Chris Sideroff
Vidyadhar,
Let me try to catch up to your questions. Let's diagnose the runtime issues first.
It appears you are using Ubuntu Linux 16.04. Please confirm this.
Which Caelus package did you install? The binary installer or the source-only installer? If it's the later, you will need to compile it using the provided BuildCaelus.py script in the top-level directory.
If you're confident the binaries are there, can you try running the vofLPTSolver tutorial with the AllRun.py script?
Let's start there and I'll answer the earlier questions after.
-Chris
Old   September 19, 2016, 14:06
vidyadhar
Hello Chris,
Yes I am using ubuntu 16.04.
I have installed the binary installer(Caelus 6.04 source code and binary installer).
I have opened AllRun.py file in ACCM_bubbleCol3D of vofLPTSolver casefile and followed the operations therein: Executing blockMesh, setSet, createPatch, setFields, decomposePar force, vofLPTSolver--- Finally vofLPTSolver.log file has been created in the ACCM_bubbleCol3D directory which has the following messages:
[iitmech5:09519] [[INVALID],INVALID] ORTE_ERROR_LOG: Error in file runtime/orte_init.c at line 79
[iitmech5:9519] Local abort before MPI_INIT completed successfully; not able to aggregate error messages, and not able to guarantee that all other processes were killed!
[iitmech5:9520] Local abort before MPI_INIT completed successfully; not able to aggregate error messages, and not able to guarantee that all other processes were killed!
[iitmech5:9521] Local abort before MPI_INIT completed successfully; not able to aggregate error messages, and not able to guarantee that all other processes were killed!
[iitmech5:9522] Local abort before MPI_INIT completed successfully; not able to aggregate error messages, and not able to guarantee that all other processes were killed!
[iitmech5:9523] Local abort before MPI_INIT completed successfully; not able to aggregate error messages, and not able to guarantee that all other processes were killed!
[iitmech5:09526] [[INVALID],INVALID] ORTE_ERROR_LOG: Error in file runtime/orte_init.c at line 79
[iitmech5:9526] Local abort before MPI_INIT completed successfully; not able to aggregate error messages, and not able to guarantee that all other processes were killed!
mpiexec detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[43169,1],1]
Exit code: 1
Thank you for the patient reading.........!!!!!
Old   September 19, 2016, 20:10
Chris Sideroff
Are the other steps running OK? What do the other log files say? Need to find out if it's one of the other steps failing.
Old   October 1, 2016, 14:15
Default errors when boundary conditions are modified in vofLPT solver
  #18
vidyadhar
Hello Chris,
I have used the vofLPT solver successfully for the given tutorial case-ACCM_bubblecolumn3D, where the fluid is at rest and bubbles are moving.
But, I want to simulate when the fluid is flowing through the column. (I have modified the column to be full of water.)
The changes made by me are:
In blockMeshDict: bottom is made to patch from wall, as I would like to flow in water through bottom patch.
In U: bottom is made to fixedValue uniform (0 0.08 0), top as zeroGradient.
In p_rgh: top is made to fixedValue uniform 0.
I tried with various boundary conditions for U and p_rgh, but I could run only till time=3 s. After that Courant number is increasing largely, volume fraction Alpha1 is also becoming very large and I am getting errors as below:
Courant Number mean: 2.387736012e+97 max: 1.998894153e+101
Interface Courant Number mean: 2.488915823e+96 max: 2.311900924e+100
Time = 3.81
Evolving bubbles
Solving 3-D cloud bubbleCloud
--> Cloud: bubbleCloud injector: model1
Added 2 new parcels
Cloud: bubbleCloud
Current number of parcels = 2907
Current mass in system = 0.0001668853125
Linear momentum = (-nan -nan -nan)
|Linear momentum| = -nan
Linear kinetic energy = -nan
Rotational kinetic energy = 0
model1:
number of parcels added = 9119
mass introduced = 0.0005142614062
Parcels absorbed into film = 0
New film detached parcels = 0
Parcel fate (number, mass)
- escape = 147, 0
- stick = 0, 0
MULES: Solving for alpha1
Phase-1 volume fraction = 1.774412665e+87 Min(alpha1) = -1.333103629e+102 Max(alpha1) = 2.357171278e+102
Phase-1 volume fraction = -4.252960616e+259 Min(alpha1) = -5.124760501e+280 Max(alpha1) = 5.031106494e+280
PIMPLE: iteration 1
DILUPBiCG: Solving for Ux: solution singularity
DILUPBiCG: Solving for Uy: solution singularity
DILUPBiCG: Solving for Uz: solution singularity
GAMG: Solving for p_rgh, Initial residual = nan, Final residual = nan, No Iterations 1000
MPI_ABORT was invoked on rank 4 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[2]
[2]
[2] --> CAELUS FATAL IO ERROR:
[2] wrong token type - expected Scalar, found on line 0 the word 'nan'
[2]
[2] file: /home/mech5/vofLPTSolver/vofLPTSolvertestedfor5s/ACCM_20processors-COMPLETEWATER_BC_MODIFIED/processor2/system/data::solverPerformance:_rgh at line 0.
[2]
[2] From function operator>>(Istream&, Scalar&)
[2] in file core/primitives/Scalar/doubleScalar/doubleScalar.cpp at line 98.
[2]
CAELUS parallel run exiting
May I know the correct boundary conditions for the flow of fluid along with bubbles.
Also, can you please brief me about p_rgh & how it is different from p.
Thanks & Regards,
vidyadhar
Old   October 2, 2016, 09:37
vidyadhar
Vidyadhar,
Regards, Chris
Hello Chris,
1. I tried using vofLPT solver for bubbles. It was working fine.
But, I have doubt regarding Youngs Modulus and Poissons ratio for bubbles in the bubble cloud properties file. Are they meant for bubbles only? Please clarify.
2.Now I would like to use the same for simulating solid particles. I have changed the density. But, I am facing the problem with viscosity of phase2 in transport properties file under constant directory.
Can you please let me know how to go about this.
Thank you.
Old   October 4, 2016, 09:27
vidyadhar
Hello chris,
I am using vofLPT solver of caelus 6.04.
In bubbleCloudProperties file:
I would like to understand the meaning of the terms such as parcel and particle. Are they same or different?
Also, how to calculate no.of parcels per second? Does this value depend on the run time of the simulation?
injectionModels
model1
type patchInjection;
patchName inlet; // Name of patch
SOI 0; // Start Of Injection
flowRateProfile constant 1; // Flow rate profile relative to SOI
massTotal 0.02025; // Total mass injected over injection duration
parcelBasisType mass; // How are the number of particles calculated
duration 7; // Duration of injection. NOTE: set to 1 for steady state
U0 (0 0.08 0); // Initial parcel velocity
parcelsPerSecond 3357; // Number of parcels to introduce per second
sizeDistribution
type fixedValue;
fixedValueDistribution
value 4e-03;
Can you please help me in understanding this. Thank you
Modelling a Released Gate whk1992 OpenFOAM Running, Solving & CFD 1 June 13, 2016 06:21
Caelus v5.10 Released cnsidero OpenFOAM Announcements from Other Sources 12 April 22, 2016 11:43
Caelus v5.04 released cnsidero OpenFOAM Announcements from Other Sources 0 April 30, 2015 13:28
OpenFOAM Version 1.3 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 29, 2006 19:06
OpenFOAM Version 1.0.2 Released Admin (Admin) OpenFOAM Announcements from ESI-OpenCFD 0 January 12, 2005 07:33
