Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
Caelus v5.10 Released
Like Tree6Likes
  • 2 Post By cnsidero
  • 1 Post By cnsidero
  • 1 Post By darrin
  • 2 Post By darrin
Old   October 26, 2015, 23:31
Default Caelus v5.10 Released
Chris Sideroff
cnsidero is on a distinguished road
The next major version of Caelus, 5.10, was released today. We’ll continue to stick to bi-annual releases with 6.04 coming next April. The big addition was compressible capabilities as well a new turbulence model class and updates to the function objects. Here’s a brief list:
  • New implicit pressure-based and explicit density-based compressible solvers
  • Multi-phase VOF solver with Lagrangian particle tracking for use with, for example, sub-grid bubble modelling
  • Very-Large Eddy Simulation (VLES) turbulence model class
  • Compressible turbulence models
  • Coherent structure LES model
  • Improved central-based interpolation schemes
  • Updates to the run-time post-processing library, function objects
There is a release notes PDF available on the download page with more descriptions. http://www.caelus-cml.com/download/
If you’re not already familiar with Caelus, it was originally forked from OpenFOAM. You can read more about it in the original announcement post. That means its free and open-source as well. The file formats are compatible but there have been many improvements to it such that it is now moving independently in its own direction.
We are happy to answer questions, technical or otherwise, by email: caelus@appliedccm.com or also follow Caelus on twitter @caelus_cml
Applied CCM is currently the maintainer and main developer of Caelus. If you’re interested in porting or developing your own application to Caelus, we’ll be happy to provide guidance. If you’ve developed a solver or model that you would like to include in Caelus that can be arranged and we’ll be sure to keep your copyright in your source files.
Thanks, Chris
Ohbuchi and dybuk like this.
cnsidero is offline   Reply With Quote
Old   April 2, 2016, 16:18
Default post-processing in Caelus
Carlos
Carlos.cuba is on a distinguished road
I am running the tutorials in Caelus 4.10. The tutorials seem to run fine but I am not sure how to post-process the results. I downloaded paraview 5.0 and I tried to open the data files created by Caelus with no success. Any pointers will be appreciated,
Carlos
Carlos.cuba is offline   Reply With Quote
Old   April 3, 2016, 22:34
Chris Sideroff
Carlos,
Create an empty file with an extension .foam in the case directory. ParaView will recognize the .foam file and load the case with it's OpenFOAM reader.
A quick way to do so from the terminal:
$> touch mycase.foam
-Chris
Carlos.cuba likes this.
Old   April 4, 2016, 03:23
Darrin Stephens
darrin is on a distinguished road
Carlos,
At present Caelus uses the same mesh and results format as OpenFOAM. As Chris said just create a file with the extension .foam in your case directory.
If you have any further questions, feel free to contact us at caelus@appliedccm.com
Regards,
Darrin
darrin is offline   Reply With Quote
Old   April 4, 2016, 03:28
Carlos
Thank you very much guys for all your help!
Carlos
Old   April 13, 2016, 02:45
Default Can Gmsh be used in Caelus 5.10?
Carlos
I have created a mesh in Gmsh. Can I use this mesh in Caelus 5.10? if so how?
Many thanks,
Carlos
Old   April 13, 2016, 09:18
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
I am wondering when 6.04 will be released. Should I wait for 6.04 or install 5.10 now?
One thing I am interested in is VOF - LPT coupling. Also curious about what new features will be added in 6.04.
Pei-Ying
phsieh2005 is offline   Reply With Quote
Old   April 13, 2016, 18:31
Darrin Stephens
Hi Carlos,
Caelus 5.10 doesn't have a converter for gmsh. You have two options, port the gmshToFoam utility or wait a couple of weeks and use Caelus 6.04 as it will have a gmshToCaelus utility.
If you cannot wait send an email to caelus@appliedccm.com and I will send you the code for gmshToCaelus to use with Caelus 5.10.
Regards,
Darrin
Old   April 13, 2016, 18:47
Darrin Stephens
Hi Pei-Ying,
Caelus 6.04 will be released before the end of April (this month). We are in the final stages of our test loop verifying all 9 supported platforms before producing the installers.
Regarding new features, the release notes will have a comprehensive list, but a brief outline is:
Top level solvers and utilities
1) Compressible solvers:
1a) cpbnsPIMPLE and cpbnsLTS now use limited/unlimited central flux formulation
1b) Addition of the dominant wave numeric flux for explicitiDBNSSolver
2) Combustion solvers:
2a) Introduction of reactingSolver with the Arrhenius rate chemical ODE solver. Caelus chemical mechanism format supported.
3) Utilities:
3a) gmshToCaelus
Library changes:
1) Numerous bug fixes, native and back ported from OpenFOAM versions.
2) Surface interpolation changes in support of TVD discretization: More detail will be provided in release notes.
3) Turbulence library:
3a) New SpalartAlamarasVLES model for both compressible and incompressible flows.
3b) Explicit control of near wall behaviour in VLES models.
3c) New gammaReTheta model for turbulent transition in incompressible flows.
We are always happy to listen to users views on future developments. Feel free to drop us an email at caelus@appliedccm.com.au to share your views.
Regards,
Darrin
phsieh2005 and Carlos.cuba like this.
Old   April 13, 2016, 20:52
Carlos
Many thanks for your reply. I was just wondering how can I port the gmshToFoam utility to be used in Caelus?
Regards,
Carlos
Old   April 13, 2016, 22:01
Darrin Stephens
Hi Carlos,
Read this blog article http://www.appliedccm.com/porting-a-...ver-to-caelus/ for the procedure of porting solvers and utilities to Caelus.
Regards,
Darrin
Old   April 13, 2016, 23:08
Carlos
Thank you for your response. I think I will wait for Caelus 6.04. Caelus is very easy to use.
Many thanks again!
Carlos
Old   April 22, 2016, 11:43
Chris Sideroff
Caelus 6.04 was released today: http://www.caelus-cml.com/download/
Caelus v5.04 released cnsidero OpenFOAM Announcements from Other Sources 0 April 30, 2015 13:28
IcofsiFoam not supported under released 141 package pi06jl6 OpenFOAM Running, Solving & CFD 4 June 26, 2008 14:59
OpenFOAM Version 1.3 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 29, 2006 19:06
OpenFOAM Version 1.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 11, 2005 06:33
OpenFOAM Version 1.0.2 Released Admin (Admin) OpenFOAM Announcements from ESI-OpenCFD 0 January 12, 2005 07:33
