Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
RichardsFOAM, a solver for water flow in unsaturated porous media
Like Tree10Likes
  • 5 Post By Orgogozo
  • 1 Post By Orgogozo
  • 1 Post By rakesh927
  • 1 Post By wavefunction
Old   October 14, 2014, 09:29
Default RichardsFOAM, a solver for water flow in unsaturated porous media
Laurent Orgogozo
Orgogozo is on a distinguished road
Dear Foamers,
Please find attached a homemade OpenFOAM solver for Richards equation, an equation of flow of water within variably saturated porous media (e.g. : soils). You may find additional details related to RichardsFOAM in the following paper :
http://authors.elsevier.com/a/1PsPx2OInFfaV
A careful attention is paid to the parallel behaviour of the solver.
Key words: geosciences, hydrosciences, transfer into soils, flows in porous media,
parallel computing, strong scaling, weak scaling,
impact of I/O on computational performances.
Best regards,
Laurent Orgogozo Universtity Of Toulouse Geosciences Environment Toulouse Laboratory
Cyp, wayne14, ZhoujiangZho and 2 others like this.
Last edited by wyldckat; March 21, 2015 at 15:24. Reason: fixed broken formatting at the start of the post
Orgogozo is offline   Reply With Quote
Old   November 21, 2014, 14:51
Laurent Orgogozo
Dear Foamers,
One can find additionnal information on RichardsFOAM (e.g.: conference presentation) on this web page :
www.richardsfoam.info
All the best,
Laurent
Old   March 21, 2015, 15:55
Retired Super Moderator
Bruno Santos
Greetings Laurent,
I've created a basic wiki page for your solver at openfoamwiki.net, so that it's a bit easier for people to find it: http://openfoamwiki.net/index.php/Contrib/RichardsFOAM
Best regards,
Bruno
Old   October 6, 2015, 09:21
Default New version of RichardsFoam
Laurent Orgogozo
Dear foamers,
A new version of RichardsFoam, RichardsFoam2, has been recently published in Computer Physics Communications.
http://authors.elsevier.com/a/1Rkjj2OInJTkZ
The main new features are the direct handling of the evapotranpiration and the possibility of deal easily with fully heterogeneous porous media. Thus this new version is more suitable for modelling of water transfers in the vadose zone.
You will find additionnal details (e.g.: source code, conferences and seminar slides) on
Cheers,
Laurent
wyldckat likes this.
Old   November 24, 2016, 10:03
Default new version of RichardsFoam2 for OF-v1606+
Laurent Orgogozo
Dear Foamers,
The solver RichardsFoam2 in its former version is not compatible with OF-v1606+. In order to fix that a new version has been done, and you may find this new version at the following url :
All the best,
Laurent
Old   November 21, 2017, 13:51
Default RichadsFoam2 use
xirtam's Avatar
Fábio
xirtam is on a distinguished road
Dear Laurent, I need to simulate the infiltration of water into the soil. I was able to compile RihcardsFoam2 using the cfdsupport.com version for Windows. But it's showing 'nan' when I run. Initially I will not need the effects of evapotranspiration. Would you help me?
xirtam is offline   Reply With Quote
Old   November 22, 2017, 15:32
Laurent Orgogozo
Dear Xirtam,
I never used OF under a windows OS, so I fear I can't help you.
Regards,
Laurent
Old   March 27, 2018, 06:46
rakesh927's Avatar
rakesh
rakesh927 is on a distinguished road
Dear Laurent,
I could compile RichardsFoam2 in OF-v1712, however while running the validation case, it's showing the error
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4  ? at ??:?
#5  ? at ??:?
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7  ? at ??:?
Floating point exception (core dumped)
Kindly help me, where it's getting wrong. Is it related to setting up of initial conditions of the domain?
Thanks,
Rakesh
rakesh927 is offline   Reply With Quote
Old   March 27, 2018, 07:13
Laurent Orgogozo
Dear Rakesh,
Did you try the updated version of RichardsFoam2 avalaible at :
Old   March 27, 2018, 07:24
rakesh927's Avatar
rakesh
Dear Laurent,
Yes, I have tried RichardsFoam2 for OF-v1606+ mentioned in the link.
Old   March 27, 2018, 08:25
Laurent Orgogozo
OK, then there are clearly somethings to be done to solve the problem. I have no time left for that now, but I will do it soon, likely by the end of april, surely before the end of may. Until that, please stay in of-v1606+ when you want to use RichardsFoam2.
All the best,
Laurent
Old   May 10, 2018, 07:33
rakesh927's Avatar
rakesh
I got the solution for the error I was facing with.
Simply replace the function
pos()
with
pos0()
in the original code of Orgogozo and recompile the solver.
Rakesh
Old   May 11, 2018, 05:10
Laurent Orgogozo
Dear Rakesh,
Thanks a lot for the hint ! I will deliver an updated RichardsFoam2 package for OF-v1712 in the following weeks.
All the best,
Laurent
rakesh927 likes this.
Old   June 1, 2018, 05:47
Saicharan
wavefunction is on a distinguished road
Hello. Could anyone please let me know what is the function of the pos() and pos0() functions?
In interMixingFoam, a volScalarField called nearInterface is defined that takes the value of 1 if it is near the interface and 0 if it is not.
Foam::tmp<Foam::volScalarField>
Foam::threePhaseInterfaceProperties::nearInterface() const
    return max
        pos0(mixture_.alpha1() - 0.01)*pos0(0.99 - mixture_.alpha1()),
        pos0(mixture_.alpha2() - 0.01)*pos0(0.99 - mixture_.alpha2())
How is this done?
wavefunction is offline   Reply With Quote
Old   June 1, 2018, 09:33
Laurent Orgogozo
Dear Saichara,
pos(x), where x is a volScalarField, is a volScalarField that is equal to 0 wherever x is negative and equal to 1 wherever x is positive.
Regards,
Laurent
wavefunction likes this.
Old   June 1, 2018, 09:41
rakesh927's Avatar
rakesh
pos(x)=
(x>0)?1:0
pos0(x)=
(x>=0)?1:0
Old   June 1, 2018, 09:46
Default Thank you!
  #17
Saicharan
Thanks a lot for your replies. You helped me out a lot. Sorry I couldn't find it out myself. I tried using the grep command as well but I was unable to find what this means. Anyways, now I know.
Old   July 2, 2018, 09:13
Default RichardsFoam2 package for OpenFOAM-V1712
  #18
Laurent Orgogozo
Dear foamers,
Please find in ResearchGate the updated RichardsFoam2 package, compatible with the version v1712 of OpenFOAM.
https://www.researchgate.net/publica...OpenFOAM-v1712
All the best,
Laurent
Old   April 3, 2019, 07:24
Default permaFoam, an extension of RichardsFoam for cold region hydrology
  #19
Laurent Orgogozo
Dear Foamers,
I kindly drive your attention on a new born OpenFOAM solver for Geosciences: the permaFoam solver (Orgogozo et al., 2019), which deals with coupled heat and water transfers in porous media with freeze/thaw of the pore water. The main related field is permafrost modelling, but there are also other fields of applications such as geotechnics or environmental engineering. Please find below the web-sites in which you can find the solver and the related paper.
All the best,
Laurent Orgogozo
https://www.researchgate.net/publica...rSjAvFKgNhOvVQ
https://www.researchgate.net/publica...ozo_et_al_2019
https://www.researchgate.net/publica..._rooting_depth
https://onlinelibrary.wiley.com/doi/....1002/ppp.1995
Old   October 11, 2021, 08:55
Default RichardsFoam3 release
  #20
Laurent Orgogozo
Dear foamers,
Please find through the link below the new version announcement for RichardsFoam3, an update of RichardsFoam that encompasses new boundary conditions that are handier for hydrogeology, more flexible use through on-the-fly handling of linearisation processes, and other improvements.
https://doi.org/10.1016/j.cpc.2021.108182
The RichardsFoam3 package may be found both in the Computer Physics Communications Code Library and in the develop.openfoam.com/community interface.
https://doi.org/10.17632/vkr7sd6fhb.1
https://develop.openfoam.com/Community/hydrology/
This new version has been developped in the framework of the HiPerBorea project (hiperborea.omp.eu).
Best wishes,
Laurent Orgogozo
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Flow through porous media: permeability issue butterfly1 Main CFD Forum 1 January 2, 2014 03:34
multiphase flow in porous media zhou FLUENT 2 August 9, 2012 08:10
compressible flow through porous media Chirag2302 FLUENT 0 March 3, 2012 00:13
Water flow in porous media under unsaturated conditions gallay OpenFOAM Running, Solving & CFD 0 August 27, 2008 10:52
