Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
New OpenFOAM PhD Thesis available for downloading
Like Tree44Likes
  • 44 Post By santiagomarquezd
Old   August 13, 2013, 10:53
Default New OpenFOAM PhD Thesis available for downloading
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi all, I defended my PhD thesis en March, 2013. It was available only for reading since not all reviews were applied, now this process has finished and it can be downloaded through the respective link provided in my user page at openfoamwiki.net: http://openfoamwiki.net/index.php/User:Santiagomarquezd
The topics covered are the following:
  • A general description of FVM discretization
  • An explanation of the FOAM's TVD framework
  • The PISO algorithm
  • An explanation of the MULES limiter (maybe the only one available in citable form)
  • The presentation of the Alebraic Slip Mixture Model (ASMM)
  • The writing of ASMM in center-of-volume velocity formulation
  • Solving some analytical examples with the ASMM
  • A Riemman-free solver included a centered flux at faces
  • An complete description of the interFoam (Volume of Fluid Solver)
  • The implementation of an ASMM solver
  • A presentation of an extended mixture solver from ASMM and VOF with examples
I hope you find this new material useful and I'm open to suggestions or questions about the topics presented in the thesis.
Keep FOAMing.
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   May 20, 2014, 06:34
Timm Severin
Astrodan is on a distinguished road
Hi Santiago,
first of all, thank you for your thesis. I just read about 3 chapters of it and found it quite interesting, especially the ASMM and the Extended Model.
Since in my thesis I will also have to deal with multiphase flows I am currently trying to figure out which options I have. Unfortunately my mixture will contain low loads of particles (that I consider as solid, but very small and thus with a fluid like behaviour), a liquid phase and - in some cases - air. So far I have considered to apply the mixture model presented by Ishii and Hibiki to resolve the Solid/Liquid interaction and wanted to add this to a VOF solver.
Now, since I read your thesis, I understand that ASMM is based on the mixture model, and your extended model on ASMM, thus it should be possible to use it to solve the three-state mixture as whole. Are you aware of any test cases in this area, or have you (or a colleague) done any development regarding this? I had a short glance at the thesis of Bohorquez, but am not convinced that it is the droid I am looking for.
Furthermore: Is there any publicly available implementation of your solver? I haven't found anything so far.
Thank you so far,
-Timm
P.S.: You got some neat vector based graphics, which program(s) did you use to draw them?
PhD Student at the Institute of Biochemical Engineering at TU München
Modelling of fluid dynamics in open photobioreactors.
System:
OpenFOAM 2.3.x, 64bit, 8 Core Xeon Workstation
Astrodan is offline   Reply With Quote
Old   May 21, 2014, 07:47
Elvis
elvis will become famous soon enough
Hi Santiago,
I hope that something of your thesis could also find its way to
http://www.cocoons-project.org/
elvis is offline   Reply With Quote
Begging for a PhD thesis Qingang Xiong OpenFOAM Running, Solving & CFD 2 May 10, 2012 13:58
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
PhD student project in CFD with OpenFOAM on hydro power generator cooling at Chalmers hani OpenFOAM 0 February 29, 2008 09:12
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 10:33
C. L. Reed's PhD thesis at University of Texas at Arlington Atit Koonsrisuk Main CFD Forum 2 June 22, 2000 17:07
