Updated native OpenFOAM reader for ParaView 5.3 |
March 17, 2017, 08:51 |
OpenCFD
Rep Power: 19 |
ESI-OpenCFD has been continuing its work on improving post-processing.
Working together with Kitware, the VTK-native OpenFOAM reader in the freshly released ParaView 5.3.0 now includes full support of 32-bit and 64-bit binary formats, better coverage of the Lagrangian formats, and the option to skip the initial conditions directory. https://blog.kitware.com/paraview-5-3-0-release-notes/ This release also includes essential improvements for parsing STL ASCII files. (https://gitlab.kitware.com/vtk/vtk/merge_requests/2357). At the same time, the OpenFOAM plugins for ParaView have been updated in our development line (for the upcoming 1706 release in June) to work with all recent ParaView versions. The blockMesh reader now also includes support for displaying the patch names, which allows better visualization of a blockMesh. (https://develop.openfoam.com/Develop...hics/PVReaders) Note that the ParaView plugins supplied with OpenFOAM are now versioned according to the ParaView major version, which makes it possible to easily switch between different ParaView versions without conflicts. |
April 3, 2017, 12:24 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Question: Whom do I contact if I find a problem with that reader? ParaView-bugtracker or yours? For instance: if I have only one non-zero data folder (for instance 0 and 42) it seems that the Time-name is not correctly display in the GUI if "Skip Zero Time" is selected. The displayed data clearly belongs to t=42 but the GUI says "Time: 0"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
April 4, 2017, 10:04 |
#3 | |
Mark Olesen
Rep Power: 40 |
I would recommend the paraview bug-tracker (or the paraview mailing list). You can also put olesenm into the distributor list there too if desired. For your reported bug: I don't really know if this is easily fixable. This seems to be a general assumption within the vtk framework - if there is only set of data, it is by definition zero and you can't change it with the spin-box. You can use the fast-forward controls (last-frame) though and "annotate time" should display the proper value. So I'd guess this is an annoying, but partially cosmetic, corner-case not specific to the OpenFOAM reader. One issue that has cropped up with the reader are holes in the display (when the mesh is fairly large, but no polys). I believe that someone at kitware is looking into it. I suspect something odd with the cell-matcher yielding negative tets or something. There is a test case posted on the paraview mailing list (5.5M cells) that illustrates this problem. It does loads properly using our reader module (develop), and when converted to VTK legacy. Need to chop it down a bit and see if the problems remain, are somehow related to an overrun, or can otherwise be pinpointed. /mark |
July 13, 2017, 06:05 |
#4 | |
Rep Power: 17 |
Like gschaider, I am not sure where to report this.... |
July 13, 2017, 11:14 |
#5 | |
Mark Olesen
Rep Power: 40 |
Do you have a case that you can share (either publicly or privately)? It would be good so see where the problem is. /mark |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 11:19 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
Native OpenFOAM interface in Pointwise | Chris Sideroff | Main CFD Forum | 0 | January 16, 2009 13:37 |
[OpenFOAM] Posted OpenFOAM native reader for ParaView3CVS | 7islands | ParaView | 0 | October 24, 2007 11:52 |
