[mesh manipulation] Problems with rotational cyclic boundaries
Like Tree1Likes
  • 1 Post By henrik
Old   March 13, 2012, 10:42
Default Problems with rotational cyclic boundaries
Thomas Reviol
TReviol is on a distinguished road
Dear Foamers,
I am using OpenFOAM 1.6-ext and 2.1.0. In 1.6-ext I created a rotational cyclic BC without any Problems. In Version 2.1.0, I can't create these BC without any errors.
I also tried translational cyclicys with another Case. These are running without any Problems in both Versions. So, I think there is no mistake in my proceeding. The Problem occurs only for rotating problems.
Here the createPatchDict I am using for OF2.1.0:
pointSync false;
patches
        name TRANS_PER1;
        patchInfo
            type cyclic;
            neighbourPatch TRANS_PER2;
            transform rotational;
            rotationAxis (1 0 0);
            rotationCentre (0 0 0);
            matchTolerance 1E-04;
        constructFrom patches;
        patches ("PERIODIC1");
        name TRANS_PER2;
        patchInfo
            type cyclic;
            neighbourPatch TRANS_PER1;
            rotationAxis (0 0 1);
        patches ("periodic_sh");
and the boundary-file is:
7
    SHROUD
        type            wall;
        nFaces          1179;
        startFace       168915;
    HUB
        type            wall;
        nFaces          1025;
        startFace       170094;
    AIRFOIL
        type            wall;
        nFaces          8118;
        startFace       171119;
    IN
        type            patch;
        nFaces          534;
        startFace       179237;
    OUT
        type            patch;
        nFaces          248;
        startFace       179771;
    PERIODIC1
        type            patch;
        nFaces          762;
        startFace       180019;
    periodic_sh
        type            patch;
        nFaces          762;
        startFace       180781;
When I run createPatch, the following error occurs:
Cannot find point in pts1 matching point 9164 coord:(67.6458 1.53543e-14 67.5526) in pts0 when using tolerance 0.000339588
Searching started from:9163 in pts1
    Compared coord:(-63.1278 -1.43289e-14 67.5526) with difference to point 130.774
    Compared coord:(-67.6458 -1.53543e-14 67.5526) with difference to point 135.292
cyclicPolyPatch::order : Writing neighbour faces to OBJ file "/scratch/reviol/Vorlesung/Sphere/TRANS_PER1_faces.obj"
cyclicPolyPatch::order : Writing my faces to OBJ file "/scratch/reviol/Vorlesung/Sphere/TRANS_PER2_faces.obj"
cyclicPolyPatch::order : Dumping currently found cyclic match as lines between corresponding face centres to file "/scratch/reviol/Vorlesung/Sphere/TRANS_PER2_faceCentres.obj"
--> FOAM Serious Error :
    From function cyclicPolyPatch::order(const primitivePatch&, labelList&, labelList&) const
    in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 1381
    Patch:TRANS_PER2 : Cannot match vectors to faces on both sides of patch
    Perhaps your faces do not match? The obj files written contain the current match.
    Continuing with incorrect face ordering from now on!
It is possible to start the case with simpleFoam, but after a few iteration-steps, the run is crashing (continuity diverges) and it seems to be a singularity point in the rotational-BCs. In CFX the run will complete normally.
Does anyone find a mistake in my proceedings?
Regards
Thomas Reviol
TReviol is offline   Reply With Quote
Old   March 13, 2012, 11:25
Steven van Haren
stevenvanharen is on a distinguished road
Hi Thomas,
If you post the case (without cyclics) I can take a look.
It is difficult to judge the case like this.
Regards,
Steven
stevenvanharen is offline   Reply With Quote
Old   March 25, 2012, 01:08
Question
Vishal Achasrya
vishalsacharya is on a distinguished road
Im facing the exact same issue. Direct specification of cyclic type in blockmeshdict and then running a blockmesh gives no errors. but when i do a checkmesh, it says that the 0th vertex has issues..
What did you do in 1.6-ext that makes it work there? Can you share the method in which you did this? did you directly do this in blockmeshdict? or did you make it a patch first and then try createpatch?
~Vishal
vishalsacharya is offline   Reply With Quote
Old   March 25, 2012, 07:24
Thomas Reviol
Hi Vishal,
in OF16ext, the Problem I solved was with planar cyclic-faces. The problem I asked for above is with planar and non-planar cyclic-faces. The problem seems to be the non-planar faces. I found in many threads the same Problem: e.g http://www.cfd-online.com/Forums/ope...ferrerid=39754. The cyclic-periodic of non-planar, rotational interfaces is only working when a face in the first interface Partner is indexed with i and the corresponding face of the second interface Partner is indexed with i+n/2 where n is the total number of the interface-elements. (Please correct me if I missunderstood how createPatch works). The only way to use such faces for cyclic boundarys is to renumber the mesh. Up to now I didn't find a way for a correct renumbering.
I just rerun the case with planar faces in OF210 an OF16ext, so I didn't realize the difference. And furthermore with the knowledge about the renumbering I am not sure about the correctness of the solution with planar faces.
So I didn't find a reliable way to solve these problems. I created all meshes in ICEMCFD. I guess it is possible to create a correct numbered mesh with blockMesh, but I'm not sure.
When I find the solution I will tell you how it works. Perhaps someone else knows the solution for this problem?
Regards
Thomas
PS: here is the createPatchDict I used in OF16ext:
| \\      /  F ield         | OpenFOAM Extend Project: Open source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
matchTolerance 1E-3;
pointSync true;
patchInfo
        name CYCLIC;
        dictionary
            type cyclic;
            rotationAngle 90;
        patches ("PERIODIC1" "PERIODIC2");
Old   March 25, 2012, 23:51
Vishal Achasrya
I do understand. My simulation uses rotationally cyclic BC. some faces are flat and some have a profile.
In OF16ext, what you said is true. Any version of OF before 2.x uses the old cyclic specification which is to have 1 to n/2 mapping onto n/2+1 to n. This is what createPatch creates. In OF 2.x and later, the separate cyclic faces are specified separately and use the neighborPatch to know their mapping. In case you use OF16ext case in OF2.x, you can take the 16ext case and run "foamUpgradeCyclics" to make it 2.x compatible.
One more thing, if you use 2.1.0 then that is the problem. It has a bug with the rotational cyclic creation using blockmesh.... use 2.1.x and install OF using git and run git pull often to make sure you have latest files. I am using 2.1.x and my same case which gave errors in 2.1.0 now works in 2.1.x without errors and no changes made.
If your case works in 16ext, just create it there and convert it to 2.1.x using the foamUpgradeCyclics utility.
Old   May 24, 2012, 11:40
alquimista is on a distinguished road
Maybe you can try with cyclic GGI.
There's more information here:
https://cmg.soton.ac.uk/community/at...LloydAug11.pdf
http://www.tfd.chalmers.se/~hani/kur...dy_2010_OP.pdf
alquimista is offline   Reply With Quote
Old   May 6, 2013, 06:32
Thomas Reviol
Hi sam1364,
since OF 2.1.1., my problems with cyclics are solved. Perhaps you could also try a newer version.
I never tried the latest version, but I assume that OF 2.2.0. will also be able to handle cyclics.
Regards
Thomas
Old   July 15, 2013, 11:57
Henrik Rusche
henrik is on a distinguished road
Please note that the transformation in the original post (#1) is incorrect as the rotationAxis is not identical.
Henrik
Tobi likes this.
henrik is offline   Reply With Quote
Old   July 11, 2014, 04:45
Tommy V
Villo is on a distinguished road
Hi guys,
working on OpenFoam 2.2.0 i`m having a similar problem.
Thomas, unfortunately the newest version is not solving my problem.
Is a channel with 6 inclined lateral surfaces. I need to make 4 of these boundaries cyclic (2by2).
Please check my post
http://www.cfd-online.com/Forums/ope...l-patches.html
I tried applying a rotation, renumbering mesh, modifying way to export mesh from Gambit (exported as fluent 5/6 and then imported in OpenFoam via fluent3DMeshToFoam), no way to let it work.
Villo is offline   Reply With Quote
wedge vs rotational cyclic boundary conditions? wildfire230 OpenFOAM Running, Solving & CFD 4 January 2, 2021 10:29
[Commercial meshers] Rotational cyclic BC in ICEM generated mesh esgee OpenFOAM Meshing & Mesh Conversion 0 May 8, 2013 09:42
how to create cyclic from 2 boundaries in Openfoam 1.7.1 vsflap OpenFOAM 4 April 26, 2013 04:30
mapFields - Changing from turbulentInlet/outlet boundaries to cyclic boundaries TianC OpenFOAM Pre-Processing 8 January 16, 2013 06:15
error in cyclic boundaries match Steve Siemens 2 March 4, 2008 05:32
