[snappyHexMesh] how to define patches with snappyHexMesh from a STL file ? |
Cyprien
Rep Power: 18 ![]() |
Hi!
I had a mesh defined as a STL file. Let's say my geometry is a cylinder. However my STL file only provides a default patche and I would like to define 3 different patches (inlet, outlet, wall). Do you know how can I do such a thing with snappyHexMesh (or another tool) ? Best regards, Cyp |
Roman Thiele
Rep Power: 21 ![]() |
you can use names stl files, where the patches of your cylinder have names (check the motorbike tutorial for this)
or provide multiple stl files where each one contains the patch that is supposed to me meshed.
~roman |
#3 | |
Soufien T
Rep Power: 0 ![]() |
I know the thread is quite old but I wanted to ask the same question you already asked on the forum. Did you manage to define inlet and outlet patches when using snappyhexmesh. If yes, could you please let me know how you did. thank you Sofiene |
Mihai Pruna
Rep Power: 16 ![]() |
If you have one stl file with multiple solids defined one after another:
geometry { yourfile.stl { type triSurfaceMesh; name whatever; regions { solid1_name_in_stl_file { name whatever1; } solid2_name_in_stl_file { name whatever2; } .....
Mihai Pruna's Bio |
Soufien T
thank you!!
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
