sirLentschi
Rep Power: 15 ![]() |
Hello everyone,
i got an error during solving due to uncovered Faces. Here is my log-file: .............. Reading field p Reading field U Reading/calculating face flux field phi Initializing the GGI interpolator between master/shadow patches: DT-TO-RU-SIDE-1/DT-TO-RU-SIDE-2 Initializing the GGI interpolator between master/shadow patches: RU-TO-SVWG-SIDE-1/RU-TO-SVWG-SIDE-2 Initializing the GGI interpolator between master/shadow patches: SVWG-TO-SC-SIDE-2/SVWG-TO-SC-SIDE-1 From function void GGIInterpolation<MasterPatch, SlavePatch>::rescaleWeightingFactors() const in file /home/lenama/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/GGIInterpolationWeights.C at line 535 Uncovered faces found. On master: 0 on slave: 56 --> FOAM FATAL ERROR: Found uncovered faces for GGI interface SVWG-TO-SC-SIDE-2/SVWG-TO-SC-SIDE-1 while the bridgeOverlap option is not set in the boundary file. This is an unrecoverable error. Aborting. From function void ggiPolyPatch::calcPatchToPatch() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 129. FOAM aborting The error occurs on a static GGI between stay-vane and spiral casing of my pumpturbine. This is my checkMesh-log: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-ext Exec : checkMesh Date : Apr 14 2011 Time : 17:25:04 Host : hdhhteris PID : 26239 Case : /home/lenama/OpenFOAM/lenama-1.6-ext/run/PT-70/Steady/scsvwgrudt/p04_steady nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 20932365 faces: 61290393 internal faces: 59796813 cells: 20181201 boundary patches: 17 point zones: 0 face zones: 10 cell zones: 1 Overall number of cells of each type: hexahedra: 20181201 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 5 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology DT-TO-RU-SIDE-1 6720 6817 ok (non-closed singly connected) INFLOW 8620 8742 ok (non-closed singly connected) WALLSTAT-DT 60370 60585 ok (non-closed singly connected) DT-TO-RU-SIDE-2 37665 37909 ok (non-closed singly connected) RU-TO-SVWG-SIDE-1 27216 27702 ok (non-closed singly connected) WALLROT-RU 222921 223633 ok (non-closed singly connected) WALLSTAT-RU 28674 30132 ok (non-closed singly connected) OUTFLOW 5126 5240 ok (non-closed singly connected) SVWG-TO-SC-SIDE-2 17600 18003 ok (non-closed singly connected) WALLSTAT-SC 75666 76181 ok (non-closed singly connected) NOSE_LOWER-SIDE-1 11760 12027 ok (non-closed singly connected) NOSE_LOWER-SIDE-2 11760 12027 ok (non-closed singly connected) NOSE_UPPER-SIDE-1 11760 12027 ok (non-closed singly connected) NOSE_UPPER-SIDE-2 12096 12369 ok (non-closed singly connected) RU-TO-SVWG-SIDE-2 53872 54948 ok (non-closed singly connected) SVWG-TO-SC-SIDE-1 68432 69825 ok (non-closed singly connected) WALLSTAT-SVWG 833322 836325 ok (non-closed singly connected) Checking geometry... This is a 3-D mesh Overall domain bounding box (-0.551782 -0.722608 -1.13494) (2.40857 0.611412 0.21191) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Mesh (non-empty, non-wedge) dimensions 3 Boundary openness (2.09114e-16 2.47771e-16 6.42884e-17) Threshold = 1e-06 OK. Max cell openness = 1.14105e-14 OK. Max aspect ratio = 285.062 OK. Minumum face area = 1.98427e-09. Maximum face area = 0.000732129. Face area magnitudes OK. Min volume = 3.78415e-13. Max volume = 6.52634e-06. Total volume = 1.18127. Cell volumes OK. Mesh non-orthogonality Max: 79.7603 average: 22.3968 Threshold = 70 *Number of severely non-orthogonal faces: 226963. Non-orthogonality check OK. Writing 226963 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 5.39191, 399 highly skew faces detected which may impair the quality of the results Threshold = 4 Writing 399 skew faces to set skewFaces Failed 1 mesh checks. End There should be no uncovered faces in my mesh - so why does OF cause this error? How can I show this "uncovered faces" in ParaView or inhibit this problem?The mesh also passed the checkMesh in ICEM! So does anyone have an idea or some experiences to resolve this error? Thanks in advance. Regards Markus |
Rep Power: 16 ![]() |
Maybe try to do this in the constant/polyMesh/boundary file:
insideSlider { type ggi; nFaces 216; startFace 95925; shadowPatch outsideSlider; zone insideZone; bridgeOverlap true; } outsideSlider { type ggi; nFaces 240; startFace 96141; shadowPatch insideSlider; zone outsideZone; bridgeOverlap true; } |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 16:45 |
[ICEM] Problem with meshing (uncovered faces, can't export bocos) | hectordiaz | ANSYS Meshing & Geometry | 16 | May 13, 2011 06:36 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
