[mesh manipulation] refineMesh Dict
Like Tree1Likes
  • 1 Post By guy_smiling
Old   August 18, 2010, 13:01
Default refineMesh Dict
Frank Whittle
challenger is on a distinguished road
I couldn't find any documentation on the refineMesh dictionary. Can anyone explain what measures I must take to refine a mesh in a particular direction?
Thanks a lot
challenger is offline   Reply With Quote
Old   September 12, 2010, 16:11
guy_smiling is on a distinguished road
I think you can find some examples of refineMeshDict in the tutorials (particularly multiphase/cavitatingFoam has some examples of it in use). Also there's a refinemeshDict that is well commented in applications/utilities/mesh/manipulation/refineMesh which you can see how it works. Basically there are three vectors (normally (1 0 0) (0 1 0) and (0 0 1)) which refine the mesh in the x, y, and z directions respectively. Changing those 1's to larger numbers refines it differently in the respective direction.
Metti likes this.
guy_smiling is offline   Reply With Quote
Old   January 14, 2011, 00:18
Stefano Wahono
swahono is on a distinguished road
Thank you!
swahono is offline   Reply With Quote
blockmesh, refinement, refinemesh, snappy
fail to run series of runApplication topoSet -dict jiahui_93 OpenFOAM Programming & Development 1 May 25, 2022 13:56
[mesh manipulation] Unstructured tetrahedral mesh Refinement using REFINEMESH DICT UTILITY.???? POSSIBLE? saddy OpenFOAM Meshing & Mesh Conversion 4 February 1, 2019 06:58
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 14:44
[mesh manipulation] Iterate refineMesh sgr OpenFOAM Meshing & Mesh Conversion 1 May 13, 2015 06:49
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
