[CAD formats] Can OpenFOAM convert foam mesh to stl?
Like Tree13Likes
  • 2 Post By liying02ts
  • 5 Post By olesen
  • 3 Post By eugene
  • 2 Post By olesen
  • 1 Post By olesen
Old   February 10, 2010, 00:48
Default Can OpenFOAM convert foam mesh to stl?
liying
liying02ts is on a distinguished road
hello,everyone:
I want to convert the foam mesh to stl, it likes ICEM exporting stl file.
but, I don't know if OpenFOAM has the functions.
I find there is a utility named surfaceFeatureExtract, but it only used on surface mesh, but not a whole foam mesh.
I wonder if there a way to exporting stl file from the foam mesh by using OpenFOAM not a third soft.
thank you ~~
amuzeshi and ordinary like this.
liying02ts is offline   Reply With Quote
Old   February 10, 2010, 03:29
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
A "foamToSurface" doesn't seem to exist yet, but you can try the following:
  • foamToStarMesh -surface [-latestTime | -constant]
This should create surfExport.{cel,vrt} files
  • touch surfExport.inp
This creates a dummy file that identifies the grouping of files as proSTAR files.
  • surfaceMeshConvert surfExport.inp surfExport.stl
Convert to STL (or other) surface format.
olesen is offline   Reply With Quote
Old   February 10, 2010, 05:04
Eugene de Villiers
eugene is on a distinguished road
If you just want the outside of the FOAM mesh as an STL, there is a handy tool called "surfaceMeshTriangulate" that will do it for you.
maryCFD, amuzeshi and souza.emer like this.
eugene is offline   Reply With Quote
Old   February 10, 2010, 05:08
liying
thank you for your reply
I tried it just now, but surfaceConvert can't read the .inp file.
The suppurted extensions are .ftr/.stl/.stlb/.gts/.obj/.ac/.off/.nas/.tri .
The OpenFOAM extension I use is OpenFOAM-1.6.
Old   February 10, 2010, 05:11
liying
Oh, It is just what I want.
Thank you very much
Old   February 11, 2010, 04:34
Mark Olesen
Sure, but surfaceMeshConvert is what I use.
Old   July 15, 2010, 06:08
Sofia
Sofia is on a distinguished road
Hi everyone;
I have a .stl file which represent a body and I want to calcul a flow around it. I need to choose the dimension of my external box (in which there is my body) but I don't know how...Have you got an idea?
Thank you for your reply
Sofia
Sofia is offline   Reply With Quote
Old   November 21, 2016, 13:55
Emre
ordinary is on a distinguished road
I tried this method. It did not work for my 3D surface body (zero volume) which is in MSH and MESHDAT file format from Ansys.
ordinary is offline   Reply With Quote
Old   October 10, 2017, 05:26
Mark Olesen
The conversion utils only work to export from OpenFOAM format. In the meantime (since the first post), there is a foamToSurface utility to export the mesh boundaries directly.
ordinary and MTomić like this.
Old   December 5, 2018, 07:58
wenhui
wenhuicc is on a distinguished road
I tried this on my 3D.msh. But the size of created surfExport.inp is zero and the created meshExport.stl showed nothing.
OpenFOAM i used is v5.
Can you please give some comments? thanks
wenhuicc is offline   Reply With Quote
Old   December 30, 2018, 11:03
Mark Olesen
Did you try with surfaceMeshTriangulate? The name is misleading (will be updated soon). Exports OpenFOAM patches (all, or just some) to various surface formats, including stl, obj etc
fumiya likes this.
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 04:13
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
