[Gmsh] Structured mesh in gmsh without Extrude function
Like Tree6Likes
  • 5 Post By ericnutsch
  • 1 Post By gmazanakis
Old   January 5, 2010, 15:24
Default Structured mesh in gmsh without Extrude function
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
Hey everyone,
I have had good luck meshing tetras and prisms with gmsh. However now I am wanting to created a structured hex mesh.
Here is what I currently can do. It requires two extrude functions and can only be controlled by the first parameter:
______________________________________
Point(1) = {0,0,0,0.1};
Point(2) = {1,0.2,0,0.1};
Point(3) = {2,0,0,0.1};
Spline(1) = {1,2,3} ;
Extrude {0,1,0} {
Line{1}; Layers{5}; Recombine;
Extrude {0,0,.1} {
Surface{5}; Layers{1}; Recombine;
Here is what I want to do. This shape requires the mesh to be controlled by two parameters, and allows you to do much much more with it. Is it possible to do this?
Point(4) = {-.5,1,0,0.1};
Point(5) = {1,1.2,0,0.1};
Point(6) = {2.5,1,0,0.1};
Spline(2) = {4,5,6} ;
Line(3)={1,4};
Line(4)={3,6};
Line Loop(5) = {1,4,-2,-3} ;
Plane Surface(6) = {5}
Thanks for your help!
ericnutsch is offline   Reply With Quote
Old   January 6, 2010, 19:38
Talking Got it to work!
Eric Nutsch
Persistence is victorious again...
A big thanks to dolfyn.net or I may never have figured it out:
Here is my script:
// Kudos to dolfyn for an awesome tutorial
// http://www.dolfyn.net/dolfyn/gmsh/tutorial06.html
 Point(4) = {-0.5,1,0,0.1};
Line(3)={1,4};
Line(4)={3,6};
 Line Loop(1) = {1,4,-2,-3} ;
 Plane Surface(1) = {1};
// Tell Gmsh how many cells you want per edge
Transfinite Line{3,4} = 10;
Transfinite Line{1,2} = 15;
// Tell Gmsh what the corner points are(going clockwise or counter-clockwise):
Transfinite Surface{1} = {1,3,6,4};
// Recombine the triangles into quads:
Recombine Surface{1};
// Havent tested this yet, but doesnt seem to hurt:
Mesh.Smoothing = 100;
// Extrued for a psudo 2D mesh :)
Extrude {0,0,0.15} {Surface{1}; Layers{1}; Recombine; }
lhcamilo, riesotto, Hisham and 2 others like this.
Old   December 6, 2013, 08:52
Default structured mesh: transfinite surface with more than 6 corners
gmazanakis is on a distinguished road
I need to create a mesh in a wind blade for my phd. I want to use hex element with structured mesh.
I will get the geometry in a .stp file (see the attach please) so I can not interfere in the geometry.
I merge the stp with a scrip (see the attach please) to recombine and transfinite but I have problems with the surface which has more than 5 corners....
the files are in this link https://dl.dropboxusercontent.com/u/...RightBlade.zip
Any ideas please?
binband likes this.
gmazanakis is offline   Reply With Quote
[Gmsh] GMSH : structured mesh issue bibiboom OpenFOAM Meshing & Mesh Conversion 0 May 17, 2017 19:49
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
Structured Mesh in GMSH vitor Main CFD Forum 4 April 28, 2010 09:15
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
