[snappyHexMesh] snappyHexMesh problems 1.5->1.6
Like Tree1Likes
  • 1 Post By Solarberiden
Old   August 24, 2009, 11:54
Default snappyHexMesh problems 1.5->1.6
Gavin Tabor
grtabor is on a distinguished road
Hi. I have a snappyHexMesh case which worked fine with 1.5 but upgrading to 1.6, I get the following error message:
Shell refinement iteration 0
Marked for refinement due to refinement shells : 0 cells.
Determined cells to refine in = 1.52 s
Selected for internal refinement : 13280 cells (out of 138087)
hexRef8 : Dumping cell as obj to "/home/gavin/OpenFOAM/gavin-1.6/run/shuttleSnappy/cell_106631.obj"
cell 106631 of level 3 uses more than 8 points of equal or lower level
Points so far:8(21039 32067 37690 37691 49159 152912 154100 155267)#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/foam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
... it then gives me a long stack trace which I won't reproduce unless someone thinks its important. Can anyone suggest what might be causing this problem or what it means?
Gavin
grtabor is offline   Reply With Quote
Old   August 24, 2009, 14:34
Mattijs Janssens
mattijs is on a distinguished road
Hi Gavin,
did you remove any left-over files (foamClearPolyMesh)? If the problem persists in 1.6.x feel free to report a bug.
mattijs is offline   Reply With Quote
Old   August 24, 2009, 17:27
Gavin Tabor
Hi Mattijs,
I didn't try that - but just have and it made no difference.
By 1.6.x - is there a bug-fixed version of 1.6 now? (I've been away on holiday for a few weeks). If so I will try with that before posting a bug report; if you think its likely to be a bug.
Gavin
Old   May 24, 2011, 07:58
Default Same problem here!
Hannes
Hanno is on a distinguished road
Same problem here! And absolutely no idea how to get or even search for a solution. Any help is very appreciated.
Hanno is offline   Reply With Quote
Old   June 22, 2011, 09:51
Default problem solved for hexRef8 problem:
TCH
Solarberiden is on a distinguished road
you should first run
> foamCleanTutorials
as the snappyHexMesh has create several time folders for saving the iteration data of HexMeshes
not just
> foamCleanPolyMesh
Good luck!
j-avdeev likes this.
Solarberiden is offline   Reply With Quote
Old   May 18, 2012, 04:00
Antti is on a distinguished road
I had the same problem and it was caused by locationInMesh that was close to the surface of the object. In my case, it was not caused by the upgrade though, but same error message none the less.
Here is the original thread: http://www.cfd-online.com/Forums/ope...rnal-flow.html
If any of you still have this problem, you might want to try to move the point further away from the surface.
Antti is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Problems with snappyHexMesh samiam1000 OpenFOAM Meshing & Mesh Conversion 2 February 3, 2015 09:31
[snappyHexMesh] OF 1.5-dev or OF 1.6 for snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 11:43
[snappyHexMesh] SnappyhexMesh and Symmetryplane bastil OpenFOAM Meshing & Mesh Conversion 10 October 7, 2008 18:07
