May 9, 2005, 13:04 |
Upper triangular face order
Matt Amos
Rep Power: 17 |
Hi all,
I'm trying to convert a mesh from our in-house format to Foam format, but I keep having problems failing the "upper triangular order" mesh check. I've had a look for what "upper triangular order" entails other than the obvious, but I can't find a definition anywhere. Any help appreciated, Matt |
May 9, 2005, 13:33 |
Simply said upper-triangular o
Mattijs Janssens
Rep Power: 26 |
Simply said upper-triangular order is that the order of faces corresponds to the order of the cells they connect.
- take all (higher numbered) cells connected to a cell. - sort them according to their cell label - the faces connecting to those cells should now also be ordered. renumberMesh will do this for you. |
April 15, 2014, 09:04 |
Upper-triangular order in detail
#3 | |
Richel Bilderbeek
Rep Power: 13 |
Trying to following the advice, I:
All files and output (and future solution) can be found at https://github.com/richelbilderbeek/...eek/issues/181 , yet I also put the files here. Trace of the faces used, the name of their boundary type and the index of the cell that owns the face: Code:
#Face index - Boundary type - Index of Cell owning the Face TRACE 's.str()' line 174 in file '..\..\Classes\CppTriangleMesh\trianglemeshbuilder.cpp': '0: inside: 1' TRACE 's.str()' line 174 in file '..\..\Classes\CppTriangleMesh\trianglemeshbuilder.cpp': '1: top: 0' TRACE 's.str()' line 174 in file '..\..\Classes\CppTriangleMesh\trianglemeshbuilder.cpp': '2: top: 1' TRACE 's.str()' line 174 in file '..\..\Classes\CppTriangleMesh\trianglemeshbuilder.cpp': '3: right: 0' TRACE 's.str()' line 174 in file '..\..\Classes\CppTriangleMesh\trianglemeshbuilder.cpp': '4: left: 0' TRACE 's.str()' line 174 in file '..\..\Classes\CppTriangleMesh\trianglemeshbuilder.cpp': '5: front: 1' TRACE 's.str()' line 174 in file '..\..\Classes\CppTriangleMesh\trianglemeshbuilder.cpp': '6: bottom: 0' TRACE 's.str()' line 174 in file '..\..\Classes\CppTriangleMesh\trianglemeshbuilder.cpp': '7: bottom: 1' TRACE 's.str()' line 174 in file '..\..\Classes\CppTriangleMesh\trianglemeshbuilder.cpp': '8: back: 1' Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\ | Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com | \*---------------------------------------------------------------------------*/ Build : 2.1-88b2f2ae3a0b Exec : checkMesh Date : Apr 15 2014 Time : 13:41:22 Host : "AIRBEAR-W7-I5" PID : 5668 Case : D:/Projects/Tools/build-ToolTestTriangleMeshConsole-Desktop_Qt_5_1_1_MinGW_32bit-Debug nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 8 internal points: 0 faces: 9 internal faces: 1 cells: 2 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 2 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. ***Faces not in upper triangular order. <<Writing 1 unordered faces to set upperTriangularFace Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology top 2 4 ok (non-closed singly connected) right 1 4 ok (non-closed singly connected) left 1 4 ok (non-closed singly connected) front 1 4 ok (non-closed singly connected) bottom 2 4 ok (non-closed singly connected) back 1 4 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.92388 -0.92388 1) (0.92388 0.92388 2) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (0 1.14967e-017 0) OK. ***Open cells found, max cell openness: 1, number of open cells 2 <<Writing 2 non closed cells to set nonClosedCells Minimum face area = 1. Maximum face area = 2. Face area magnitudes OK. Min volume = 0.777778. Max volume = 0.777778. Total volume = 1.55556. Cell volumes OK. Mesh non-orthogonality Max: 180 average: 180 ***Number of non-orthogonality errors: 1. <<Writing 1 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 2 faces are incorrectly oriented. <<Writing 1 faces with incorrect orientation to set wrongOrientedFaces Max skewness = 0.404762 OK. Coupled point location match (average 0) OK. Failed 4 mesh checks. End Code:
FoamFile { version 2.0; format ascii; class faceSet; location "constant/polyMesh/sets"; object upperTriangularFace; } 1 ( 0 ) Code:
FoamFile { version 2.0; format ascii; class vectorField; location "constant/polyMesh"; object points; } 8 ( (-0.92388000000000003 -0.382683 1) (-0.92388000000000003 -0.382683 2) (-0.382683 0.92388000000000003 1) (-0.382683 0.92388000000000003 2) (0.382683 -0.92388000000000003 1) (0.382683 -0.92388000000000003 2) (0.92388000000000003 0.382683 1) (0.92388000000000003 0.382683 2) ) Code:
FoamFile { version 2.0; format ascii; class faceList; location "constant/polyMesh"; object faces; } 9 ( 4(2 4 5 3) 3(5 7 3) 3(3 1 5) 4(2 3 7 6) 4(4 6 7 5) 4(0 4 5 1) 3(2 6 4) 3(4 0 2) 4(0 1 3 2) ) Code:
FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant\polyMesh"; object boundary; } 6 ( top { type zeroGradient; nFaces 2; startFace 1; } right { type zeroGradient; nFaces 1; startFace 3; } left { type zeroGradient; nFaces 1; startFace 4; } front { type zeroGradient; nFaces 1; startFace 5; } bottom { type zeroGradient; nFaces 2; startFace 6; } back { type zeroGradient; nFaces 1; startFace 8; } ) Code:
FoamFile { version 2.0; format ascii; class labelList; note "nPoints: 8 nCells: 2 nFaces: 9"; location "constant/polyMesh"; object owner; } 9 ( 1 0 1 0 0 1 0 1 1 ) Code:
FoamFile { version 2.0; format ascii; class labelList; note "nPoints: 8 nCells: 2 nFaces: 9"; location "constant/polyMesh"; object neighbour; } 9 ( 0 -1 -1 -1 -1 -1 -1 -1 -1 )
I will never accept a 'Friend' request, I will always accept beer Last edited by assert; April 15, 2014 at 09:07. Reason: layout |
April 15, 2014, 10:37 |
[FIXED] Upper-triangular order in detail
Richel Bilderbeek
Rep Power: 13 |
The algorithm to assign indices to a cell is as follows:
* Partition faces (yes, faces) in boundaries * Maintain a cell index counter, start it at zero. * Go through all these faces: find the face its owner (i.e. the cell that owns that face). If that cell has not been assigned a cell index yet, assign it a cell index. Increase that cell index counter.
I will never accept a 'Friend' request, I will always accept beer |
May 7, 2024, 22:37 |
Simpler explanation
Bob Tipton
Rep Power: 7 |
While the final consequence of misordered face, owner and neighbour files RESULTS in a matrix which is not upper triangular, this message is misleading.
If the reorderMesh app were run automatically, this would not be an issue and the matrix would be correct. The issue is, what order do the faces need to be in the "faces" file to produce such the desired matrix. The answer can be seen by viewing the faces, owner and neighbour data in parallel, as follows. The first column is the vertex indices as ordered in the faces file. The second column are the owner [cell] indices - which must be in ascending order The third column are the neighbour [cell] indices - which must also be in ascending order - within that cell. If the files meet these conditions, they will create an upper triangular matrix when read. Mesh files written in this way, with good cells and faces, pass checkMesh. How this is assured is up to the author. (6, 7, 5, 4) 0 1 (2, 3, 7, 6) 0 2 (5, 7, 3, 1) 0 4 (6, 7, 11, 9) 1 3 (10, 11, 7, 5) 1 5 (11, 10, 8, 9) 1 8 (54, 55, 7, 6) 2 3 (3, 7, 55, 53) 2 6 (55, 54, 52, 53) 2 48 (61, 55, 7, 11) 3 7 (11, 9, 60, 61) 3 10 (55, 61, 60, 54) 3 49 (5, 7, 280, 279) 4 5 (278, 280, 7, 3) 4 6 (280, 278, 277, 279) 4 204 (11, 7, 280, 286) 5 7 (11, 286, 285, 10) 5 12 (280, 279, 285, 286) 5 205 (280, 7, 55, 330) 6 7 (55, 53, 329, 330) 6 52 (280, 330, 329, 278) 6 206" Last edited by Bob Tipton; May 7, 2024 at 22:40. Reason: Columnating |
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 15:18 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
2nd order boundary conditions for 2nd order discretization? | quarkz | Main CFD Forum | 30 | December 26, 2011 08:12 |
Upper triangular ordering | deepsterblue | OpenFOAM Running, Solving & CFD | 0 | December 3, 2007 12:41 |
