November 29, 2024, 07:09 |
blockMesh/sHM: defaultFaces
Rep Power: 15 |
Good Morning,
i am stuck with blockMesh/snappyHexMesh: I manage to mesh my cases with blockMesh, usually a big cube. All faces are "defaultFaces" with no patchtype. When i run sHM with my inlet/out/wall stl file, all goes fine but my solver does not run because of this: Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Starting time loop Selecting finite volume options type scalarSemiImplicitSource Source: IncrementTime - selecting all cells - selected 3652902 cell(s) with volume 0.303072 Time = 1 smoothSolver: Solving for T, Initial residual = 1, Final residual = 0.00840505, No Iterations 13 -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 95 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [76] [76] [76] --> FOAM FATAL ERROR: (openfoam-2406) [76] Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 1e-300 Specified mass inflow : 2.69687e-05 Specified mass outflow : 0 Adjustable mass outflow : 0 [76] Here is the main part of my U file: boundaryField { inlet { type flowRateInletVelocity; massFlowRate $massenStrominkgs; rhoInlet $dichte_; } outlet { type zeroGradient; } wall { type noSlip; } defaultFaces { type empty; } } Can someone help me how to get rid of the defaultFaces (coming obviously from blockMesh)? |
November 29, 2024, 07:45 |
Yann
Rep Power: 29 |
Hello Fanta,
What kind of geometry are you meshing? Is it an internal flow? Before running your case, have you checked your mesh? When you don't define any boundary in blockMeshDict, patches are automatically named defaultFaces and get an empty type by default. However, as far as I remember, snappyHexMesh does not like empty types. So it is very likely to find warnings about this in your snappy log (for instance complaining about 2D/3D dimensions), and possibly a failed mesh. To avoid undefined faces to get an empty type with blockMesh, you can define your boundary section in blockMeshDict as: Code:
boundary ( defaultFaces { type patch; faces (); } ); If you are meshing an internal flow entirely defined by your STL file, you should not have any remaining defaultFaces in your mesh if snappy ran successfully. |
November 29, 2024, 08:26 |
Rep Power: 15 |
Hey Yann; first of all: thank you for your help!
Yes, i am running an internal flow, using a inlet.stl, outlet.stl and a wall.stl. I edited the blockMeshDict as you recommended and checkMesh did not complain anymore. Now my simulation is running and Ansys is no longer needed. FYI: We have been using Ansys CFD PrepPost for meshing since 2017 on and now i am switching to blockMesh/sHM. Running in parallel it is really a lot more faster than Ansys + we are saving money if we stop using Ansys. |
[mesh manipulation] Stitching defaultFaces | gm.arx.2024 | OpenFOAM Meshing & Mesh Conversion | 0 | November 7, 2024 06:39 |
[Gmsh] defaultFaces boundary condition | bruce21 | OpenFOAM Meshing & Mesh Conversion | 0 | June 21, 2022 08:55 |
[blockMesh] How to get rid of defaultFaces | flowwwww | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2020 02:25 |
[Gmsh] unwanted defaultFaces after exporting to foam 5.0 | deepbandivadekar | OpenFOAM Meshing & Mesh Conversion | 8 | July 3, 2018 17:37 |
How to get rid of the defaultFaces, Courant number diverge. | liguifan | OpenFOAM Running, Solving & CFD | 1 | May 1, 2011 00:13 |
