[snappyHexMesh] No geometry showing after snappyHexMesh run (URGENT)
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By hussainazam2002
Old   November 20, 2024, 05:50
Post No geometry showing after snappyHexMesh run (URGENT)
Hussain
hussainazam2002 is on a distinguished road
As the title explains, after I run snappyHexMesh and then open the mesh in paraview, all I see is the cuboid I defined in blockMesh. I am a beginner to openfoam and really need to solve this problem urgently. If anyone has any idea as to why this is happening it would help me a lot. I have attached my snappyHexMesh file below. the geometry is literally just a cylinder.
hussainazam2002 is offline   Reply With Quote
Old   November 20, 2024, 06:01
M
AtoHM is on a distinguished road
If you get the blockMesh as output, something went wrong when running snappyHexMesh. Could be anything from ill-defined locationInMesh to running out of memory. You have to log the output of snappyHexMesh and post it here or analyse it yourself.
AtoHM is offline   Reply With Quote
Old   November 20, 2024, 07:03
Default snappyHexMesh log file attached
Hussain
Thank you for your help. I have attached the log file with this reply. I am having problems reading the file to identify the mistake I am making. Any help would be greatly appreciated.
Old   November 20, 2024, 07:17
Yann
Yann will become famous soon enoughYann will become famous soon enough
When visualizing your mesh in ParaView, do you move to the latest time step? (time 26)
This is where you final mesh should be.
AtoHM likes this.
Yann is offline   Reply With Quote
Old   November 20, 2024, 07:35
Hussain
Oh my it worked. I have spent the last week editing and rewriting files and running the mesh over and over. To think I had not changed it to the final time step . Thank you so much Yann!
Yann likes this.
[snappyHexMesh] Run snappyHexMesh steps (castellated, snap, addlayer) separately Glc OpenFOAM Meshing & Mesh Conversion 6 October 8, 2021 03:50
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
Restarted run and change in geometry...question Vanessa CFX 3 August 28, 2006 08:55
