[snappyHexMesh] high skewness and random triangles issue on structured stl mesh
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By panda007
Old   October 23, 2024, 01:02
Default high skewness and random triangles issue on structured stl mesh
panda007 is on a distinguished road
I'm desperate needing some help.
I'm trying to use snappyHexMesh to mesh around a rigid body with structured grid. It worked fine before. It's a rectangular shape with a rounded bottom body. After I adjusted the size of the body, no matter how carefully I calculated the cell number to make sure the edge of the body lies on the cell edge, the snappyHexMesh just keep throwing me random triangle cells.
It's driving me nuts, I have tried to changed the nSmoothPatch, minVol, minArea, maxBoundarySkewness, maxNonOrtho, it is still the same.
I'm running out of options. please help me if anyone has any clues. Thanks for any help.
castellatedMesh true;
snap            true;
addLayers       false;
geometry
    body.stl
        type    triSurfaceMesh;
        name    body;
        regions
            body
                name    body;
    BoxRefinement
        type    box;
        min     ( 7.83 -0.56 -0.44);
        max     ( 8.01 0.56 0.13 );
castellatedMeshControls
    maxLocalCells   100000000;
    maxGlobalCells  500000000;
    minRefinementCells 20;
    nCellsBetweenLevels 3;
    maxLoadUnbalance 0.1;
    allowFreeStandingZoneFaces true;
    resolveFeatureAngle     30;
    features
            file "body.eMesh" ;
            level 0 ;
    refinementSurfaces
        body
            level (0 0);
            regions
                body
                    level (0 0);
refinementRegions
        BoxRefinement
            mode    inside;
            levels  ((1 1));
    locationInMesh ( 7.85 -0.53 -0.42 ) ;
snapControls
    tolerance       2;
    implicitFeatureSnap false;
    explicitFeatureSnap true;
    multiRegionFeatureSnap true;
    detectNearSurfacesSnap true;
    nSmoothPatch    3;
    nSolveIter      50;
    nRelaxIter      5;
    nFeatureSnapIter 10;
    nSmoothInternal 3;
    nFaceSplitInterval 5;
addLayersControls
    layers
        "(body)"
            nSurfaceLayers 4;
    relativeSizes    true ;
    expansionRatio    1.1 ;
firstLayerThickness   0.8 ;
    featureAngle    85;
    slipFeatureAngle 30;
    nGrow           0;
    nBufferCellsNoExtrude 0;
    minMedialAxisAngle 90;
    maxFaceThicknessRatio 0.2;
    maxThicknessToMedialRatio 0.3;
    minThickness    1e-06;
    nLayerIter      50;
    nRelaxIter      5;
    nSmoothSurfaceNormals 10;
    nSmoothNormals  3;
    nSmoothThickness 10;
    nRelaxedIter    10;
    nMedialAxisIter 10;
meshQualityControls
    minVol          1e-6; //1e-20;
    minTetQuality   1e-6; //1e-20;
    minArea         5e-6; //1e-20;
    minTwist        0.1; //0.05;
    minDeterminant  1e-5; //1e-06;
    minFaceWeight   0.1; //0.02;
    minVolRatio     0.1; //0.01;
    minTriangleTwist -1;
    minFlatness     0.5;
    maxNonOrtho     20; //30; //60;
    maxBoundarySkewness 2; //12;
    maxInternalSkewness 2; //4;
    maxConcave      80;
    nSmoothScale    4;
    errorReduction  0.75;
    relaxed
        minVol          1e-6; //1e-30;
        minTetQuality   1e-6; //1e-30;
        minArea         1e-5; //1e-30;
        minTwist        0.05; //0.001;
        minFaceWeight   1e-5; //1e-06;
        minFlatness     0.5;
        maxNonOrtho     20; //30; //75;
        maxBoundarySkewness 2; //20;
        maxInternalSkewness 2; //8;
        maxConcave      80;
        nSmoothScale    4;
mergeTolerance  1e-06;
debug           0;
panda007 is offline   Reply With Quote
Old   October 23, 2024, 02:40
M
AtoHM is on a distinguished road
cfMesh noisy mesh
AtoHM is offline   Reply With Quote
Old   October 23, 2024, 05:19
M
Btw, using such tough meshQuality targets as maxNonOrtho 20; can lead to adverse effects for more complex geometries.
Give the mesher some room to work by allowing for a certain non orthogonality and skewness. Non-orthogonality arises already when you use different cell levels (at the transition), now add some inclined faces and you already top 20 degrees. The default I think is 65, which is absolutely fine.
Skewness of 2 is also quite low, up to 12 and even beyond (sometimes) is a save range from my experience. At least for OpenFOAM.
Old   October 23, 2024, 14:11
Hi Ingo,
Thanks for the quick response!
I'm using Paraview 5.13 the newest version, I have enabled the full mode for setting, but I don't see any options for 'decompose polyhedra'. And I can't find the crinkle stuff. I was using clip for mesh visualization.
I have used all the default values for maxNonOrtho, degree, skewness, it was still the same issue.
So you think it's just a visualization issue? How can I make it display the mesh better without all the noise triangles?
Thank you so much for helping me out!! I really appreciate it!!
Old   October 26, 2024, 06:37
Yann
Yann will become famous soon enoughYann will become famous soon enough
This is without doubt a visualization issue.
In ParaView 5.13, there is no more "decompose polyhedra" option and polyhedra are not decomposed anymore.
On your clip, you need to tick "crinkle clip". Same thing with "crinkle slice" if you are using the slice filter.
Cheers,
Yann
Yann is offline   Reply With Quote
Old   October 28, 2024, 11:35
Cheers,
Yann
Hello Yann,
Thank you so much for pointing out this is visualization issue! I turned on the Crinkle clip option on Paraview. The mesh looks so much better now!!! The only issue now is that the mesh does show some extra layer of cells on the clip face, do I need to worry about it or it is totally okay?
Old   October 28, 2024, 13:23
Yann
Hello panda,
During the meshing process, snappyHexMesh do some mesh morphing operations when snapping the mesh onto the geometry surface. This leads to moving nodes/cells, which are not perfectly aligned anymore, as it was in the initial background mesh.
When you slice or clip the mesh, the lines you see in your original screenshots are cells which have been cut by ParaView in order to produce the slice/clip.
The crinkle option allow to display the cells intersecting the slicing/clipping plane instead of cutting it.
The extra cells you see on your last screenshot are those cells which are itersecting the plane which are now displayed instead of being cut (if you untick the crinkle option, you will probably see lines where you have the extra cells).
You can try it with a slice instead of a clip, maybe it will help you to visualize what is going on. Try to slightly move the position of your clipping/slicing plane and those will disappear. (others might appear)
Anyway, this is only a visualization matter, nothing to worry about.
Cheers,
Yann
panda007 likes this.
Old   October 31, 2024, 09:46
Hello panda,
Cheers,
Yann
Hello Yann,
Thanks for the detailed explanation!! That is good to know that it is just a visualization issue. The mesh looks much better with crinkle slice. Thank you!!
Yann likes this.
[ANSYS Meshing] [ANSYS Meshing] Fixing high skewness on simple elbow pipe luzikato ANSYS Meshing & Geometry 2 May 10, 2020 03:34
