[snappyHexMesh] Replacing ANSYS Workbench Meshing with snappyHexMesh
Like Tree3Likes
  • 1 Post By AtoHM
  • 2 Post By rocketLauncher
Old   August 16, 2024, 06:14
Post Replacing ANSYS Workbench Meshing with snappyHexMesh
fanta is on a distinguished road
Good Morning,
i am trying to make the simulation workflow easier and to save money for the company.
It all got started with introducing Siemens NX instead of Solidworks as the main CAD programm for the machines we are developing. With Siemens NX one can easily export multi-region STL files for a given watertight CAD design (before that we were using Solidworks, multi-region STL Files were not possible + overall CAD and STL quality was tpoor, too). So with Solidworks as CAD system we meshed with Ansys Workbench, exported to Fluent (ASCII) and after dos2unix we imported to OpenFOAM with fluent3DMeshtofoam. Now (my idea, with Siemens NX) i can export the STL files (always inlet.txt, outlet.txt and wall.txt), move that files in my case and do the rest with scripts! After one week of learning blockMesh and snappyHexMesh i still don't know if will be succesful. I started with a simple pipe, moved to a easy part. Both were meshed with sHM and i ran the simulations successfull and they show the same results compared with the Ansys mesh. I am still having trouble with the watertightness of the STL files, for the "real parts" the surfaceCheck Tool shows openness. Our real geometries to simulate are up to 2m in diameter and have small gaps (0.8mm), so this is not so easy. Has anyone done something similar?
-Replaced ANSYS Workbench meshing with sHM?
-use blockMesh/sHM in scripted, industrial environment?
edit: OpenFOAM v2406
fanta is offline   Reply With Quote
Old   August 16, 2024, 06:49
Fun Times
happyHexMesh is on a distinguished road
bad idea in current state of sHM
happyHexMesh is offline   Reply With Quote
Old   August 21, 2024, 09:20
M
AtoHM is on a distinguished road
If you know what you are doing, sHM is a quite capable mesher. Go ahead and show us another open source tool that gives us hex dominant, unstructured meshes .. I would be happy. I guess there is none.
Regarding your questions, I cannot go into details of how we do all of it, but in my company we mesh like 95 % of our jobs in sHM, using either Solidworks or FreeCAD as our CAD input. It is no secret (look for the discussions here in the forum) that FreeCAD can produce watertight STLs. So yeah, its possible, and it is done was we speak
fanta likes this.
AtoHM is offline   Reply With Quote
Old   August 28, 2024, 07:03
rocketLauncher is on a distinguished road
I am working on a similar change atm. For snappyHexMesh, BaramCFD is very helpful because it provides a UI to make the process easier. It's still in development so you have to be patient as not all industrial features are available. They are very responsive to feedback though.
snappy is extremely capable, but you have to dedicate time to it in order to learn how to make the most of all the features. I would highly recommend that you give yourself more time to train. Aso, read the notes of Wolf Dynamics and some article on cfdMonkey about how to improve quality.
fanta and AtoHM like this.
rocketLauncher is offline   Reply With Quote
[ANSYS Meshing] polyhedral mesh which is generated directly in Workbench Poly Meshing for Fluent teguhtf ANSYS Meshing & Geometry 0 January 24, 2019 23:04
ansys workbench meshing sanjaykummar2810 CFD Freelancers 6 August 15, 2018 01:47
[ANSYS Meshing] mixing elbow meshing in ansys workbench tmeysam92 ANSYS Meshing & Geometry 0 April 6, 2012 04:09
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
Meshing In Ansys Workbench For Fluent (Refinement) FAU_OceanEng FLUENT 0 May 31, 2010 18:12
