[snappyHexMesh] snappyhexmesh locationinmesh many bodies |
July 23, 2024, 05:52 |
Rep Power: 3 |
let say I have CHT problem with 50 bolts. Do I have to have 50 regions and manually define 50 insidePoint?? Is it possible to have all 50 bolts in only 1 region, since there is only one material and field (T)? Last edited by jacobCFD; July 23, 2024 at 08:45. |
July 23, 2024, 08:09 |
M
Rep Power: 12 |
Not necessarily. The regions are also kept (meshed) if you specify a faceZone and a cellZone for it (you need faceZone to produce cellZone) in snappyHexMeshDict / refinementSurfaces / ... . You end up with 1 region per bolt, but it appears you can merge them, I hope this link helps: merge or combine several cellZone
July 23, 2024, 08:16 |
Rep Power: 3 |
Yeah, but will I need to define 50 insidePoint?
August 1, 2024, 06:53 |
Rep Power: 3 |
Allright, I achieved this by having correctly directed normals for stl face elements and
BOLT { level ( 4 4 ) ; faceZone BOLT; cellZone BOLT; mode inside; } splitMeshRegions -cellZonesOnly -overwrite |
Two bodies in same fluid but different velocities | averis007 | FLUENT | 0 | December 11, 2020 06:54 |
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found | cdase | ANSYS Meshing & Geometry | 0 | August 26, 2018 14:31 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] SnappyHexMesh and locationinMesh | aqua | OpenFOAM Meshing & Mesh Conversion | 7 | January 6, 2012 04:57 |
