[snappyHexMesh] Geometry Splitting and Layer Refinement Around Curvatures |
#1 | |
Ilyes SAYAD
Rep Power: 5 ![]() |
Hello everyone,
I'm attempting to replicate the simulation case presented in this article as a validation for my model. However, I'm encountering difficulties with the meshing process. Quote:
I am facing the following issues:
I have attached the case file for reference. Thank you for your assistance! |
Yann
Rep Power: 27 ![]() |
Hello Ilyes,
Regards, Yann |
#3 | |
Ilyes SAYAD
Bonjour Yann,
Thank you for your reply ! Quote:
I still have two other questions regarding the 3D simulation :
Yann
Bonjour Ilyes,
I don't have a specific tutorial for that because it depends on the software you use to prepare your geometries. Some software supports regions in STL/OBJ files, others do not. So you will have to dig a bit more about that on your own. Regarding your questions:
Regards, Yann |
[snappyHexMesh] SnappyHexMesh stuck at "Introducing baffles..." | Rojj | OpenFOAM Meshing & Mesh Conversion | 1 | June 30, 2023 08:14 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
[mesh manipulation] Splitting the mesh for AMI | wgvanveen | OpenFOAM Meshing & Mesh Conversion | 17 | October 18, 2017 05:23 |
[snappyHexMesh] Bad meshing result on corrugated metal sheet | UebertreibeR | OpenFOAM Meshing & Mesh Conversion | 1 | August 19, 2016 04:55 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
