[snappyHexMesh] Max skewness level, skew faces detected |
June 13, 2024, 13:41 |
Alvaro
Rep Power: 2 |
Hi everyone,
I'm trying to do a flow simulation with a 3D .obj Fórmula 1 car. I'm having a problem when I do "checkMesh" having the message I uploaded below. I'm having an error sayingt "Max skewness and 1 skewface detected" which I tried to edit my snappyHexMeshDict file, on the refinementBox having the same level of refinement (6 6). This it's a tip I saw on other guys thread wich was resolved the problem but not for me, I'm still having the same problem. Has anyone any tip for this type of problem? I can not go forward with the simulation without having this correct. Any help is welcome. Thanks! Checking geometry... Overall domain bounding box (-5 -4 -0.134617) (15 4 5.86538) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.05812e-17 -1.24883e-16 9.08509e-16) OK. Max cell openness = 1.05155e-15 OK. Max aspect ratio = 41.0957 OK. Minimum face area = 8.41388e-07. Maximum face area = 1.00262. Face area magnitudes OK. Min volume = 1.69327e-08. Max volume = 0.754462. Total volume = 959.895. Cell volumes OK. Mesh non-orthogonality Max: 63.9446 average: 4.56077 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 9.21033, 1 highly skew faces detected which may impair the quality of the results <<Writing 1 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End |
June 14, 2024, 07:57 |
M
Rep Power: 13 |
Have you actually checked if the simulation runs?
Besides that, the first step would be to figure out where the issue occurs. For that you have several options, either let checkMesh put out the quality metric as fields which you can visualize in Paraview directly (I think this is only available in ESI version, not sure). Or you can check the faceSet "skewFaces" that checkMesh wrote with these bad cells and convert that to VTK to visualize in PV aswell. The key is to understand where the issue is and then decide on a strategy to resolve. |
#mesh #snappyhexmesh |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 07:33 |
Converging Diverging Nozzle with dbnsTurbFoam | Saleh Abuhanieh | OpenFOAM Running, Solving & CFD | 4 | December 13, 2019 11:26 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 17:45 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 17:08 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
